Other Parts Discussed in Thread: CC2538, ENERGYTRACE
I've downloaded the latest CCS for linux 6.1.0.00104 - and the install fails on Ubuntu 15.04
I've made sure that everything is up to date, and the libraries needed are available. I've downloaded the stand alone installation and have the same problem:
06/13/2015 12:57:30(GMT) - extract - successfully unzipped /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip
06/13/2015 12:57:30(GMT) - findLauncher - launcher version = 1.3.0.v20130327-1440
06/13/2015 12:57:30(GMT) - installEclipse - CCS_INFO: eclipse does not exist
06/13/2015 12:57:30(GMT) - installEclipse - using /home/stephen/ti/ccsv6/eclipse/jre/bin/java
06/13/2015 12:57:30(GMT) - installEclipse - "/home/stephen/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.r
etrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/cfg" "-Dosg
i.instance.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/ws" -jar "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -applicati
on org.eclipse.equinox.p2.director -repository "file:/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equi
nox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.e
clipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -d
estination "/home/stephen/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/home/stephen/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arc
h x86 -roaming
06/13/2015 12:57:30(GMT) - runEclipseApp - running cmd "/home/stephen/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.fil
etransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/
cfg" "-Dosgi.instance.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/ws" -jar "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar"
-application org.eclipse.equinox.p2.director -repository "file:/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.e
clipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.
group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.featu
re.group -destination "/home/stephen/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/home/stephen/ti/ccsv6/eclipse/" -p2.os linux -p2.ws
gtk -p2.arch x86 -roaming
06/13/2015 12:58:10(GMT) - runEclipseApp - FAILED 0: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400.
Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802.
Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143.
Installing org.eclipse.cdt.feature.group 8.5.0.201409172108.
Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108.
Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905.
Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651.
Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r.
Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf.
Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108.
Installing org.eclipse.rse.feature.group 3.5.0.201406091451.
Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108.
Operation completed in 27845 ms.
I've attached the entire install log, any help appreciated.
06/13/2015 12:56:19(GMT) - Validation::linuxLibChecks - LD_LIBRARY_PATH == :/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/tcl/lib
06/13/2015 12:56:19(GMT) - Validation::linuxLibChecks - tempLD == {}
06/13/2015 12:56:19(GMT) - Validation::linuxLibChecks - cmd = /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/dependency-checker/check_depends.sh --ldpath
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - ran /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/dependency-checker/check_depends.sh --ldpath :Installed versions of glibc and glibcxx: GLIBC_2.18, N/A
Required versions of glibc and glibcxx: GLIBC_2.11, GLIBCXX_3.4.15
Checking availability of libraries in ext-depends.txt ...
Failed to find lib: libgcrypt.so.11
Done.
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - Line: Installed versions of glibc and glibcxx: GLIBC_2.18, N/A
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - Line: Required versions of glibc and glibcxx: GLIBC_2.11, GLIBCXX_3.4.15
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - Line: Checking availability of libraries in ext-depends.txt ...
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - Line: Failed to find lib: libgcrypt.so.11
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - Val: libgcrypt.so.11
06/13/2015 12:56:20(GMT) - Validation::linuxLibChecks - Line: Done.
