combining identical string literals
hi all
i'm using the TM320C6x C/C++ compiler and linker v6.1.19 and i have noticed that the linker does not seem to combine identical string literals into one.
for instance, if you have an assertion in a header file that uses __FILE__ to include the file name in the message, and you include this header file in N compilation units, then you'll end up with N copies of that header file's name in the final output. this results in a considerable amount of wasted space.
is there any option you know of to tell the linker to combine identical string literals?
cheers,
sam
    No.  The compiler reuses string literals within a single source file (and the files it includes), but not across source files.
    Thanks and regards,
    -George
