Other Parts Discussed in Thread: ENERGIA, MSP430F5529, MSP430WARE
i dont know how to interface it but i need to.....please provide any info about this issue even if the inter face is in energia....
thanks gautam
i have gone through the datasheet of "dogs102-6 102x64 lcd"(
i have also studied the schematics of my msp430f5529 experiment board ..(
you have provided me valuable input and i have learned a lot as a student...... but i am sorry to say that i am facing the following problems:
1. i dont know how to use the spi library .
2. i was going through the net & i found a few header files for interfacing my lcd with msp one of them was " HAL_dogs102-6.h" and also "HAL_dogs102-6"
i tried to copy paste it in the ccs folder where the header file are located (ie "include folder") but there were lots of them....so i dont know where . but still i tried to paste and succeeded in making it identify the functions .but yet it showed errors. the contents of the .h and .c are given below
/******************************************************************************* * * HAL_Dogs102x6.h * * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ******************************************************************************/ #ifndef HAL_DOGS102X6_H #define HAL_DOGS102X6_H #include <stdint.h> // Screen size #define DOGS102x6_X_SIZE 102 // Display Size in dots: X-Axis #define DOGS102x6_Y_SIZE 64 // Display Size in dots: Y-Axis // Screen printing styles #define DOGS102x6_DRAW_NORMAL 0x00 // Display dark pixels on a light background #define DOGS102x6_DRAW_INVERT 0x01 // Display light pixels on a dark background // Screen printing mode #define DOGS102x6_DRAW_IMMEDIATE 0x01 // Display update done immediately #define DOGS102x6_DRAW_ON_REFRESH 0x00 // Display update done only with refresh extern uint8_t dogs102x6Memory[]; // Provide direct access to the frame buffer extern void Dogs102x6_init(void); extern void Dogs102x6_backlightInit(void); extern void Dogs102x6_disable(void); extern void Dogs102x6_refresh(uint8_t mode); extern void Dogs102x6_writeCommand(uint8_t* sCmd, uint8_t i); extern void Dogs102x6_writeData(uint8_t* sData, uint8_t i); extern void Dogs102x6_setAddress(uint8_t pa, uint8_t ca); extern uint8_t Dogs102x6_getContrast(void); extern uint8_t Dogs102x6_getBacklight(void); extern void Dogs102x6_setContrast(uint8_t newContrast); extern void Dogs102x6_setBacklight(uint8_t brightness); extern void Dogs102x6_setInverseDisplay(void); extern void Dogs102x6_clearInverseDisplay(void); extern void Dogs102x6_scrollLine(uint8_t lines); extern void Dogs102x6_setAllPixelsOn(void); extern void Dogs102x6_clearAllPixelsOn(void); extern void Dogs102x6_clearScreen(void); extern void Dogs102x6_charDraw(uint8_t row, uint8_t col, uint16_t f, uint8_t style); extern void Dogs102x6_charDrawXY(uint8_t x, uint8_t y, uint16_t f, uint8_t style); extern void Dogs102x6_stringDraw(uint8_t row, uint8_t col, char *word, uint8_t style); extern void Dogs102x6_stringDrawXY(uint8_t x, uint8_t y, char *word, uint8_t style); extern void Dogs102x6_clearRow(uint8_t row); extern void Dogs102x6_pixelDraw(uint8_t x, uint8_t y, uint8_t style); extern void Dogs102x6_horizontalLineDraw(uint8_t x1, uint8_t x2, uint8_t y, uint8_t style); extern void Dogs102x6_verticalLineDraw(uint8_t y1, uint8_t y2, uint8_t x, uint8_t style); extern void Dogs102x6_lineDraw(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, uint8_t style); extern void Dogs102x6_circleDraw(uint8_t x, uint8_t y, uint8_t radius, uint8_t style); extern void Dogs102x6_imageDraw(const uint8_t IMAGE[], uint8_t row, uint8_t col); extern void Dogs102x6_clearImage(uint8_t height, uint8_t width, uint8_t row, uint8_t col); #endif /* HAL_DOGS102x6_H */
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
and this is the .c file
* HAL_Dogs102x6.c - Driver for the DOGS 102x6 display
* are met:
* distribution.
