Line execution count in CCS?
Im have CCS5 and am working with C6678. Context Aware Profiling wiht fucntion entry/exit hooks can easily profile at Function granularity. But I am interested in Line granularity. Is there any method where CCS can tell me that the Lines of a certain code took these many cycles and were executed these many times?
Paticularly in am interested in Execution Count of all the Lines in a code.
Thank you.
    Since you are using C6678 with CCSv5, you can use the C6678 Device Cycle Accurate Simulator and Code Coverage feature to get the information you are looking for:
    processors.wiki.ti.com/.../CCS_Modules_Library
    ki
  • Hi Ki,
    Thanks for the reply. Yes this will work for me. I still have a few questions. Where can I find more information regarding Code Coverage? e.g I want to know what the different columns specify in the Line Coverage and Function Coverage tables.
    Also is there a way to get coverage of only selective code Lines?
    Awaid
  • There is some documentation in the included Help that comes with CCS ('Help -> Help Contents'). However the information is a bit sparse and I don't think it explains all the columns. If you are unsure what a particular column means, I can try to explain it.
    If you are looking to have the tool only collect coverage information of only a few specified lines, I do not think that is possible. It will get all the coverage data.
