How to get older ARM compiler.
One of our older application was developed on CCS3.3 and ARM CGT Tool 4.6.0.
And we need that compiler to re-build the project, is it possible to provide us this tool(ARM v4.6.0)?
Best Regards
Kummi
  • Do you have CCS 6.x installed?  You can use it to install older versions of the ARM compiler.  Select Help | Install New Software.  You can install ARM compiler version 4.6.6.  See the screenshot below.  The only difference from version 4.6.0 is bug fixes.  It is the same otherwise.  Is this good enough?
    Thanks and regards,
    -George