* @file HAL_Dogs102x6.c
* @addtogroup HAL_Dogs102x6
#include "msp430.h"
#include "HAL_Buttons.h"
#include "HAL_Dogs102x6.h"
// Macros
#ifndef abs
# define abs(n) (((n) < 0) ? -(n) : (n))
#endif
// For all commands, CD signal must = 0
#define SET_COLUMN_ADDRESS_MSB 0x10 //Set SRAM col. addr. before write, last 4 bits =
// ca4-ca7
#define SET_COLUMN_ADDRESS_LSB 0x00 //Set SRAM col. addr. before write, last 4 bits =
// ca0-ca3
#define SET_POWER_CONTROL 0x2F //Set Power control - booster, regulator, and follower
// on
#define SET_SCROLL_LINE 0x40 //Scroll image up by SL rows (SL = last 5 bits),
// range:0-63
#define SET_PAGE_ADDRESS 0xB0 //Set SRAM page addr (pa = last 4 bits), range:0-8
#define SET_VLCD_RESISTOR_RATIO 0x27 //Set internal resistor ratio Rb/Ra to adjust contrast
#define SET_ELECTRONIC_VOLUME_MSB 0x81 //Set Electronic Volume "PM" to adjust contrast
#define SET_ELECTRONIC_VOLUME_LSB 0x0F //Set Electronic Volume "PM" to adjust contrast (PM =
// last 5 bits)
#define SET_ALL_PIXEL_ON 0xA4 //Disable all pixel on (last bit 1 to turn on all pixels
// - does not affect memory)
#define SET_INVERSE_DISPLAY 0xA6 //Inverse display off (last bit 1 to invert display -
// does not affect memory)
#define SET_DISPLAY_ENABLE 0xAF //Enable display (exit sleep mode & restore power)
#define SET_SEG_DIRECTION 0xA1 //Mirror SEG (column) mapping (set bit0 to mirror
// display)
#define SET_COM_DIRECTION 0xC8 //Mirror COM (row) mapping (set bit3 to mirror display)
#define SYSTEM_RESET 0xE2 //Reset the system. Control regs reset, memory not
// affected
#define NOP 0xE3 //No operation
#define SET_LCD_BIAS_RATIO 0xA2 //Set voltage bias ratio (BR = bit0)
#define SET_CURSOR_UPDATE_MODE 0xE0 //Column address will increment with write operation
// (but no wrap around)
#define RESET_CURSOR_UPDATE_MODE 0xEE //Return cursor to column address from before cursor
// update mode was set
#define SET_ADV_PROGRAM_CONTROL0_MSB 0xFA //Set temp. compensation curve to -0.11%/C
#define SET_ADV_PROGRAM_CONTROL0_LSB 0x90
// Pins from MSP430 connected to LCD
#define CD BIT6
#define CS BIT4
#define RST BIT7
#define BACKLT BIT6
#define SPI_SIMO BIT1
#define SPI_CLK BIT3
// Ports
#define CD_RST_DIR P5DIR
#define CD_RST_OUT P5OUT
#define CS_BACKLT_DIR P7DIR
#define CS_BACKLT_OUT P7OUT
#define CS_BACKLT_SEL P7SEL
#define SPI_SEL P4SEL
#define SPI_DIR P4DIR
// Font lookup table
static const uint8_t FONT6x8[] = {
/* 6x8 font, each line is a character each byte is a one pixel wide column
* of that character. MSB is the top pixel of the column, LSB is the bottom
* pixel of the column. 0 = pixel off. 1 = pixel on. */
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // space
0x00, 0x00, 0xFA, 0x00, 0x00, 0x00, // !
0x00, 0xE0, 0x00, 0xE0, 0x00, 0x00, // "
0x28, 0xFE, 0x28, 0xFE, 0x28, 0x00, // #
0x24, 0x54, 0xFE, 0x54, 0x48, 0x00, // $
0xC4, 0xC8, 0x10, 0x26, 0x46, 0x00, // %
0x6C, 0x92, 0x6A, 0x04, 0x0A, 0x00, // &
0x00, 0x10, 0xE0, 0xC0, 0x00, 0x00, // '
0x00, 0x38, 0x44, 0x82, 0x00, 0x00, // (
0x00, 0x82, 0x44, 0x38, 0x00, 0x00, // )
0x54, 0x38, 0xFE, 0x38, 0x54, 0x00, // *
0x10, 0x10, 0x7C, 0x10, 0x10, 0x00, // +
0x00, 0x02, 0x1C, 0x18, 0x00, 0x00, // ,
0x10, 0x10, 0x10, 0x10, 0x10, 0x00, // -
0x00, 0x00, 0x06, 0x06, 0x00, 0x00, // .
0x04, 0x08, 0x10, 0x20, 0x40, 0x00, // /
//96 Bytes
0x7C, 0x8A, 0x92, 0xA2, 0x7C, 0x00, // 0
0x00, 0x42, 0xFE, 0x02, 0x00, 0x00, // 1
0x42, 0x86, 0x8A, 0x92, 0x62, 0x00, // 2
0x84, 0x82, 0x92, 0xB2, 0xCC, 0x00, // 3
0x18, 0x28, 0x48, 0xFE, 0x08, 0x00, // 4
0xE4, 0xA2, 0xA2, 0xA2, 0x9C, 0x00, // 5
0x3C, 0x52, 0x92, 0x92, 0x0C, 0x00, // 6
0x82, 0x84, 0x88, 0x90, 0xE0, 0x00, // 7
0x6C, 0x92, 0x92, 0x92, 0x6C, 0x00, // 8
0x60, 0x92, 0x92, 0x94, 0x78, 0x00, // 9
0x00, 0x00, 0x28, 0x00, 0x00, 0x00, // :
0x00, 0x00, 0x02, 0x2C, 0x00, 0x00, // ;
0x00, 0x10, 0x28, 0x44, 0x82, 0x00, // <
0x28, 0x28, 0x28, 0x28, 0x28, 0x00, // =
0x00, 0x82, 0x44, 0x28, 0x10, 0x00, // >
0x40, 0x80, 0x8A, 0x90, 0x60, 0x00, // ?
