CCSv6.1.3 and GUI Composer: No variable binding for button
Guru 20075 points
In GUI Composer, how do I bind a button to a variable.  Neither Bind->Label nor Widget->Label work.
Stephen
  • Also, setting setting Widget->Name to the variable name and Value to 1 doesn't.
    Stephen
  • Where is the documentation for GUI Composer?
    I found this post .
    I added a dsScript.js file to my GUI Composer project with the contents shown below.  I also added myStepOver to the onclick evert.  GUI_Var doesn't get set to 1 when I click the button.
    What am I doing wrong?
    Stephen
    importPackage(Packages.com.ti.ccstudio.scripting.environment)
    function myStepOver( steps)
        if(!$active_context_name)
            throw "An active Debug Session is required for myStepOver()";
        var debugServer = ScriptingEnvironment.instance().getServer('DebugServer.1');
        var session = debugServer.openSession($active_context_name);
        session.expression.evaluate("GUI_Var = 1");
  • Ok, I found this: e2e.ti.com/.../385515
    The value button works, however the logic is backward: Widget->Value = variable name and Binding= Value. You would think it would be the other way around.
