I am Using code composer 6.0.1.00040, arm compiler 5.1.9 & Tiva C 129XNCZAD micro controller,I am wandering if there is an option in the CCS IDE to set the default of the structure alignment to be packed(no padding) .
i don't want to use the GCC extension type __attribute__((__packed__)) with each structure definition but i want want to make it as a default.
Thank you
Ahmed
