DSS/Rhino cannot launch: java.net.BindException: Address already in use: bind
Other Parts Discussed in Thread: CCSTUDIO
With CCS 5.5 the following message shows when trying to run DSS:
C:\ti\ccsv5\ccs_base\scripting\bin>dss.bat -dss.debug "Breakpoints - Copy.js"
2015-04-16 20:26:05.701:WARN:oejuc.AbstractLifeCycle:FAILED SelectChannelConnector@0.0.0.0:80: java.net.BindException: Address already in use: bind
        at sun.nio.ch.Net.bind(Native Method)
        at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
        at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
        at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182)
        at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311)
        at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260)
        at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
        at org.eclipse.jetty.server.Server.doStart(Server.java:273)
        at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113)
        at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
        at java.security.AccessController.doPrivileged(Native Method)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
        at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
2015-04-16 20:26:05.740:WARN:oejuc.AbstractLifeCycle:FAILED org.eclipse.jetty.server.Server@135da43: java.net.BindException: Address already in use: bind
Particularly the message reads “address already in use”. At the end of the message (2~3 seconds) rhino debug window briefly shows, then disappears
Test 1: the problem has nothing to do with .js file. Even if I supply a non-existent .js file to DSS.BAT, the same message shows.
Test 2: the error message still show after terminating all ccstudio.exe sessions (not any left in Windows task manager).
Matt
