Other Parts Discussed in Thread: ENERGIA
Am trying out CCS Cloud to program my MSP432 LP (as Energia has simply stopped working - I just get unhelpful "Upload Failed" messages now).
I cannot upload via CCS Cloud either - I get Flashing Failed whenever I try to flash the LP.
Can anyone suggest why, or what to do to fix this problem?
2015-10-14T01:27:36.802Z - info: Staring directory : /Users/macmini/TICloudAgent/src source=unknown
2015-10-14T01:27:36.804Z - info: Starting Agent! source=unknown
2015-10-14T01:27:36.814Z - info: Module( Agent )->Web socket server started! source=unknown
2015-10-14T01:27:36.815Z - info: Discovered Module : DS source=unknown
2015-10-14T01:27:36.818Z - info: Discovered Module : File source=unknown
2015-10-14T01:27:36.821Z - info: Discovered Module : Flash source=unknown
2015-10-14T01:27:36.859Z - info: Discovered Module : Serial source=unknown
2015-10-14T01:27:36.863Z - info: Discovered Module : TargetSupport source=unknown
2015-10-14T01:27:36.972Z - info: Module( Agent )->Exec Command : listCommands:1 source=unknown
2015-10-14T01:27:36.972Z - info: Module( Agent )->Ret Command ( response) : listCommands : 1 source=unknown
2015-10-14T01:27:37.000Z - info: Module( Agent )->Exec Command : addConfigProperty:2 source=unknown
2015-10-14T01:27:37.000Z - info: Setting property cloudAgentInstallerServerURL : http://dev.ti.com/ticloudagentinstaller source=unknown
2015-10-14T01:27:37.001Z - info: Module( Agent )->Ret Command ( response) : addConfigProperty : 2 source=unknown
2015-10-14T01:27:37.432Z - info: Module( Agent )->Exec Command : createSubModule:3 source=unknown
2015-10-14T01:27:37.433Z - info: Module( Agent )->Creating Sub Module : File source=unknown
2015-10-14T01:27:37.433Z - info: Module( File )->Web socket server started! source=unknown
2015-10-14T01:27:37.433Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 3 source=unknown
2015-10-14T01:27:37.498Z - info: Module( File )->Exec Command : listCommands:1 source=unknown
2015-10-14T01:27:37.499Z - info: Module( File )->Ret Command ( response) : listCommands : 1 source=unknown
2015-10-14T01:27:38.067Z - info: Module( File )->Exec Command : write:2 source=unknown
2015-10-14T01:27:38.069Z - info: Module( File )->Ret Command ( response) : write : 2 source=unknown
2015-10-14T01:27:38.093Z - info: Module( Agent )->Exec Command : createSubModule:4 source=unknown
2015-10-14T01:27:38.093Z - info: Module( Agent )->Creating Sub Module : TargetSupport source=unknown
2015-10-14T01:27:38.269Z - info: Overridden Proxy = source=unknown
2015-10-14T01:27:38.271Z - info: Creating db dir : /Users/macmini/.ti/TICloudAgent/db source=unknown
2015-10-14T01:27:38.272Z - info: Creating loaders dir : /Users/macmini/.ti/TICloudAgent/loaders source=unknown
2015-10-14T01:27:38.272Z - info: Could not open installed.json : Error: ENOENT, no such file or directory '/Users/macmini/.ti/TICloudAgent/db/installed.json' source=unknown
2015-10-14T01:27:38.272Z - info: Could not open targets.json : Error: ENOENT, no such file or directory '/Users/macmini/.ti/TICloudAgent/db/targets.json' source=unknown
2015-10-14T01:27:38.278Z - info: Module( TargetSupport )->Web socket server started! source=unknown
2015-10-14T01:27:38.278Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 4 source=unknown
2015-10-14T01:27:38.346Z - info: Module( TargetSupport )->Exec Command : listCommands:1 source=unknown
2015-10-14T01:27:38.347Z - info: Module( TargetSupport )->Ret Command ( response) : listCommands : 1 source=unknown
2015-10-14T01:27:38.378Z - info: Module( TargetSupport )->Exec Command : add:2 source=unknown
2015-10-14T01:27:38.378Z - info: Getting Install Info: http://dev.ti.com/ticloudagentinstaller/ticloudagentinstaller/getInstallInfo?os=osx&deviceID=msp432p401r&connectionID=TIXDS110_Connection source=unknown
2015-10-14T01:27:38.379Z - info: Looking up proxy settings for url http://dev.ti.com/ticloudagentinstaller source=unknown
2015-10-14T01:27:38.515Z - info: installer.js using proxy: source=unknown
2015-10-14T01:27:39.666Z - info: Additional packages need to be installed to support /Users/macmini/.ti/TICloudAgent/tmp/ti_cloud_storage/MSP432P401R.ccxml. Starting Install Process.
