Dear All,
During the first manufacturing build I noticed 20% failures for the JTAG programming of virgin DSP. When we tried to program the second time - everyone was passed.
I tried to recreate the failures - the programming routine was repeated 100 times for 6 DSP - all passed.
It seems that error is the same for each failures (occurred at the same step every time , after/ during the Writing Flash @ Address 0x00080000 of Length 0x00002d1f ) uniflash complains with Trouble Setting Breakpoint with the Action "Remain Halted" at 0xc15f: (Error -1066 @ 0xC15F)
Attached are two log files for passed and failed programming, .ccxml file and the screen for uniflash output when error appeared.
To program the DSP we use:
- command tool of uniflash 3.3
typical parameters for command line are:
uniflash -log C:\\temp\\nest1dcore1d.txt -programStatusOutput C:\\temp\\status1_core1d pass fail -ccxml C:\\temp\\set.ccxml -core C28xx_CPU1 -program C:\\temp\\load.s37
- Spectrum Digital XDS220 ISO
Any help is welcome for the resolution of this problem
Anton
<?xml version="1.0" encoding="windows-1252" standalone="no"?>
<?xml-stylesheet type="text/xsl" href="C:/ti/uniflash_3.3/ccs_base/scripting/examples/uniflash/cmdLineM/../stylesheet/DefaultStylesheet.xsl"?>
<log>
<record>
<date>2016-06-24T12:22:25</date>
<millis>1466785345997</millis>
<sequence>7</sequence>
<logger>com.ti</logger>
<level>FINER</level>
<class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class>
<method>traceSetFileLevel</method>
<thread>10</thread>
<message>RETURN</message>
</record>
<record>
<date>2016-06-24T12:22:26</date>
<millis>1466785346007</millis>
<sequence>8</sequence>
<method>getServer</method>
<thread>10</thread>
<message>ENTRY sServerName: DebugServer.1</message>
</record>
<record>
<sequence>9</sequence>
<thread>10</thread>
<message>Getting definition for: DebugServer.1</message>
</record>
<record>
<millis>1466785346017</millis>
<sequence>10</sequence>
<thread>10</thread>
<message>Constructing server</message>
</record>
<record>
<millis>1466785346027</millis>
<sequence>11</sequence>
<thread>10</thread>
<message>RETURN com.ti.debug.engine.scripting.DebugServer@cfec48</message>
</record>
<record>
<sequence>12</sequence>
<logger>com.ti.debug.engine.scripting.DebugServer</logger>
<class>com.ti.debug.engine.scripting.DebugServer</class>
<method>setConfig</method>
<thread>10</thread>
<message>ENTRY sConfigurationFile: C:\Main_GM1_75\XDS220\cfg3DualCore.ccxml</message>
</record>
<record>
<sequence>13</sequence>
<thread>10</thread>
</record>
<record>
<sequence>14</sequence>
<method>setDefaultDialogResponse</method>
<thread>10</thread>
<message>ENTRY com.ti.debug.engine.scripting.DebugServer@cfec48 Default Choice: Update</message>
</record>
<record>
<sequence>15</sequence>
<thread>10</thread>
</record>
<record>
<sequence>16</sequence>
<method>openSession</method>
<thread>10</thread>
<message>ENTRY sPattern: .*C28xx_CPU1.*</message>
</record>
<record>
<sequence>17</sequence>
<method>start</method>
<thread>10</thread>
<message>ENTRY</message>
</record>
<record>
<sequence>18</sequence>
<thread>10</thread>
<message>Firing: onServerStarting()</message>
</record>
<record>
<sequence>19</sequence>
<thread>10</thread>
<message>Connecting to XPCOM DebugServer</message>
</record>
<record>
<millis>1466785346087</millis>
<sequence>20</sequence>
<thread>10</thread>
<message>Initializing DebugServer using specified configuration: "C:\Main_GM1_75\XDS220\cfg3DualCore.ccxml"</message>
</record>
<record>
<sequence>21</sequence>
<class>com.ti.debug.engine.scripting.DebugServer$Callback</class>
<method>waitUntil</method>
<thread>10</thread>
<message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@9f5011 timeout: infinite</message>
</record>
<record>
<date>2016-06-24T12:22:28</date>
<millis>1466785348957</millis>
<sequence>22</sequence>
<logger>com.ti.debug.engine.scripting.DebugSession</logger>
<class>com.ti.debug.engine.scripting.DebugSession</class>
