Code Compose Studio 6
How you get the search window results show up.
I tried Window  -> Show View -> search
but not luck
I tried to search an exiting variable  and function name the search window started, but no search results.shown.
On Standard Eclipse I do not have this issue.
    I assume you are using File Search or C/C++ Search, is that correct?
    Try resetting the perspective (menu Window->Reset Perspective) and then try the search again to see if that helps. If it does not, please post screenshots of your search window as well the whole CCS workbench.
  • Yes File Search and C/C++ search.
    The Reset Perspective solved the issue.
    Thank you.