source=unknown
2015-10-14T01:27:39.667Z - info: Installing Components: [{"DSLite":{"type":"files","path":"loaders","name":"DSLite"},"MSP432":{"type":"files","path":"loaders","name":"MSP432"}}] source=unknown
2015-10-14T01:27:39.668Z - info: Installing package : DSLite
source=unknown
2015-10-14T01:27:39.668Z - info: Looking up proxy settings for url http://dev.ti.com/ticloudagentinstaller source=unknown
2015-10-14T01:27:39.761Z - info: installer.js using proxy: source=unknown
2015-10-14T01:27:39.762Z - info: Get: http://dev.ti.com/ticloudagentinstaller/ticloudagentinstaller/getComponent?os=osx&component=DSLite source=unknown
2015-10-14T01:27:40.290Z - info: Response: 200 source=unknown
2015-10-14T01:27:40.291Z - info: Saving to temporary location: /Users/macmini/.ti/TICloudAgent/tmp/ticloudagent_artifacts/DSLite.7z source=unknown
2015-10-14T01:28:57.061Z - info: Added to Installed Components DB:DSLite source=unknown
2015-10-14T01:28:57.061Z - info: Installed package : DSLite
source=unknown
2015-10-14T01:28:57.062Z - info: Installing package : MSP432
source=unknown
2015-10-14T01:28:57.062Z - info: Looking up proxy settings for url http://dev.ti.com/ticloudagentinstaller source=unknown
2015-10-14T01:28:57.170Z - info: installer.js using proxy: source=unknown
2015-10-14T01:28:57.170Z - info: Get: http://dev.ti.com/ticloudagentinstaller/ticloudagentinstaller/getComponent?os=osx&component=MSP432 source=unknown
2015-10-14T01:28:57.705Z - info: Response: 200 source=unknown
2015-10-14T01:28:57.705Z - info: Saving to temporary location: /Users/macmini/.ti/TICloudAgent/tmp/ticloudagent_artifacts/MSP432.7z source=unknown
2015-10-14T01:29:18.594Z - info: Added to Installed Components DB:MSP432 source=unknown
2015-10-14T01:29:18.594Z - info: Installed package : MSP432
source=unknown
2015-10-14T01:29:18.595Z - info: Added to Supported Target DB:msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:29:18.595Z - info: Module( TargetSupport )->Ret Command ( response) : add : 2 source=unknown
2015-10-14T01:29:18.634Z - info: Module( Agent )->Exec Command : createSubModule:5 source=unknown
2015-10-14T01:29:18.635Z - info: Module( Agent )->Creating Sub Module : DS source=unknown
2015-10-14T01:29:18.635Z - info: Starting DS!!!!! source=unknown
2015-10-14T01:29:18.635Z - info: spawnDS : execFile = ./DSLite args = cwd = /Users/macmini/.ti/TICloudAgent/loaders/DSLite/DebugServer/bin source=unknown
2015-10-14T01:29:18.662Z - info: DS Lite : { "port" : 62820 }
source=unknown
2015-10-14T01:29:18.662Z - info: Started DS Lite : { "port" : 62820 }
source=unknown
2015-10-14T01:29:18.662Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 5 source=unknown
2015-10-14T01:29:24.164Z - info: DSLite process : exit event source=unknown
2015-10-14T01:29:24.164Z - info: DSLite process : close event source=unknown
2015-10-14T01:29:46.653Z - info: Module( File )->Exec Command : write:3 source=unknown
2015-10-14T01:29:46.655Z - info: Module( File )->Ret Command ( response) : write : 3 source=unknown
2015-10-14T01:29:46.688Z - info: Module( TargetSupport )->Exec Command : add:3 source=unknown