//96*2 = 192 Bytes
0x7C, 0x82, 0xBA, 0x9A, 0x72, 0x00, // @
0x3E, 0x48, 0x88, 0x48, 0x3E, 0x00, // A
0xFE, 0x92, 0x92, 0x92, 0x6C, 0x00, // B
0x7C, 0x82, 0x82, 0x82, 0x44, 0x00, // C
0xFE, 0x82, 0x82, 0x82, 0x7C, 0x00, // D
0xFE, 0x92, 0x92, 0x92, 0x82, 0x00, // E
0xFE, 0x90, 0x90, 0x90, 0x80, 0x00, // F
0x7C, 0x82, 0x92, 0x92, 0x5E, 0x00, // G
0xFE, 0x10, 0x10, 0x10, 0xFE, 0x00, // H
0x00, 0x82, 0xFE, 0x82, 0x00, 0x00, // I
0x04, 0x02, 0x82, 0xFC, 0x80, 0x00, // J
0xFE, 0x10, 0x28, 0x44, 0x82, 0x00, // K
0xFE, 0x02, 0x02, 0x02, 0x02, 0x00, // L
0xFE, 0x40, 0x38, 0x40, 0xFE, 0x00, // M
0xFE, 0x20, 0x10, 0x08, 0xFE, 0x00, // N
0x7C, 0x82, 0x82, 0x82, 0x7C, 0x00, // O
//96*3 = 288 Bytes
0xFE, 0x90, 0x90, 0x90, 0x60, 0x00, // P
0x7C, 0x82, 0x8A, 0x84, 0x7A, 0x00, // Q
0xFE, 0x90, 0x98, 0x94, 0x62, 0x00, // R
0x64, 0x92, 0x92, 0x92, 0x4C, 0x00, // S
0x80, 0x80, 0xFE, 0x80, 0x80, 0x00, // T
0xFC, 0x02, 0x02, 0x02, 0xFC, 0x00, // U
0xF8, 0x04, 0x02, 0x04, 0xF8, 0x00, // V
0xFC, 0x02, 0x1C, 0x02, 0xFC, 0x00, // W
0xC6, 0x28, 0x10, 0x28, 0xC6, 0x00, // X
0xC0, 0x20, 0x1E, 0x20, 0xC0, 0x00, // Y
0x86, 0x8A, 0x92, 0xA2, 0xC2, 0x00, // Z
0x00, 0xFE, 0x82, 0x82, 0x82, 0x00, // [
0x40, 0x20, 0x10, 0x08, 0x04, 0x00, // '\'
0x00, 0x82, 0x82, 0x82, 0xFE, 0x00, // ]
0x20, 0x40, 0x80, 0x40, 0x20, 0x00, // ^
0x01, 0x01, 0x01, 0x01, 0x01, 0x00, // _
//96*4 = 384 Bytes
0x00, 0xC0, 0xE0, 0x10, 0x00, 0x00, // `
0x04, 0x2A, 0x2A, 0x2A, 0x1E, 0x00, // a
0xFE, 0x14, 0x22, 0x22, 0x1C, 0x00, // b
0x1C, 0x22, 0x22, 0x22, 0x14, 0x00, // c
0x1C, 0x22, 0x22, 0x14, 0xFE, 0x00, // d
0x1C, 0x2A, 0x2A, 0x2A, 0x18, 0x00, // e
0x00, 0x10, 0x7E, 0x90, 0x40, 0x00, // f
0x18, 0x25, 0x25, 0x25, 0x3E, 0x00, // g
0xFE, 0x10, 0x20, 0x20, 0x1E, 0x00, // h
0x00, 0x22, 0xBE, 0x02, 0x00, 0x00, // i
0x00, 0x04, 0x02, 0x02, 0xBC, 0x00, // j
0x00, 0xFE, 0x08, 0x14, 0x22, 0x00, // k
0x00, 0x82, 0xFE, 0x02, 0x00, 0x00, // l
0x3E, 0x20, 0x1E, 0x20, 0x1E, 0x00, // m
0x3E, 0x10, 0x20, 0x20, 0x1E, 0x00, // n
0x1C, 0x22, 0x22, 0x22, 0x1C, 0x00, // o
//96*5 = 480 Bytes
0x3F, 0x18, 0x24, 0x24, 0x18, 0x00, // p
0x18, 0x24, 0x24, 0x18, 0x3F, 0x00, // q
0x3E, 0x10, 0x20, 0x20, 0x10, 0x00, // r
0x12, 0x2A, 0x2A, 0x2A, 0x24, 0x00, // s
0x20, 0x20, 0xFC, 0x22, 0x24, 0x00, // t
0x3C, 0x02, 0x02, 0x04, 0x3E, 0x00, // u
0x38, 0x04, 0x02, 0x04, 0x38, 0x00, // v
0x3C, 0x02, 0x0C, 0x02, 0x3C, 0x00, // w
0x22, 0x14, 0x08, 0x14, 0x22, 0x00, // x
0x32, 0x09, 0x09, 0x09, 0x3E, 0x00, // y
0x22, 0x26, 0x2A, 0x32, 0x22, 0x00, // z
0x00, 0x10, 0x6C, 0x82, 0x00, 0x00, // {
