Encounter an error when importing CCS v3.3 project to CCS v6
Other Parts Discussed in Thread: CCSTUDIO
I am trying to import a CCS v3.3 project to CCS v6 and I follows steps: file->import->legacy CCSv3.3-> next-> finish. But it finally pops a windows says an error occurs and it is in the log file. Is there anyone can give me a help?The log file is shown below,Thanks.
!ERROR: java.lang.NullPointerException
 at com.ti.ccstudio.project.core.internal.initializer.CCSConfigurationInitializer.doInitializeConfiguration(CCSConfigurationInitializer.java:167)
 at com.ti.common.project.core.internal.initializer.AConfigurationInitializer.internalInitializeConfiguration(AConfigurationInitializer.java:247)
 at com.ti.common.project.core.internal.initializer.AConfigurationInitializer.internalInitializeConfiguration(AConfigurationInitializer.java:232)
 at com.ti.common.project.core.internal.initializer.AConfigurationInitializer.initialize(AConfigurationInitializer.java:71)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.initializeBuildConfigurations(LegacyProjectImporter.java:540)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.createManagedMakeProject(LegacyProjectImporter.java:459)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.doRun(LegacyProjectImporter.java:268)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.access$0(LegacyProjectImporter.java:229)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter$1.run(LegacyProjectImporter.java:212)
 at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
 at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2327)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.run(LegacyProjectImporter.java:210)
 at com.ti.ccstudio.project.ui.internal.wizards.importlegacy.ImportLegacyProjectWizard$2.run(ImportLegacyProjectWizard.java:144)
 at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
 at org.eclipse.cdt.managedbuilder.internal.core.Configuration.getEditableBuilder(Configuration.java:2351)
 at org.eclipse.cdt.managedbuilder.internal.core.Configuration.getBuildData(Configuration.java:2344)
 at org.eclipse.cdt.managedbuilder.internal.dataprovider.BuildConfigurationData.getBuildData(BuildConfigurationData.java:147)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescription$1.getChildren(CConfigurationDescription.java:300)
 at org.eclipse.cdt.internal.core.settings.model.ProxyProvider.fillCache(ProxyProvider.java:60)
 at org.eclipse.cdt.internal.core.settings.model.ProxyProvider.getProxy(ProxyProvider.java:84)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescription.getTargetPlatformSetting(CConfigurationDescription.java:534)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationSpecSettings.getReferenceDelta(CConfigurationSpecSettings.java:929)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationSpecSettings.checkReconsile(CConfigurationSpecSettings.java:624)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationSpecSettings.reconcileExtensionSettings(CConfigurationSpecSettings.java:672)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationSpecSettings.copyExtensionInfo(CConfigurationSpecSettings.java:887)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationSpecSettings.<init>(CConfigurationSpecSettings.java:197)
 at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.<init>(CConfigurationDescriptionCache.java:163)
 at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.<init>(CProjectDescription.java:309)
 at org.eclipse.cdt.internal.core.settings.model.SetCProjectDescriptionOperation.executeOperation(SetCProjectDescriptionOperation.java:93)
 at org.eclipse.cdt.internal.core.model.CModelOperation.execute(CModelOperation.java:341)
 at org.eclipse.cdt.internal.core.model.CModelOperation.run(CModelOperation.java:607)
 at org.eclipse.cdt.internal.core.model.CModelOperation.runOperation(CModelOperation.java:638)
 at org.eclipse.cdt.internal.core.settings.model.AbstractCProjectDescriptionStorage.setProjectDescription(AbstractCProjectDescriptionStorage.java:203)
 at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionStorageManager.setProjectDescription(CProjectDescriptionStorageManager.java:149)
 at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.setProjectDescription(CProjectDescriptionManager.java:873)
 at org.eclipse.cdt.managedbuilder.internal.core.BuildSettingsUtil.checkApplyDescription(BuildSettingsUtil.java:211)
 at org.eclipse.cdt.managedbuilder.internal.core.BuildSettingsUtil.checkApplyDescription(BuildSettingsUtil.java:198)
 at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.updateBuildInfo(ManagedBuildManager.java:1404)
 at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.saveBuildInfo(ManagedBuildManager.java:1363)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.processDependencies(LegacyProjectImporter.java:554)
 at com.ti.ccstudio.project.core.internal.legacy.LegacyProjectImporter.createManagedMakeProject(LegacyProjectImporter.java:461)
  • I am far from being an expert on this issue, but it looks like a CCS bug.  Are you using the newest CCS version (CCSv6.1)?
    Personally, I would try CCSv5 and work my way up to CCSv6.   However, if you don't want to go through all the trouble, you can wait for a TI expert to help you.
    Stephen
  • If you are using linux, take a look at e2e.ti.com/.../170159.
  • Migrating directly from CCS 3.3 to CCSv6 is quite a jump. Although many projects will import without issues, I would not be surprised if more complex projects do not import seamlessly.
    Is this a BIOS project? Depending on the size and complexity of the project, rather than spend time addressing migration issues, a better option (or at least better time spent) would be to create a new project in CCSv6 and manually copy over your source files and project settings.