2015-10-14T01:29:46.688Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:29:46.689Z - info: Module( TargetSupport )->Ret Command ( response) : add : 3 source=unknown
2015-10-14T01:29:46.720Z - info: Module( Agent )->Exec Command : createSubModule:6 source=unknown
2015-10-14T01:29:46.720Z - info: Module( Agent )->Creating Sub Module : DS source=unknown
2015-10-14T01:29:46.720Z - info: Starting DS!!!!! source=unknown
2015-10-14T01:29:46.720Z - info: spawnDS : execFile = ./DSLite args = cwd = /Users/macmini/.ti/TICloudAgent/loaders/DSLite/DebugServer/bin source=unknown
2015-10-14T01:29:46.749Z - info: DS Lite : { "port" : 49428 }
source=unknown
2015-10-14T01:29:46.749Z - info: Started DS Lite : { "port" : 49428 }
source=unknown
2015-10-14T01:29:46.750Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 6 source=unknown
2015-10-14T01:30:09.716Z - info: Module( File )->Exec Command : write:4 source=unknown
2015-10-14T01:30:09.717Z - info: Module( File )->Ret Command ( response) : write : 4 source=unknown
2015-10-14T01:30:09.753Z - info: Module( TargetSupport )->Exec Command : add:4 source=unknown
2015-10-14T01:30:09.753Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:30:09.753Z - info: Module( TargetSupport )->Ret Command ( response) : add : 4 source=unknown
2015-10-14T01:30:09.783Z - info: Module( Agent )->Exec Command : createSubModule:7 source=unknown
2015-10-14T01:30:09.783Z - info: Module( Agent )->Creating Sub Module : Serial source=unknown
2015-10-14T01:30:09.784Z - info: Module( Serial )->Web socket server started! source=unknown
2015-10-14T01:30:09.785Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 7 source=unknown
2015-10-14T01:30:09.847Z - info: Module( Serial )->Exec Command : listCommands:1 source=unknown
2015-10-14T01:30:09.847Z - info: Module( Serial )->Ret Command ( response) : listCommands : 1 source=unknown
2015-10-14T01:30:09.888Z - info: Module( Serial )->Exec Command : list:2 source=unknown
2015-10-14T01:30:09.914Z - info: Module( Serial )->Ret Command ( response) : list : 2 source=unknown
2015-10-14T01:30:20.058Z - info: Module( Serial )->Exec Command : open:3 source=unknown
2015-10-14T01:30:20.062Z - info: Module( Serial )->Ret Command ( response) : open : 3 source=unknown
2015-10-14T01:30:24.474Z - info: Module( File )->Exec Command : write:5 source=unknown
2015-10-14T01:30:24.476Z - info: Module( File )->Ret Command ( response) : write : 5 source=unknown
2015-10-14T01:30:24.507Z - info: Module( TargetSupport )->Exec Command : add:5 source=unknown
2015-10-14T01:30:24.507Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:30:24.508Z - info: Module( TargetSupport )->Ret Command ( response) : add : 5 source=unknown
2015-10-14T01:30:25.937Z - info: DSLite process : exit event source=unknown
2015-10-14T01:30:25.937Z - info: DSLite process : close event source=unknown
2015-10-14T01:32:24.828Z - info: Module( File )->Exec Command : write:6 source=unknown
2015-10-14T01:32:24.828Z - info: Module( File )->Ret Command ( response) : write : 6 source=unknown
2015-10-14T01:32:24.872Z - info: Module( TargetSupport )->Exec Command : add:6 source=unknown
