gmake not found
Thank you for the reply,but the compiler ver. doesn't seem to be solution to my problem.
I installed the 3.2.1 compiler, have the 90days ccsv5 license now, but the pb remained, the same as in ccsv6, gmake not found in path.
I even uninstalled the antivirus just to see if it would work,but it didn t,same error about gmake path and the out file.
Could you please provide some support ?
Please let me know if it s necessary to provide some more details.
Thank you.
Have a good day,
Dorina
    Could you please provide more details about the project you are building and the full error message. The following details will be helpful:
    - In which version(s) of CCS do you see the build error?
    - Which project are you importing/building? Is it a TI example project or your own custom project? Could you try a TI example if you have not already
    - Does the same build error occur with multiple different projects?
    - For one of the failed builds, please copy the full output of the CCS build console to a text file and attach it here.
