Experiencing error with MSP430-FET
Other Parts Discussed in Thread: MSP430F2619, MSP-FET
Hello
I'm trying to download a firmware to MSP430F2619, but CCS shows me the message: "Error initializing emulator: MSP-FET430UIF is already in use"
I'm using CCS 6.0.1.00040,
Linux Mint 17.1 (uname -an: Linux mkh 3.13.0-37-generic #64-Ubuntu SMP Mon Sep 22 21:28:38 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux).
What should I try?
    Try un-mounting & re-mounting the emulator through terminal. Does it still display the same error?
    Gautam
  • How can I do it in terminal?
    I've tried unplug and plug emulator again. but this made no effect.
  • Baranov - do you have some terminal program open (putty, etc) to try to communicate with your device?
    Despite your distro is not officially supported, I can suggest a few things to check:
    - which FET are you using? Is it a standalone box or is it embedded into a development board? Some of the built-in FETs are not supported in Linux.
    - If you have a white MSP-FET430UIF, you should have a /dev/ttyACM0 device; if you have a black MSP-FET you should see an additional /dev/ttyACM1 device.
    - if you don't see those, it is possible you do not have the device drivers properly installed. Go to the CCS install directory and run the install script as superuser:
    user@host:/opt/ti/ccsv6/install_scripts$ sudo install_drivers.sh
    - if you have already ran the scripts, perhaps there may be something wrong with the hardware of the FET itself. In this case, the last idea I have is to run lsusb and get detailed information about the device itself. For that, follow the instructions at the page below and compare the output of lsusb -D with the attached files for both the white and the black versions of MSP-FET.
    www.linuxnix.com/.../find-usb-device-details-in-linuxunix-using-lsusb-command.html
    Hope this helps,
    Rafael
    user@host:~$ lsusb
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 001 Device 003: ID 1bcf:2802 Sunplus Innovation Technology Inc.
    Bus 002 Device 003: ID 0a5c:5800 Broadcom Corp. BCM5880 Secure Applications Processor
    Bus 001 Device 004: ID 413c:2513 Dell Computer Corp. internal USB Hub of E-Port Replicator
    Bus 001 Device 005: ID 413c:2513 Dell Computer Corp. internal USB Hub of E-Port Replicator
    Bus 001 Device 006: ID 046d:c077 Logitech, Inc.
    Bus 002 Device 006: ID 2047:0014 Texas Instruments
    user@host:~$ lsusb -D /dev/bus/usb/002/006
    Device: ID 2047:0014 Texas Instruments
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass          239 Miscellaneous Device
      bDeviceSubClass         2 ?
      bDeviceProtocol         1 Interface Association
      bMaxPacketSize0         8
      idVendor           0x2047 Texas Instruments
      idProduct          0x0014
      bcdDevice            2.00
      iManufacturer           1 Texas Instruments
      iProduct                2 MSP Tools Driver
      iSerial                 3 EEF298461C001900
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength          141
        bNumInterfaces          4
        bConfigurationValue     1
        iConfiguration          4 MSP430 USB
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              100mA
        Interface Association:
          bLength                 8
          bDescriptorType        11
          bFirstInterface         0
          bInterfaceCount         2
          bFunctionClass          2 Communications
          bFunctionSubClass       2 Abstract (modem)
          bFunctionProtocol       1 AT-commands (v.25ter)
          iFunction               5 MSP Debug Interface
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         2 Communications
          bInterfaceSubClass      2 Abstract (modem)
          bInterfaceProtocol      1 AT-commands (v.25ter)
          iInterface              5 MSP Debug Interface
          CDC Header:
            bcdCDC               1.10
          CDC Call Management:
            bmCapabilities       0x00
            bDataInterface          1
          CDC ACM:
            bmCapabilities       0x02
              line coding and serial state
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  1x 64 bytes
            bInterval             255
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass        10 CDC Data
          bInterfaceSubClass      0 Unused
          bInterfaceProtocol      0
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x02  EP 2 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval             255
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval             255
          bLength                 8
          bDescriptorType        11
          bFirstInterface         2
          bInterfaceCount         2
          iFunction               6 MSP Application UART
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              6 MSP Application UART
          CDC Header:
            bcdCDC               1.10
            bmCapabilities       0x00
            bDataInterface          3
          CDC ACM:
            bmCapabilities       0x02
          CDC Union:
            bMasterInterface        2
            bSlaveInterface         3
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x83  EP 3 IN
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x04  EP 4 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval             255
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x84  EP 4 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Device Status:     0x0000
      (Bus Powered)
    user@host:~$
    user@host:~$ lsusb
    Bus 002 Device 004: ID 2047:0010 Texas Instruments
    user@host:~$ lsusb -D /dev/bus/usb/002/004
    Device: ID 2047:0010 Texas Instruments
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            2 Communications
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idProduct          0x0010
      bcdDevice            1.04
      iProduct                2 Texas Instruments MSP430-JTAG
      iSerial                 3 DFFF54F75EC6553E
        bLength                 9
        bDescriptorType         2
        wTotalLength           67
        bNumInterfaces          2
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
          CDC Header:
            bcdCDC               1.10
            bmCapabilities       0x00
            bDataInterface          1
          CDC ACM:
            bmCapabilities       0x02
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval             255
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval             255
      (Bus Powered)
    user@host:~$