0x00, 0x00, 0xEE, 0x00, 0x00, 0x00, // |
0x00, 0x82, 0x6C, 0x10, 0x00, 0x00, // }
0x40, 0x80, 0x40, 0x20, 0x40, 0x00, // ~
0x00, 0x60, 0x90, 0x90, 0x60, 0x00, // degrees symbol
//96*6 = 576 Bytes
//Special Characters ** NON-ASCII **
0x00, 0x00, 0xFE, 0x82, 0x82, 0x82, // [
0x82, 0x82, 0x82, 0xFE, 0x00, 0x00 // ]
// Variables
// Store a copy of the lcd memory (8x102) = 816 bytes
// Since we cannot read from the lcd memory, this is a way to keep track of
// what is stored there Two additional byes are used for driver-
// internal purposes
uint8_t dogs102x6Memory[816 + 2];
uint8_t currentPage = 0, currentColumn = 0;
uint8_t backlight = 8;
uint8_t contrast = 0x0F;
uint8_t drawmode = DOGS102x6_DRAW_IMMEDIATE;
// Dog102-6 Initialization Commands
uint8_t Dogs102x6_initMacro[] = {
SET_SCROLL_LINE,
SET_SEG_DIRECTION,
SET_COM_DIRECTION,
SET_ALL_PIXEL_ON,
SET_INVERSE_DISPLAY,
SET_LCD_BIAS_RATIO,
SET_POWER_CONTROL,
SET_VLCD_RESISTOR_RATIO,
SET_ELECTRONIC_VOLUME_MSB,
SET_ELECTRONIC_VOLUME_LSB,
SET_ADV_PROGRAM_CONTROL0_MSB,
SET_ADV_PROGRAM_CONTROL0_LSB,
SET_DISPLAY_ENABLE,
SET_PAGE_ADDRESS,
SET_COLUMN_ADDRESS_MSB,
* @brief Initialize LCD
* @param None
* @return None
// Port initialization for LCD operation
CD_RST_DIR |= RST;
// Reset is active low
CD_RST_OUT &= RST;
CD_RST_OUT |= RST;
// Chip select for LCD
CS_BACKLT_DIR |= CS;
// CS is active low
CS_BACKLT_OUT &= ~CS;
// Command/Data for LCD
CD_RST_DIR |= CD;
// CD Low for command
CD_RST_OUT &= ~CD;
// P4.1 option select SIMO
SPI_SEL |= SPI_SIMO;
SPI_DIR |= SPI_SIMO;
// P4.3 option select CLK
SPI_SEL |= SPI_CLK;
SPI_DIR |= SPI_CLK;
// Initialize USCI_B1 for SPI Master operation
// Put state machine in reset
UCB1CTL1 |= UCSWRST;
//3-pin, 8-bit SPI master
UCB1CTL0 = UCCKPH + UCMSB + UCMST + UCMODE_0 + UCSYNC;
// Clock phase - data captured first edge, change second edge
// MSB
// Use SMCLK, keep RESET
UCB1CTL1 = UCSSEL_2 + UCSWRST;
UCB1BR0 = 0x02;
UCB1BR1 = 0;
// Release USCI state machine
UCB1CTL1 &= ~UCSWRST;
UCB1IFG &= ~UCRXIFG;
Dogs102x6_writeCommand(Dogs102x6_initMacro, 13);
// Deselect chip
CS_BACKLT_OUT |= CS;
dogs102x6Memory[0] = 102;
dogs102x6Memory[1] = 8;
* @brief Initialize Backlight
* @param None
* @return None
// Turn on Backlight
CS_BACKLT_DIR |= BACKLT;
CS_BACKLT_OUT |= BACKLT;
// Uses PWM to control brightness
CS_BACKLT_SEL |= BACKLT;
// start at full brightness (8)
TB0CCTL4 = OUTMOD_7;
TB0CCR4 = TB0CCR0 >> 1;
TB0CCR0 = 50;
TB0CTL = TBSSEL_1 + MC_1;
* @brief Set function for the backlight PWM's duty cycle
* @param BackLightLevel The target backlight duty cycle - valued 0~11.