<method><init></method>
<thread>11</thread>
<message>CPU Name: C28xx_CPU1</message>
</record>
<record>
<sequence>23</sequence>
<thread>11</thread>
<message>PartNum: TMS320F28377D</message>
</record>
<record>
<sequence>24</sequence>
<thread>11</thread>
<message>Family: 320</message>
</record>
<record>
<sequence>25</sequence>
<thread>11</thread>
<message>SubFamily/MajorISA: 28</message>
</record>
<record>
<sequence>26</sequence>
<thread>11</thread>
<message>Revision/MinorISA: 127</message>
</record>
<record>
<sequence>27</sequence>
<thread>11</thread>
<message>Platform: EMULATOR</message>
</record>
<record>
<sequence>28</sequence>
<thread>11</thread>
<message>Processor ID: 1342219256</message>
</record>
<record>
<millis>1466785348977</millis>
<sequence>29</sequence>
<thread>11</thread>
<message>CPU Name: CPU1_CLA1</message>
</record>
<record>
<sequence>30</sequence>
<thread>11</thread>
</record>
<record>
<sequence>31</sequence>
<thread>11</thread>
<message>Family: 192</message>
</record>
<record>
<sequence>32</sequence>
<thread>11</thread>
<message>SubFamily/MajorISA: 20</message>
</record>
<record>
<sequence>33</sequence>
<thread>11</thread>
<message>Revision/MinorISA: 7</message>
</record>
<record>
<sequence>34</sequence>
<thread>11</thread>
</record>
<record>
<sequence>35</sequence>
<thread>11</thread>
<message>Processor ID: 805339192</message>
</record>
<record>
<sequence>36</sequence>
<thread>11</thread>
<message>CPU Name: C28xx_CPU2</message>
</record>
<record>
<sequence>37</sequence>
<thread>11</thread>
</record>
<record>
<sequence>38</sequence>
<thread>11</thread>
</record>
<record>
<sequence>39</sequence>
<thread>11</thread>
</record>
<record>
<sequence>40</sequence>
<thread>11</thread>
</record>
<record>
<sequence>41</sequence>
<thread>11</thread>
</record>
<record>
<sequence>42</sequence>
<thread>11</thread>
</record>
<record>
<sequence>43</sequence>
<thread>11</thread>
<message>CPU Name: CPU2_CLA1</message>
</record>
<record>
<sequence>44</sequence>
<thread>11</thread>
</record>
<record>
<sequence>45</sequence>
<thread>11</thread>
</record>
<record>
<sequence>46</sequence>
<thread>11</thread>
</record>
<record>
<sequence>47</sequence>
<thread>11</thread>
</record>
<record>
<sequence>48</sequence>
<thread>11</thread>
</record>
<record>
<sequence>49</sequence>
<thread>11</thread>
</record>
<record>
<sequence>50</sequence>
<thread>11</thread>
<message>CPU Name: IcePick_C_0</message>
</record>
<record>
<sequence>51</sequence>
<thread>11</thread>
</record>
<record>
<sequence>52</sequence>
<thread>11</thread>
<message>Family: 240</message>
</record>
<record>
<sequence>53</sequence>
<thread>11</thread>
<message>SubFamily/MajorISA: 2</message>
</record>
<record>
<sequence>54</sequence>
<thread>11</thread>
<message>Revision/MinorISA: 0</message>
</record>
<record>
<sequence>55</sequence>
<thread>11</thread>
<message>Platform: NONE</message>
</record>
<record>
<sequence>56</sequence>
<thread>11</thread>
<message>Processor ID: 1006635013</message>
</record>
<record>
<sequence>57</sequence>
<thread>10</thread>
<message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@9f5011</message>
</record>
<record>
<sequence>58</sequence>
<thread>10</thread>
<message>Firing: onServerStarted()</message>
</record>
<record>
<sequence>59</sequence>
<thread>10</thread>
<message>Searching for devices</message>
</record>
<record>
<sequence>60</sequence>
<method>listDevices</method>
<thread>10</thread>
</record>
<record>
<sequence>61</sequence>
<thread>10</thread>
<message>Found debuggable device: Texas Instruments XDS2xx LAN Emulator/C28xx_CPU1</message>
</record>
<record>
<sequence>62</sequence>
<thread>10</thread>
<message>Found debuggable device: Texas Instruments XDS2xx LAN Emulator/CPU1_CLA1</message>
</record>
<record>
<sequence>63</sequence>
<thread>10</thread>
<message>Found debuggable device: Texas Instruments XDS2xx LAN Emulator/C28xx_CPU2</message>
</record>
<record>
<sequence>64</sequence>
<thread>10</thread>
