CDT builder error after installing CCS 6.1.3
I just installed CCS 6.1.3 and I can't build two build configurations of a project. If one output folder of a build exists, I can build it but if I switch to the other build config while the output folder of the other one exists, I will get a CDT builder null pointer error. I attached part of the eclipse log related to the build error. Before upgrading I was using CCS 6.1.1 and everything was working fine.
Any help will be appreciated.
!ENTRY org.eclipse.core.resources 4 75 2016-05-11 09:11:27.661
!MESSAGE Errors occurred during the build.
!SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 75 2016-05-11 09:11:27.661
!MESSAGE Errors running builder 'CDT Builder' on project 'Bootloader'.
!STACK 0
java.lang.NullPointerException
	at org.eclipse.core.runtime.Path.isPrefixOf(Path.java:705)
	at com.ti.ccstudio.project.core.internal.build.temp.ManagedBuildGnuToolInfo.calculateInputs(ManagedBuildGnuToolInfo.java:335)
	at com.ti.ccstudio.project.core.internal.build.temp.GnuMakefileGenerator$3.visit(GnuMakefileGenerator.java:3798)
	at org.eclipse.cdt.core.settings.model.util.PathSettingsContainer.doAccept(PathSettingsContainer.java:519)
	at org.eclipse.cdt.core.settings.model.util.PathSettingsContainer.accept(PathSettingsContainer.java:515)
	at com.ti.ccstudio.project.core.internal.build.temp.GnuMakefileGenerator.calculateToolInputsOutputs(GnuMakefileGenerator.java:3714)
	at com.ti.ccstudio.project.core.internal.build.temp.GnuMakefileGenerator.regenerateMakefiles(GnuMakefileGenerator.java:592)
	at com.ti.ccstudio.project.core.internal.build.CCSMakefileGenerator.regenerateMakefiles(CCSMakefileGenerator.java:376)
	at com.ti.ccstudio.project.core.internal.build.CCSMakefileGenerator.regenerateMakefiles(CCSMakefileGenerator.java:367)
	at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performMakefileGeneration(CommonBuilder.java:1006)
	at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performPrebuildGeneration(CommonBuilder.java:873)
	at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:748)
	at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:513)
	at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:459)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:205)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:245)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:300)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:303)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:359)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:382)
	at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:486)
	at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:405)
	at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:287)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:39)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.665
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
	at org.eclipse.rse.files.ui.resources.SystemTempFileListener.checkLocalChanges(SystemTempFileListener.java:379)
	at org.eclipse.rse.files.ui.resources.SystemTempFileListener.checkLocalChanges(SystemTempFileListener.java:386)
	at org.eclipse.rse.files.ui.resources.SystemTempFileListener.resourceChanged(SystemTempFileListener.java:218)
	at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:299)
	at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:289)
	at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:152)
	at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:373)
	at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1470)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:46)
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.672
!STACK 0
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.680
!STACK 0
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.687
!STACK 0
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.696
!STACK 0
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.729
!STACK 0
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.737
!STACK 0
!ENTRY org.eclipse.core.resources 4 2 2016-05-11 09:11:27.815
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2016-05-11 09:11:28.459
!MESSAGE Indexed 'Bootloader' (48 sources, 246 headers) in 7.03 sec: 23,735 declarations; 33,769 references; 0 unresolved inclusions; 194 syntax errors; 2,750 unresolved names (4.6%)
