Below are shown excerpts from the .cproject from two versions of my code. They should be the same, however, version 1 is using the xml name attribute and version 2 is not. I am using ccs6.1 for both code versions, so why is one .cproject using the xml name attribute and the other is not?
Stephen
Version 1:
<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1729481631" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="6.2.11" valueType="string"/>
<targetPlatform id="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.targetPlatformRelease.293566752" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.targetPlatformRelease"/>
<builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.builderRelease.1313182938" keepEnvironmentInBuildfile="false" name="GNU Make" parallelBuildOn="true" parallelizationNumber="optimal" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.builderRelease"/>
<tool id="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.compilerRelease.1918351100" name="C2000 Compiler" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.compilerRelease">
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.LARGE_MEMORY_MODEL.1730282670" name="Use large memory model (--large_memory_model, -ml)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.LARGE_MEMORY_MODEL" value="true" valueType="boolean"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.UNIFIED_MEMORY.143387400" name="Unified memory (--unified_memory, -mt)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.UNIFIED_MEMORY" value="true" valueType="boolean"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.SILICON_VERSION.1152821061" name="Processor version (--silicon_version, -v)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.SILICON_VERSION.28" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.FLOAT_SUPPORT.945408222" name="Specify floating point support (--float_support)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.FLOAT_SUPPORT.fpu32" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_LEVEL.release.68690158" name="Optimization level (--opt_level, -O)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_LEVEL.release" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_LEVEL.off" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_FOR_SPEED.891370162" name="Speed vs. size trade-offs (--opt_for_speed, -mf)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_FOR_SPEED" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_FOR_SPEED.5" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.INCLUDE_PATH.1958204202" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.INCLUDE_PATH" valueType="includePath">
Version 2:
<option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1729481631" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="6.2.11" valueType="string"/>
<builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.builderRelease.1313182938" name="GNU Make.Release" parallelBuildOn="true" parallelizationNumber="optimal" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.exe.builderRelease"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.LARGE_MEMORY_MODEL.1730282670" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.LARGE_MEMORY_MODEL" value="true" valueType="boolean"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.UNIFIED_MEMORY.143387400" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.UNIFIED_MEMORY" value="true" valueType="boolean"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.SILICON_VERSION.1152821061" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.SILICON_VERSION.28" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.FLOAT_SUPPORT.945408222" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.FLOAT_SUPPORT" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.FLOAT_SUPPORT.fpu32" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_LEVEL.release.68690158" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_LEVEL.release" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_LEVEL.off" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_FOR_SPEED.891370162" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_FOR_SPEED" value="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.OPT_FOR_SPEED.5" valueType="enumerated"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.INCLUDE_PATH.1958204202" superClass="com.ti.ccstudio.buildDefinitions.C2000_6.2.compilerID.INCLUDE_PATH" valueType="includePath">