2015-10-14T01:32:24.872Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:32:24.873Z - info: Module( TargetSupport )->Ret Command ( response) : add : 6 source=unknown
2015-10-14T01:32:24.932Z - info: Module( Agent )->Exec Command : createSubModule:8 source=unknown
2015-10-14T01:32:24.932Z - info: Module( Agent )->Creating Sub Module : DS source=unknown
2015-10-14T01:32:24.932Z - info: Starting DS!!!!! source=unknown
2015-10-14T01:32:24.932Z - info: spawnDS : execFile = ./DSLite args = cwd = /Users/macmini/.ti/TICloudAgent/loaders/DSLite/DebugServer/bin source=unknown
2015-10-14T01:32:24.964Z - info: DS Lite : { "port" : 61640 }
source=unknown
2015-10-14T01:32:24.964Z - info: Started DS Lite : { "port" : 61640 }
source=unknown
2015-10-14T01:32:24.964Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 8 source=unknown
2015-10-14T01:33:59.385Z - info: Module( File )->Exec Command : write:7 source=unknown
2015-10-14T01:33:59.387Z - info: Module( File )->Ret Command ( response) : write : 7 source=unknown
2015-10-14T01:33:59.485Z - info: Module( TargetSupport )->Exec Command : add:7 source=unknown
2015-10-14T01:33:59.486Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:33:59.487Z - info: Module( TargetSupport )->Ret Command ( response) : add : 7 source=unknown
2015-10-14T01:34:01.025Z - info: DSLite process : exit event source=unknown
2015-10-14T01:34:01.025Z - info: DSLite process : close event source=unknown
2015-10-14T01:35:02.934Z - info: Module( File )->Exec Command : write:8 source=unknown
2015-10-14T01:35:02.935Z - info: Module( File )->Ret Command ( response) : write : 8 source=unknown
2015-10-14T01:35:02.969Z - info: Module( TargetSupport )->Exec Command : add:8 source=unknown
2015-10-14T01:35:02.970Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:35:02.970Z - info: Module( TargetSupport )->Ret Command ( response) : add : 8 source=unknown
2015-10-14T01:35:03.004Z - info: Module( Agent )->Exec Command : createSubModule:9 source=unknown
2015-10-14T01:35:03.004Z - info: Module( Agent )->Creating Sub Module : DS source=unknown
2015-10-14T01:35:03.004Z - info: Starting DS!!!!! source=unknown
2015-10-14T01:35:03.004Z - info: spawnDS : execFile = ./DSLite args = cwd = /Users/macmini/.ti/TICloudAgent/loaders/DSLite/DebugServer/bin source=unknown
2015-10-14T01:35:03.032Z - info: DS Lite : { "port" : 50188 }
source=unknown
2015-10-14T01:35:03.032Z - info: Started DS Lite : { "port" : 50188 }
source=unknown
2015-10-14T01:35:03.032Z - info: Module( Agent )->Ret Command ( response) : createSubModule : 9 source=unknown
2015-10-14T01:39:30.363Z - info: Module( File )->Exec Command : write:9 source=unknown
2015-10-14T01:39:30.366Z - info: Module( File )->Ret Command ( response) : write : 9 source=unknown
2015-10-14T01:39:30.394Z - info: Module( TargetSupport )->Exec Command : add:9 source=unknown
2015-10-14T01:39:30.395Z - info: Target support already exists : msp432p401r_TIXDS110_Connection source=unknown
2015-10-14T01:39:30.395Z - info: Module( TargetSupport )->Ret Command ( response) : add : 9 source=unknown
2015-10-14T01:39:31.867Z - info: DSLite process : exit event source=unknown
2015-10-14T01:39:31.867Z - info: DSLite process : close event source=unknown
Scott