* @return none
unsigned int dutyCycle = 0, i, dummy;
if (brightness > 0)
dummy = (TB0CCR0 >> 4);
dutyCycle = 12;
for (i = 0; i < brightness; i++)
dutyCycle += dummy;
TB0CCR4 = dutyCycle;
//If the backlight was previously turned off, turn it on.
if (!backlight)
TB0CTL |= MC0;
else
TB0CCTL4 = 0;
TB0CTL &= ~MC0;
backlight = brightness;
* @brief Disable display
* @param None
* @return None
uint8_t cmd[1] = { SYSTEM_RESET };
Dogs102x6_writeCommand(cmd, 1);
cmd[0] = SET_DISPLAY_ENABLE & 0xFE;
* @brief Sends commands to LCD via 3 wire SPI
* @param sCmd Pointer to the commands to be written to the LCD
* @param i Number of commands to be written to the LCD
* @return None
void Dogs102x6_writeCommand(uint8_t *sCmd, uint8_t i)
// Store current GIE state
uint16_t gie = __get_SR_register() & GIE;
// Make this operation atomic
__disable_interrupt();
// CS Low
P7OUT &= ~CS;
// CD Low
P5OUT &= ~CD;
while (i)
// USCI_B1 TX buffer ready?
while (!(UCB1IFG & UCTXIFG)) ;
// Transmit data
UCB1TXBUF = *sCmd;
// Increment the pointer on the array
sCmd++;
// Decrement the Byte counter
i--;
// Wait for all TX/RX to finish
while (UCB1STAT & UCBUSY) ;
// Dummy read to empty RX buffer and clear any overrun conditions
UCB1RXBUF;
// CS High
P7OUT |= CS;
// Restore original GIE state
__bis_SR_register(gie);
* @brief Sends Data to LCD via 3 wire SPI
* @param sData Pointer to the Data to be written to the LCD
* @param i Number of data bytes to be written to the LCD
* @return None
void Dogs102x6_writeData(uint8_t *sData, uint8_t i)
if (drawmode == DOGS102x6_DRAW_ON_REFRESH)
while (i)
dogs102x6Memory[2 + (currentPage * 102) + currentColumn] = (uint8_t)*sData++;
currentColumn++;
// Boundary check
if (currentColumn > 101)
currentColumn = 101;
i--;
else
// CS Low
P7OUT &= ~CS;
//CD High
P5OUT |= CD;
while (i)
dogs102x6Memory[2 + (currentPage * 102) + currentColumn] = (uint8_t)*sData;
currentColumn++;
// Boundary check
// Transmit data and increment pointer
UCB1TXBUF = *sData++;
i--;
UCB1RXBUF;
// CS High
P7OUT |= CS;
* @brief Gets the current contrast level
* @param None
* @return Contrast level
return contrast;
* @brief Gets the current backlight level
* @param None
* @return Backlight level
return backlight;
* @brief Sets Address of the LCD RAM memory
* (0,0) is the upper left corner of screen.
* @param pa Page Address of the LCD RAM memory to be written (0 - 7)
* @param ca Column Address of the LCD RAM memory to be written (0 - 101)
* @return None
uint8_t cmd[1];
// Page boundary check
if (pa > 7)
pa = 7;
// Column boundary check
if (ca > 101)
ca = 101;
// Page Address Command = Page Address Initial Command + Page Address
cmd[0] = SET_PAGE_ADDRESS + (7 - pa);
uint8_t H = 0x00;
uint8_t L = 0x00;
uint8_t ColumnAddress[] = { SET_COLUMN_ADDRESS_MSB, SET_COLUMN_ADDRESS_LSB };
currentPage = pa;
currentColumn = ca;
if (drawmode == DOGS102x6_DRAW_ON_REFRESH) return; // exit if drawmode on refresh
// Separate Command Address to low and high
L = (ca & 0x0F);
H = (ca & 0xF0);
H = (H >> 4);
// Column Address CommandLSB = Column Address Initial Command
// + Column Address bits 0..3
ColumnAddress[0] = SET_COLUMN_ADDRESS_LSB + L;
// Column Address CommandMSB = Column Address Initial Command
// + Column Address bits 4..7
ColumnAddress[1] = SET_COLUMN_ADDRESS_MSB + H;
// Set page address
// Set column address
Dogs102x6_writeCommand(ColumnAddress, 2);
* @brief Sets the contrast
* @param contrast Contrast level (0~31, where 31 is darkest setting)
* @return None
uint8_t cmd[2];
cmd[0] = SET_ELECTRONIC_VOLUME_MSB;
//check if parameter is in range
if (newContrast > 0x1F)
cmd[1] = 0x1F;
else
cmd[1] = newContrast;
contrast = cmd[1];
Dogs102x6_writeCommand(cmd, 2);
// Save new contrast to initMacro
Dogs102x6_initMacro[8] = newContrast;
* @brief Inverts the screen (pixels on/off) - does not affect LCD memory.
* @param None
* @return None
uint8_t cmd[] = {SET_INVERSE_DISPLAY + 0x01};
* @brief Uninverts the screen (pixels on/off) - does not affect LCD memory.
* @param None
* @return None
uint8_t cmd[] = {SET_INVERSE_DISPLAY};
* @brief Scrolls image down a number of lines. The scrolling wraps around the screen.
