Other Parts Discussed in Thread: CCSTUDIO
Hi, I try to profile my project on HW.
and it is not work. please support,
(I have CCS3.3 and CCS Version: 5.5.0.00077 )
at org.eclipse.cdt.internal.ui.text.c.hover.CEditorTextHoverProxy.getHoverInfo2(CEditorTextHoverProxy.java:84)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextViewerHoverManager.java:166)
!ENTRY com.ti.ccstudio.debug 1 0 2015-05-17 11:37:30.513
!MESSAGE DS_ERROR: IcePick_C_0: Power Failure on Target CPU
!ENTRY com.ti.ccstudio.debug 1 0 2015-05-17 11:37:30.622
!MESSAGE DS_ERROR: IcePick_C_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY com.ti.ccstudio.debug 1 0 2015-05-17 11:37:32.388
!MESSAGE DS_ERROR: C64XP_0: Power Failure on Target CPU
!ENTRY com.ti.ccstudio.debug 1 0 2015-05-17 11:37:41.248
!MESSAGE DS_ERROR: C64XP_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY org.eclipse.cdt.dsf.ui 2 0 2015-05-17 12:03:46.982
!MESSAGE Unable to locate file: /tmp/TI_MKLIBxaGIwi/SRC/sqrt.c
!ENTRY UIA_Session_View/com.ti.dvt.uia.UtilUI 1 1 2015-05-17 12:07:28.273
!MESSAGE Connecting
!STACK 0
java.lang.Throwable