06/13/2015 12:56:59(GMT) - Util::httpCopy - http::config now: -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.5}
06/13/2015 12:56:59(GMT) - Util::httpCopy - Downloading /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/apps_6.1.0.json from http://software-dl.ti.com/ccs/non-esd/ccs_appcenter/apps_6.1.0.json
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Server: Apache
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Last-Modified: Thu, 07 May 2015 21:52:38 GMT
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= ETag: "6621-51584ee187580"
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Accept-Ranges: bytes
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Content-Length: 26145
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Content-Type: application/json
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Date: Sat, 13 Jun 2015 12:56:59 GMT
06/13/2015 12:56:59(GMT) - Util::httpCopy - httpstate= Connection: close
06/13/2015 12:57:28(GMT) - writeDebugFile -
Install Information:
06/13/2015 12:57:28(GMT) - writeDebugFile - Install Version: 6.1.0.00104
06/13/2015 12:57:28(GMT) - writeDebugFile - Install Source : /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux
06/13/2015 12:57:28(GMT) - writeDebugFile - Install Temp : /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd
06/13/2015 12:57:28(GMT) - writeDebugFile - Install Type : Offline
06/13/2015 12:57:28(GMT) - writeDebugFile - OS : Linux
06/13/2015 12:57:28(GMT) - writeDebugFile - OS Version : 3.19.0-20-generic
06/13/2015 12:57:28(GMT) - writeDebugFile - OS Platform : unix
06/13/2015 12:57:28(GMT) - writeDebugFile - : 64-bit
06/13/2015 12:57:28(GMT) - writeDebugFile - User ID : stephen
06/13/2015 12:57:28(GMT) - writeDebugFile - Timezone : EDT
06/13/2015 12:57:28(GMT) - writeDebugFile - IPAddress : 127.0.1.1
06/13/2015 12:57:28(GMT) - writeDebugFile - Update/Rerun : 0
06/13/2015 12:57:28(GMT) - writeDebugFile - Command line : installersrc /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux installertmp /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd buildid 6.1.0.00104 installer /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/ccs_setup_6.1.0.00104.bin bitness 64-bit
06/13/2015 12:57:28(GMT) - writeDebugFile - CCS_WARNING: {Failed to locate 32-bit system libraries required for CCS operation:
} { libgcrypt.so.11} {
For more information on how to install these, please visit:
http://processors.wiki.ti.com/index.php/Linux_Host_Support_CCSv6}
Product families selected:
06/13/2015 12:57:28(GMT) - writeDebugFile - PF_MSP430
06/13/2015 12:57:28(GMT) - writeDebugFile - PF_C28
06/13/2015 12:57:28(GMT) - writeDebugFile - PF_WIRELESS
06/13/2015 12:57:28(GMT) - writeDebugFile - PF_DIGITAL_POWER
Components to be installed:
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_MSP430
06/13/2015 12:57:28(GMT) - writeDebugFile - EMU_MSP430
06/13/2015 12:57:28(GMT) - writeDebugFile - EMU_MSP432
06/13/2015 12:57:28(GMT) - writeDebugFile - EMU_TI
06/13/2015 12:57:28(GMT) - writeDebugFile - MSP430_CGT_HELP
06/13/2015 12:57:28(GMT) - writeDebugFile - CGT_DEFAULTLIBS_MSP430
06/13/2015 12:57:28(GMT) - writeDebugFile - DMED
06/13/2015 12:57:28(GMT) - writeDebugFile - ARM_CGT_HELP
06/13/2015 12:57:28(GMT) - writeDebugFile - CGT_DEFAULTLIBS_TMS470
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_ARM
06/13/2015 12:57:28(GMT) - writeDebugFile - GCC_ARM_COMPILER
06/13/2015 12:57:28(GMT) - writeDebugFile - C2000_CGT_HELP
06/13/2015 12:57:28(GMT) - writeDebugFile - CGT_DEFAULTLIBS_C2800
06/13/2015 12:57:28(GMT) - writeDebugFile - DEV_SUPPORT_CC2538
06/13/2015 12:57:28(GMT) - writeDebugFile - DEV_SUPPORT_CC26XX
06/13/2015 12:57:28(GMT) - writeDebugFile - DEV_SUPPORT_UCD31XX
06/13/2015 12:57:28(GMT) - writeDebugFile - JRE
06/13/2015 12:57:28(GMT) - writeDebugFile - P2APP
06/13/2015 12:57:28(GMT) - writeDebugFile - ECLIPSE
06/13/2015 12:57:28(GMT) - writeDebugFile - ECLIPSECORE
06/13/2015 12:57:28(GMT) - writeDebugFile - P2TOOLS
06/13/2015 12:57:28(GMT) - writeDebugFile - GMF
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_MAIN
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_WORKFLOW
06/13/2015 12:57:28(GMT) - writeDebugFile - DVT_COMMON
06/13/2015 12:57:28(GMT) - writeDebugFile - DVT_UIA
06/13/2015 12:57:28(GMT) - writeDebugFile - DVT_VIA_CCS
06/13/2015 12:57:28(GMT) - writeDebugFile - XULRUNNER
06/13/2015 12:57:28(GMT) - writeDebugFile - INSTALLER
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_CHROME
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_TOOLS_COMMON
