Hi ,
Am using c6000_7.4.7 compiler and am trying to build using command line.
when i use this compiler options --preproc_with_compile * .obj is not generated, I don't know if its generated and deleted but during linking the linker is not able find the .obj. I have verified the following thing
abc.obj : ../src/abc.cpp compiler.opt
$(CC) $(CFLAGS) --preproc_with_compile --preproc_dependency="abc.pp $<
the above rule dosnt generate .obj but the below one does generate *.obj and am able to link.
$(CC) $(CFLAGS) -c $<
what could be the possible error.Any leads!! Thanks in advance!!!
