Other Parts Discussed in Thread: CC2640
I am using sable-x module which has a cc2640 5xd, the build process succeed but the debug failed, the console information is listed as below
I checked that the .out file is there, then what could be the reason?
thanks!
Di
Cortex_M3_0: GEL Output: Memory Map Initialization Complete.
Cortex_M3_0: GEL Output: Board Reset Complete.
Cortex_M3_0: Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 6.0.83.1)
Cortex_M3_0: Trouble Halting Target CPU: (Error -2064 @ 0x0) Unable to read device status. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 6.0.83.1)
Cortex_M3_0: Trouble Halting Target CPU: (Error -2062 @ 0x0) Unable to halt device. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 6.0.83.1)
Cortex_M3_0: Unable to determine target status after 20 attempts
Cortex_M3_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
Cortex_M3_0: Error occurred during flash operation: Could not read register R0: target is not connected
Cortex_M3_0: Flashloader unable to erase sector 0 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Error occurred during flash operation: Could not write register R5: target is not connected
Cortex_M3_0: Error occurred during flash operation: Could not write register R6: target is not connected
Cortex_M3_0: Error occurred during flash operation: Could not write register R0: target is not connected
Cortex_M3_0: Error occurred during flash operation: Could not write register PC: target is not connected
Cortex_M3_0: Error occurred during flash operation: Failed to run target
Cortex_M3_0: Flashloader unable to erase sector 1 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Flashloader unable to erase sector 2 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Flashloader unable to erase sector 3 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Flashloader unable to erase sector 4 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Flashloader unable to erase sector 5 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Flashloader unable to erase sector 6 (code 1507190168). Sector may be locked - try mass erase operation.
Cortex_M3_0: Error occurred during flash operation: Could not write 0x20000400: target is not connected
Cortex_M3_0: Error occurred during flash operation: Could not write register R1: target is not connected
Cortex_M3_0: Error occurred during flash operation: Could not write register R2: target is not connected
Cortex_M3_0: File Loader: Verification failed: Could not read 0x00000000: target is not connected
Cortex_M3_0: GEL: File: E:\Users\Di\workspace_v6_1\SimpleBLEPeripheral\FlashROM\SimpleBLEPeripheral.out: Load failed.
