Other Parts Discussed in Thread: TMS320F28335, UNIFLASH
hello,
i having some problem related to XDS100v2 and controller TMS320F28335
[16:52:41] C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
[16:52:41] ERROR >> C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:52:41] ERROR >> C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:52:41] ERROR >> C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:52:41] ERROR >> C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1 at (ST1&~(0x0100)) [f28335.gel:312] at C28x_Mode() [f28335.gel:38] at OnReset(1) .
[16:52:42] C28xx: Calculating checksum...
[16:52:42] ERROR >> C28xx: Flash Programmer: Error calculating checksum. Device is locked or not connected. Operation cancelled.
[16:52:42] Flash operation CalculateChecksum failed on core Texas Instruments XDS100v2 USB Emulator/C28xx .
[16:53:57] ERROR >> C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:53:57] ERROR >> C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:53:57] ERROR >> C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:53:57] ERROR >> C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1 at (ST1&~(0x0100)) [f28335.gel:312] at C28x_Mode() [f28335.gel:38] at OnReset(1) .
[16:53:57] C28xx: Calculating checksum...
[16:53:58] ERROR >> C28xx: Flash Programmer: Error calculating checksum. Device is locked or not connected. Operation cancelled.
[16:53:58] Flash operation CalculateChecksum failed on core Texas Instruments XDS100v2 USB Emulator/C28xx .
[16:54:34] ERROR >> C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:54:34] ERROR >> C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:54:34] ERROR >> C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.73.0)
[16:54:34] ERROR >> C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1 at (ST1&~(0x0100)) [f28335.gel:312] at C28x_Mode() [f28335.gel:38] at OnReset(1) .
[16:54:35] C28xx: Starting Frequency Test, please wait...
[16:54:35] ERROR >> C28xx: Flash Programmer: Error starting frequency test. Device is locked or not connected. Operation cancelled.
[16:54:35] Flash operation FrequencyTest failed on core Texas Instruments XDS100v2 USB Emulator/C28xx .
Neeraj Deshmukh
