word wrap in Problems window
Got a long warning in the problem window.  Do not know how to do word wrap so I can not read the whole message
Is there a way to do word wrap in this (and other) windows?
  • You can double click on the tab where it says "problems" and it will maximize the view, you can also resize the column to make it longer.  I don't know of a way to have it show multiple lines for an error.   Putting your mouse over the text will also show a tooltip but it will be limited to one line as well (as wide as your screen is)
    The full text will also be displayed in the console view.
    John
  • I filed a defect to track this SDSCM00036504.  However I should note that this is likely an issue in Eclipse itself so any fix will be dependent on us including a newer version of Eclipse in CCS.
    John
