CCS to slow...
In the latest release you made a mistake so I can no longer use the 8 CPU cores I got ether so this is way to slowwwwwwww...........
The 4.1.3 is supose to fix this, but WHEN IS IT COMMING....
Terje
  • Terje,
    Correct in 4.1.2 you cannot swap in mingw make and take advantage of the parallel build feature supported by that version of make.  This is due to a change introduced to fix an issue with long command lines.  CCSv4.1.3 does fix this, current estimates put its availability at the end of June.
    John