* @param lines number of lines to scroll (0~63)
* @return None
uint8_t cmd[] = {SET_SCROLL_LINE};
if (lines > 0x1F)
cmd[0] |= 0x1F;
else
cmd[0] |= lines;
* @brief Sets all Pixels on
* @param None
* @return None
uint8_t cmd[] = {SET_ALL_PIXEL_ON + 0x01};
* @brief Returns pixels to normal functioning
* @param None
* @return None
uint8_t cmd[] = {SET_ALL_PIXEL_ON};
/****************************DRAWING FUNCTIONS*********************************/
* @brief Sets All pixels Off (in memory as well)
* @param None
* @return None
uint8_t LcdData[] = {0x00};
uint8_t p, c;
// 8 total pages in LCD controller memory
for (p = 0; p < 8; p++)
Dogs102x6_setAddress(p, 0);
// 102 total columns in LCD controller memory
for (c = 0; c < 102; c++)
Dogs102x6_writeData(LcdData, 1);
* @brief Writes a character from FONT6x8[] array to the LCD at (row,col).
* @param row Page Address (0 - 7) (there are 8 pages on the screen, each is 8 pixels tall)
* @param col Column Address (there are 102 columns on the screen)
* @param f Pointer to the character to be written to the LCD
* @param style The style of the text
* - NORMAL = 0 = dark letters with light background
* - INVERT = 1 = light letters with dark background
* @return None
// Each Character consists of 6 Columns on 1 Page
// Each Page presents 8 pixels vertically (top = MSB)
uint8_t b;
uint16_t h;
uint8_t inverted_char[6];
// Row boundary check
if (row > 7)
row = 7;
if (col > 101)
col = 101;
// handle characters not in our table
if (f < 32 || f > 129)
// replace the invalid character with a '.'
f = '.';
// subtract 32 because FONT6x8[0] is "space" which is ascii 32,
// multiply by 6 because each character is columns wide
h = (f - 32) * 6;
Dogs102x6_setAddress(row, col);
if (style == DOGS102x6_DRAW_NORMAL)
// write character
Dogs102x6_writeData((uint8_t *)FONT6x8 + h, 6);
else
for (b = 0; b < 6; b++)
// invert the character
inverted_char[b] = FONT6x8[h + b] ^ 0xFF;
// write inverted character
Dogs102x6_writeData(inverted_char, 6);
* @brief Writes a character from FONT6x8[] array to the LCD at (x,y).
* @param x Horizontal coordinate (0 - 102)
* @param y Vertical coordinate (0 - 63)
* @return None
// Each Character consists of 6 Columns 8 pixels tall
uint8_t b, row;
uint16_t h;
uint8_t desired_char[12];
// make sure we won't be writing off the screen
if (x >= 102)
x = 101;
if (y >= 64)
y = 63;
f = '.';
// subtract 32 because FONT6x8[0] is 'space' which is ascii 32,
// multiply by 6 because each character is 6 columns wide
h = (f - 32) * 6;
// Check if there is a remainder
row = y >> 3; // identical to: row = y / 8;
desired_char[b] =
(FONT6x8[h + b] >> (y % 8)) | dogs102x6Memory[2 + (row * 102) + x + b];
desired_char[b + 6] =
FONT6x8[h + b] << (8 - y % 8) | dogs102x6Memory[2 + ((row + 1) * 102) + x + b];
else
desired_char[b] = (FONT6x8[h + b] ^ 0xFF) >> (y & 0x07); // identical to: (y % 8);
desired_char[b + 6] = (FONT6x8[h + b] ^ 0xFF) << (8 - y & 0x07); // identical to: y % 8);
Dogs102x6_setAddress(row, x);
// write first line of character
Dogs102x6_writeData(desired_char, 6);
Dogs102x6_setAddress(row + 1, x);
// write second line of character
Dogs102x6_writeData(desired_char + 6, 6);
* @brief Writes a String to the LCD at (row,col).
* @param row Page Address (there are 8 pages on the screen, each is 8 pixels
* tall) (0 - 7)
* @param col Column Address (there are 102 columns on the screen) (0 - 101)
* @param word[] Pointer to the String to be written to the LCD
* @return None
uint8_t a = 0;
if (row > 7)
row = 7;
if (col > 101)
col = 101;
while (word[a] != 0)
// check for line feed '/n'
if (word[a] != 0x0A)
//check for carriage return '/r' (ignore if found)
if (word[a] != 0x0D)
//Draw a character
Dogs102x6_charDraw(row, col, word[a], style);
//Update location
col += 6;
//Text wrapping
if (col >= 102)
col = 0;
if (row < 7)
row++;
else
row = 0;
// handle line feed character
else
if (row < 7)
row++;
else
row = 0;
col = 0;
a++;
* @brief Writes a String to the LCD at (x,y).