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_GC
06/13/2015 12:57:28(GMT) - writeDebugFile - TARGET_CONTENT_CORE
06/13/2015 12:57:28(GMT) - writeDebugFile - DS
06/13/2015 12:57:28(GMT) - writeDebugFile - DS_FLASH
06/13/2015 12:57:28(GMT) - writeDebugFile - DVT_ENERGYTRACE
06/13/2015 12:57:28(GMT) - writeDebugFile - IDE_C2000
06/13/2015 12:57:28(GMT) - writeDebugFile - EMU_C2000_FLASH
06/13/2015 12:57:28(GMT) - writeDebugFile - GREE_C2000_SUPPORT
06/13/2015 12:57:28(GMT) - writeDebugFile - DVT_TRACE
06/13/2015 12:57:28(GMT) - writeDebugFile - TIVA_STELLARIS_DRIVERS
Apps to be installed when CCS starts up:
06/13/2015 12:57:28(GMT) - writeDebugFile - iu=com.ti.gcc.msp430.linux.feature.group
06/13/2015 12:57:28(GMT) - writeDebugFile - repo=http://software-dl.ti.com/ccs/esd/msp430/
06/13/2015 12:57:28(GMT) - writeDebugFile - iu=com.ti.msp430.msp430ware.linux.feature.group
06/13/2015 12:57:28(GMT) - writeDebugFile - repo=http://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/MSP430ware/update/latest/
06/13/2015 12:57:28(GMT) - writeDebugFile - repo=http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v6.1/linux32/browserRepo
06/13/2015 12:57:28(GMT) - getprefix - installdir for ARM_CGT_HELP: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for C2000_CGT_HELP: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for C5500_CGT_HELP: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for C6000_CGT_HELP: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_DOC. Using Defaults.
06/13/2015 12:57:28(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_LAUNCHER. Using Defaults.
06/13/2015 12:57:28(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_UTILS. Using Defaults.
06/13/2015 12:57:28(GMT) - getprefix - installdir for DVT_COMMON: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for DVT_ENERGYTRACE: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for DVT_TRACE: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for DVT_UIA: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for DVT_VIA_CCS: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for ECLIPSE: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for EMU_SD: /home/stephen/ti/ccsv6/ccs_base
06/13/2015 12:57:28(GMT) - getprefix - installdir for GMF: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_ARM: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_C2000: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_C5500: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_C6000: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_CHROME: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_GC: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_MAIN: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_MSP430: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_TOOLS_COMMON: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for IDE_WORKFLOW: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for KEYSTONE1: /home/stephen/ti/ccsv6/ccs_base
06/13/2015 12:57:28(GMT) - getprefix - installdir for KEYSTONE2: /home/stephen/ti/ccsv6/ccs_base
06/13/2015 12:57:28(GMT) - getprefix - installdir for MSP430_CGT_HELP: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for P2APP: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getprefix - installdir for P2TOOLS: /home/stephen/ti/ccsv6/
06/13/2015 12:57:28(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni TARGETDB_DEF_PROPS. Using Defaults.
06/13/2015 12:57:28(GMT) - getprefix - installdir for TARGET_CONTENT_CORE: /home/stephen/ti/ccsv6/..
06/13/2015 12:57:28(GMT) - Util::getProperty - No /home/stephen/ti/ccsv6/eclipse/ccs.properties file found
06/13/2015 12:57:28(GMT) - ProgressPane::Run - non-threaded
06/13/2015 12:57:28(GMT) - ProgressPane::Run - RunInstall /home/stephen/ti/ccsv6/eclipse/ccs_config.xml 0 0 0 0 /home/stephen/ti/ccsv6/install_logs/ccs_setup_6.1.0.00104_install.log ::progressPane0 -1
06/13/2015 12:57:28(GMT) - RunMain - Started with params pConfigFile=/home/stephen/ti/ccsv6/eclipse/ccs_config.xml pProfiling=0 pUpdate=0 logfile=/home/stephen/ti/ccsv6/install_logs/ccs_setup_6.1.0.00104_install.log progress=::progressUpdate0
06/13/2015 12:57:28(GMT) - RunMain - encoding = utf-8
06/13/2015 12:57:28(GMT) - readConfigFile - Start installing components:
06/13/2015 12:57:28(GMT) - readConfigFile - read config file /home/stephen/ti/ccsv6/eclipse/ccs_config.xml
06/13/2015 12:57:28(GMT) - readConfigFile - found /home/stephen/ti/ccsv6/eclipse/ccs_config.xml
