Hello Fellow Programmers,
I am now in need of a license for my ccsv5 and I am trying to figure out which license is the best one for me and the company I work for.
I am curious about the floating license. I have seen in the wiki the following:
'If you are configured to check out a license from a license server and you take your computer off the network, CCS will continue to function with no limitation. Note that it will indicate in the title bar that it is currently unlicensed since it was unable to get a license from the server, but otherwise functionality will not be limited. It is not using up a floating license when operating this way."
I am confused, as I thought I could not use my JTAG if Code Composer is not licensed. Are there really no limitations?
I have to go customers' sites, and using JTAG (XDS510LC in my case) is sometimes needed; I cannot remotely access the server that would be holding my floating license.
So in a nutshell: can I use JTAG if I don't have access to my floating license present on my office's server?
Thank you all in advance for your help!
Christophe
