CCSv6 refactor: How to add structure name to variable after making a variable a structure member.
Guru 20045 points
I added a group of static variables to a structure type.  Is there a way to easily add the structure name to the variables by using refactor?
Stephen
  • Stephen,
    If I understood correctly, you originally had a variable "var" and afterwards moved its definition inside a structure "str". Now you want to rename all instances of "var" with "str.var", right?
    If you right click on the variable name "var" and select Refactor --> Rename does that work?
    If not, I don't think this can be done easily.
    Rafael
  • That's correct.   When I enter, for example, str.var in the New Name dialog, a " 'str.var' is not a valid identifier" error shows  up in the dialog box
    I guess that type of refactoring doesn't work.
    Thanks.
    Stephen