06/13/2015 12:57:28(GMT) - readConfigFile - Parsing Root Elements
06/13/2015 12:57:28(GMT) - readConfigFile - Done Parsing
06/13/2015 12:57:28(GMT) - readConfigFile - CCSDIR=/home/stephen/ti/ccsv6
06/13/2015 12:57:28(GMT) - readConfigFile - EclipseDir=/home/stephen/ti/ccsv6/eclipse
06/13/2015 12:57:28(GMT) - readConfigFile - InstallDir=/home/stephen/ti
06/13/2015 12:57:28(GMT) - readConfigFile - TempDir=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd
06/13/2015 12:57:28(GMT) - readConfigFile - platform=linux
06/13/2015 12:57:28(GMT) - readConfigFile - LocalBaseRepository=/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo
06/13/2015 12:57:28(GMT) - readConfigFile - baserepourl=/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo
06/13/2015 12:57:28(GMT) - readConfigFile - featureurl=/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/featurerepo
06/13/2015 12:57:28(GMT) - readConfigFile - LocalRepository_Exists=1
06/13/2015 12:57:28(GMT) - readConfigFile - componentinstaller=false
06/13/2015 12:57:28(GMT) - readConfigFile - eclipseexe=eclipse
06/13/2015 12:57:28(GMT) - readConfigFile - in install components
06/13/2015 12:57:28(GMT) - readUserProfile - userprofile =
06/13/2015 12:57:28(GMT) - downloadIfRequired - deleted /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/jre_root.gtk.linux.x86_1.7.0.60
06/13/2015 12:57:28(GMT) - downloadIfRequired - copying /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/featurerepo/binary/jre_root.gtk.linux.x86_1.7.0.60
06/13/2015 12:57:28(GMT) - downloadIfRequired - copied /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/featurerepo/binary/jre_root.gtk.linux.x86_1.7.0.60 to /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/jre_root.gtk.linux.x86_1.7.0.60
06/13/2015 12:57:28(GMT) - downloadIfRequired - File /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/jre_root.gtk.linux.x86_1.7.0.60 already exists. Not attempting to download
06/13/2015 12:57:28(GMT) - extract - cmd = "unzip" -q -o -d "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd" "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/jre_root.gtk.linux.x86_1.7.0.60"
06/13/2015 12:57:29(GMT) - extract - successfully unzipped /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/jre_root.gtk.linux.x86_1.7.0.60
06/13/2015 12:57:29(GMT) - extract - cmd = "unzip" -q -o -d "/home/stephen/ti/ccsv6/eclipse" "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/downloads/jre_1.7.0_60.zip"
06/13/2015 12:57:30(GMT) - extract - successfully unzipped /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/downloads/jre_1.7.0_60.zip
06/13/2015 12:57:30(GMT) - installEclipse - CCS_INFO: JAVA_TOOL_OPTIONS was set to -javaagent:/usr/share/java/jayatanaag.jar , temporarily unsetting it.
06/13/2015 12:57:30(GMT) - downloadIfRequired - File /home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip already exists. Not attempting to download
06/13/2015 12:57:30(GMT) - extract - cmd = "unzip" -q -o -d "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd" "/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip"
06/13/2015 12:57:30(GMT) - installEclipse - "/home/stephen/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/cfg" "-Dosgi.instance.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/ws" -jar "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "/home/stephen/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/home/stephen/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arch x86 -roaming
06/13/2015 12:57:30(GMT) - runEclipseApp - running cmd "/home/stephen/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/cfg" "-Dosgi.instance.area=/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/ws" -jar "/tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/home/stephen/Downloads/ccs/CCS6.1.0.00104_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "/home/stephen/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/home/stephen/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arch x86 -roaming
Picked up JAVA_TOOL_OPTIONS:
06/13/2015 12:58:10(GMT) - runEclipseApp - Running again
06/13/2015 12:58:22(GMT) - runEclipseApp - FAILED 1: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1844 ms.
06/13/2015 12:58:22(GMT) - runEclipseApp - Running again
06/13/2015 12:58:35(GMT) - runEclipseApp - FAILED 2: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1938 ms.
06/13/2015 12:58:35(GMT) - runEclipseApp - Running again
06/13/2015 12:58:47(GMT) - runEclipseApp - FAILED 3: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1920 ms.