* @return None
/* Each Character consists of 6 Columns on 1 Page
* Each Page presents 8 pixels vertically (top = MSB)*/
uint8_t a = 0;
// Draw a character
Dogs102x6_charDrawXY(x, y, word[a], style);
// Update location
x += 6;
// Text wrapping
if (x >= 102)
x = 0;
if (y + 8 < 64)
y += 8;
else
y = 0;
a++;
* @brief Clears one row/page (in memory as well).
* Row 0 is at the top of the screen.
* @param row The row to be cleared (0~7)
* @return None
uint8_t cmd[] = {0};
uint8_t a = 0;
// Check row boundary
if (row > 7)
row = 7;
Dogs102x6_setAddress(row, 0);
for (a = 0; a < 102; a++)
Dogs102x6_writeData(cmd, 1);
// dogs102x6Memory[2 + (row * 102) + a] = 0x00; // this is already done in writeData
* @brief Draws a pixel at (x,y).
* @param x x-coordinate of the point
* @param y y-coordinate of the point
* @param style The style of the pixel
* - NORMAL = 0 = dark pixel
* - INVERT = 1 = inverts pixel
* @return None
uint8_t p, temp;
//make sure we won't be writing off the screen
if (x > 101)
x = 101;
if (y > 63)
y = 63;
//determine the page
p = y >> 3; // identical to: p = y / 8;
//determine height of pixel within the page
temp = 0x80 >> (y & 0x07); // identical to: temp = 0x80 >> (y % 8);
//update our array
dogs102x6Memory[2 + (p * 102) + x] |= temp;
else
dogs102x6Memory[2 + (p * 102) + x] &= ~temp;
Dogs102x6_setAddress(p, x);
//draw pixel
Dogs102x6_writeData(dogs102x6Memory + (2 + (p * 102) + x), 1);
* @brief Draws a horizontal line on the LCD.
* @param x1 The horizontal line starting pixel coordinate (0~101)
* @param x2 The horizontal line ending pixel coordinate (0~101)
* @param y The height of the line (pixel row, not page) (0~63)
* @param style The style of the line
* - NORMAL = 0 = dark line, overwrites
* - INVERT = 1 = inverts color on line
* @return None
uint8_t temp = 0, p, a;
if (x1 > 101)
x1 = 101;
if (x2 > 101)
x2 = 101;
if (y > 63)
y = 63;
//swap coordinates if x1 is past x2
if (x1 > x2)
temp = x1;
x1 = x2;
x2 = temp;
//determine height of line within the page
a = x1;
while (a <= x2)
//draws a dark line through everything
dogs102x6Memory[2 + (p * 102) + a] |= temp;
else
//draws a light line through everything
dogs102x6Memory[2 + (p * 102) + a] &= ~temp;
a++;
Dogs102x6_setAddress(p, x1);
//draw the line
Dogs102x6_writeData(dogs102x6Memory + (2 + (p * 102) + x1), x2 - x1 + 1);
* @brief Draws a vertical line on the LCD.
* @param y1 The vertical line starting pixel coordinate (0~63)
* @param y2 The vertical line ending pixel coordinate (0~63)
* @param x The column of line (0~101)
* @return None
uint8_t temp1 = 0, temp2 = 0, p1, p2, a;
if (y1 > 63)
y1 = 63;
if (y2 > 63)
y2 = 63;
if (x > 101)
x = 101;
//swap coordinates if y1 is past y2
if (y1 > y2)
temp1 = y1;
y1 = y2;
y2 = temp1;
//determine the first page of line
p1 = y1 >> 3; // identical to: p1 = y1 / 8;
//determine the last page of line
p2 = y2 >> 3; // identical to: p2 = y2 / 8;
//mask for last page of line
temp2 = 8 - (y2 & 0x07); // identical to: temp2 = 8 - (y2 % 8);
temp2--;
temp2 = 0xFF << temp2;
//mask for first page of line
// Length that spans across multiple pages
if (p1 != p2)
// Check if there is an offset
if (y1 > 0)
temp1 = 0xFF00 >> (y1 & 0x07); // identical to: temp1 = 0xFF00 >> (y1 % 8);
temp1 = temp1 ^ 0xFF;
// If there is no offset, set all bits for lower mask
else
temp1 = 0xFF;
// Short length that only spans one page
else
// Clear lower page bits
temp1 = 0;
// mask off y1 from top page bits
a = y1 - (p1 * 8);
a = 0xFF00 >> a;
temp2 = temp2 ^ a;
// Prepare for first page of line
dogs102x6Memory[2 + (p1 * 102) + x] |= temp1;
else
dogs102x6Memory[2 + (p1 * 102) + x] &= ~temp1;
// Set starting address for first page
Dogs102x6_setAddress(p1, x);
//draw first page of line
Dogs102x6_writeData(dogs102x6Memory + (2 + (p1 * 102) + x), 1);
a = p1 + 1;
while (a < p2)
dogs102x6Memory[2 + (a * 102) + x] = 0xFF;
else
dogs102x6Memory[2 + (a * 102) + x] &= 0x00;
Dogs102x6_setAddress(a, x);
// draw middle of line
Dogs102x6_writeData(dogs102x6Memory + (2 + (a * 102) + x), 1);
a++;
// Prepare for last page of line
dogs102x6Memory[2 + (p2 * 102) + x] |= temp2;
else
dogs102x6Memory[2 + (p2 * 102) + x] &= ~temp2;
Dogs102x6_setAddress(p2, x);
//draw last page of line
Dogs102x6_writeData(dogs102x6Memory + (2 + (p2 * 102) + x), 1);
* @brief Draws a line from (x1,y1) to (x2,y2).