06/13/2015 12:58:47(GMT) - runEclipseApp - Running again
06/13/2015 12:59:00(GMT) - runEclipseApp - FAILED 4: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1852 ms.
06/13/2015 12:59:00(GMT) - runEclipseApp - Running again
06/13/2015 12:59:13(GMT) - runEclipseApp - FAILED 5: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 2064 ms.
06/13/2015 12:59:13(GMT) - runEclipseApp - Running again
06/13/2015 12:59:25(GMT) - runEclipseApp - FAILED 6: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1884 ms.
06/13/2015 12:59:25(GMT) - runEclipseApp - Running again
06/13/2015 12:59:38(GMT) - runEclipseApp - FAILED 7: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1838 ms.
06/13/2015 12:59:38(GMT) - runEclipseApp - Running again
06/13/2015 12:59:50(GMT) - runEclipseApp - FAILED 8: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1855 ms.
06/13/2015 12:59:50(GMT) - runEclipseApp - Running again
06/13/2015 13:00:03(GMT) - runEclipseApp - FAILED 9: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 2012 ms.
06/13/2015 13:00:03(GMT) - runEclipseApp - Running again
06/13/2015 13:00:15(GMT) - runEclipseApp - FAILED 10: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1859 ms.
06/13/2015 13:00:15(GMT) - runEclipseApp - Running again
06/13/2015 13:00:28(GMT) - runEclipseApp - FAILED 11: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 2042 ms.
06/13/2015 13:00:28(GMT) - runEclipseApp - Running again
06/13/2015 13:00:41(GMT) - runEclipseApp - FAILED 12: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1847 ms.
06/13/2015 13:00:41(GMT) - runEclipseApp - Running again
06/13/2015 13:00:53(GMT) - runEclipseApp - FAILED 13: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1865 ms.
06/13/2015 13:00:53(GMT) - runEclipseApp - Running again
06/13/2015 13:01:06(GMT) - runEclipseApp - FAILED 14: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 2050 ms.
06/13/2015 13:01:06(GMT) - runEclipseApp - Running again
06/13/2015 13:01:18(GMT) - runEclipseApp - FAILED 15: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1869 ms.
06/13/2015 13:01:18(GMT) - runEclipseApp - Running again
06/13/2015 13:01:31(GMT) - runEclipseApp - FAILED 16: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 2027 ms.
06/13/2015 13:01:31(GMT) - runEclipseApp - Running again
06/13/2015 13:01:44(GMT) - runEclipseApp - FAILED 17: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 2093 ms.
06/13/2015 13:01:44(GMT) - runEclipseApp - Running again
06/13/2015 13:01:56(GMT) - runEclipseApp - FAILED 18: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1848 ms.
06/13/2015 13:01:56(GMT) - runEclipseApp - Running again
06/13/2015 13:02:09(GMT) - runEclipseApp - FAILED 19: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
Operation completed in 1864 ms.
06/13/2015 13:02:09(GMT) - runEclipseApp - Running again
06/13/2015 13:02:09(GMT) - runEclipseApp - FAILED 20: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400.
06/13/2015 13:02:09(GMT) - runEclipseApp - Can't run again.
06/13/2015 13:02:09(GMT) - installEclipse - Eclipse installation failed have to exit here
06/13/2015 13:02:09(GMT) - installEclipse - CCS_ERROR: Failed to install eclipse. Cannot recover from this error.
06/13/2015 13:02:09(GMT) - installEclipse - new state: feature registered
06/13/2015 13:02:09(GMT) - checkStatus - CCS_ERROR: Installer failed to install org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group correctly.
Please submit these logs to TI for analysis using the next dialog.
You may also visit the TI Online CCS support form for additional help.
The install logs are located in: /home/stephen/ti/ccsv6/install_logs.
06/13/2015 13:02:09(GMT) - checkStatus - file does not exist /tmp/ccs_f255feb0-b099-4b70-5d22-4ad00fbbd0cd/eclipse/ws/.metadata/.log
06/13/2015 13:02:09(GMT) - checkStatus - saving /home/stephen/ti/ccsv6/install_logs_20150611180650
06/13/2015 13:02:09(GMT) - checkStatus - saving /home/stephen/ti/ccsv6/install_logs_20150613085728
06/13/2015 13:02:09(GMT) - checkStatus - CCS_ERROR: Code Composer Studio v6 installation failed.