* Uses Bresenham's line algorithm.
* @param x1 x-coordinate of the first point
* @param y y-coordinate of the first point
* @param x2 x-coordinate of the second point
* @param y2 y-coordinate of the second point
* @return None
int8_t x, y, deltay, deltax, d;
int8_t x_dir, y_dir;
if (y1 > 63)
y1 = 63;
if (y2 > 63)
y2 = 63;
if (x1 > 101)
x1 = 101;
if (x2 > 101)
x2 = 101;
// Check if vertical line. Use more efficient vertical line function
if (x1 == x2)
Dogs102x6_verticalLineDraw(y1, y2, x1, style);
// Check if horizontal line. Use more efficient horizontal line function
else if (y1 == y2)
Dogs102x6_horizontalLineDraw(x1, x2, y1, style);
// else it is a diagonal line
else
if (x1 > x2)
x_dir = -1;
else
x_dir = 1;
if (y1 > y2)
y_dir = -1;
else
y_dir = 1;
x = x1;
y = y1;
deltay = abs(y2 - y1);
deltax = abs(x2 - x1);
if (deltax >= deltay)
d = (deltay << 1) - deltax;
while (x != x2)
Dogs102x6_pixelDraw(x, y, style);
if (d < 0)
d += (deltay << 1);
else
d += ((deltay - deltax) << 1);
y += y_dir;
x += x_dir;
else
d = (deltax << 1) - deltay;
while (y != y2)
if (d < 0)
d += (deltax << 1);
else
d += ((deltax - deltay) << 1);
x += x_dir;
y += y_dir;
* @brief Draw a circle of Radius with center at (x,y).
* Uses Bresenham's circle algorithm.
* @param x x-coordinate of the circle's center point
* @param y y-coordinate of the circle's center point
* @param radius Radius of the circle
* @param style The style of the circle
* @return None
int8_t xx, yy, ddF_x, ddF_y, f;
ddF_x = 0;
ddF_y = -(2 * radius);
f = 1 - radius;
xx = 0;
yy = radius;
Dogs102x6_pixelDraw(x + xx, y + yy, style);
Dogs102x6_pixelDraw(x + xx, y - yy, style);
Dogs102x6_pixelDraw(x - xx, y + yy, style);
Dogs102x6_pixelDraw(x - xx, y - yy, style);
Dogs102x6_pixelDraw(x + yy, y + xx, style);
Dogs102x6_pixelDraw(x + yy, y - xx, style);
Dogs102x6_pixelDraw(x - yy, y + xx, style);
Dogs102x6_pixelDraw(x - yy, y - xx, style);
while (xx < yy)
if (f >= 0)
yy--;
ddF_y += 2;
f += ddF_y;
xx++;
ddF_x += 2;
f += ddF_x + 1;
* @brief Loads an image of size = height * width, starting at (row,col).
* The first two bytes of the image should contain the width in pixels
* and the height in rows (height in rows = height in pixels/8)
* @param image[] The image to be loaded.
* @param height The number of rows in the image. Size = Rows * Columns.
* @param width The number of columns in the image. Size = Rows * Columns.
* @param row row of the image's starting location
* @param col column of the image's starting location
* @return None
// height in rows (row = 8 pixels), width in columns
uint8_t a, height, width;
width = IMAGE[0];
height = IMAGE[1];
for (a = 0; a < height; a++)
Dogs102x6_setAddress(row + a, col);
// Draw a row of the image
Dogs102x6_writeData((uint8_t*)IMAGE + 2 + a * width, width);
* @brief Clears an area of size = height * width, starting at (row,col).
* @return None
uint8_t a, b;
uint8_t cmd[] = {0x00};
for (b = 0; b < width; b++)
// clear a byte
* @brief Disable refresh
* @param mode: 0:on update request 1:immediate (default)
* @return None
//uint8_t savedmode = drawmode;
Dogs102x6_imageDraw(dogs102x6Memory, 0, 0);
//drawmode = savedmode;
drawmode = mode;
i am very new to ti microcontrollers but we are in a contest where we HAVE to use only ti components....before this i used arduino.....now i can use energia but the
lcd screen library there is for 16x2 ...
already you have provided me a alot of of help.....i'll be forever indebted if u help us just give enough help to display "hello world".on the screen
thank you
Amarnath De
What kind of errors do you get? Also, if you've never used MSP430 before... then I would like you to quickly go through the sample codes right from "Blinking of LED"
which will help you understand the structure of MSP projects. Else it would be very complicated for you to understand.
Download MSP430Ware & go through this link:
Gautam