<message>Found debuggable device: Texas Instruments XDS2xx LAN Emulator/CPU2_CLA1</message>
</record>
<record>
<sequence>65</sequence>
<thread>10</thread>
<message>Found non-debuggable device: Texas Instruments XDS2xx LAN Emulator/IcePick_C_0</message>
</record>
<record>
<sequence>66</sequence>
<thread>10</thread>
</record>
<record>
<sequence>67</sequence>
<thread>10</thread>
</record>
<record>
<sequence>68</sequence>
<thread>10</thread>
<message>Searching for device exactly matching name: .*C28xx_CPU1.*</message>
</record>
<record>
<sequence>69</sequence>
<thread>10</thread>
<message>No exact name matches found. Searching for device matching regular expression: .*C28xx_CPU1.*</message>
</record>
<record>
<date>2016-06-24T12:22:29</date>
<millis>1466785349087</millis>
<sequence>70</sequence>
<thread>10</thread>
<message>RETURN Texas Instruments XDS2xx LAN Emulator/C28xx_CPU1</message>
</record>
<record>
<sequence>71</sequence>
<level>INFO</level>
<method>traceWrite</method>
<thread>10</thread>
<message>> Flash Manager is configured for the following part: TMS320F28377D
</message>
</record>
<record>
<sequence>72</sequence>
<method>unsetDefaultDialogResponse</method>
<thread>10</thread>
<message>ENTRY com.ti.debug.engine.scripting.DebugServer@cfec48</message>
</record>
<record>
<sequence>73</sequence>
<thread>10</thread>
</record>
<record>
<sequence>74</sequence>
<logger>com.ti.debug.engine.scripting.Options</logger>
<class>com.ti.debug.engine.scripting.Options</class>
<method>optionExist</method>
<thread>10</thread>
<message>ENTRY ID: FlashVerboseMode</message>
</record>
<record>
<sequence>75</sequence>
<thread>10</thread>
<message>RETURN true</message>
</record>
<record>
<sequence>76</sequence>
<method>setBoolean</method>
<thread>10</thread>
<message>ENTRY ID: FlashVerboseMode Value: true</message>
</record>
<record>
<sequence>77</sequence>
<thread>10</thread>
</record>
<record>
<sequence>78</sequence>
<thread>10</thread>
<message>ENTRY ID: AddCIOBreakpointAfterLoad Value: false</message>
</record>
<record>
<sequence>79</sequence>
<thread>10</thread>
</record>
<record>
<sequence>80</sequence>
<method>setString</method>
<thread>10</thread>
<message>ENTRY ID: VerifyAfterProgramLoad Value: Full verification</message>
</record>
<record>
<millis>1466785349097</millis>
<sequence>81</sequence>
<thread>10</thread>
</record>
<record>
<sequence>82</sequence>
<thread>10</thread>
<message>ENTRY ID: AutoRunToLabelOnRestart Value: false</message>
</record>
<record>
<sequence>83</sequence>
<thread>10</thread>
</record>
<record>
<sequence>84</sequence>
<thread>10</thread>
<message>ENTRY ID: AddCEXITbreakpointAfterLoad Value: false</message>
</record>
<record>
<sequence>85</sequence>
<thread>10</thread>
</record>
<record>
<sequence>86</sequence>
<level>INFO</level>
<thread>10</thread>
<message>> Connecting to the target for Flash operations ...
</message>
</record>
<record>
<sequence>87</sequence>
<logger>com.ti.debug.engine.scripting.Target</logger>
<class>com.ti.debug.engine.scripting.Target</class>
<method>connect</method>
<thread>10</thread>
</record>
<record>
<sequence>88</sequence>
<method>isConnected</method>
<thread>10</thread>
</record>
<record>
<sequence>89</sequence>
<thread>10</thread>
<message>Target is not connected</message>
</record>
<record>
<sequence>90</sequence>
<thread>10</thread>
<message>RETURN false</message>
</record>
<record>
<sequence>91</sequence>
<thread>10</thread>
<message>Requesting target connect</message>
</record>
<record>
<millis>1466785349107</millis>
<sequence>92</sequence>
<class>com.ti.debug.engine.scripting.Target$OnConnectedListener</class>
<thread>10</thread>
<message>ENTRY timeout: infinite</message>
</record>
<record>
<date>2016-06-24T12:22:30</date>
<millis>1466785350707</millis>
<sequence>93</sequence>
<level>INFO</level>
<class>com.ti.debug.engine.scripting.DebugSession$DebuggerInfoListener</class>
<method>onEvent</method>
<thread>12</thread>
<message>C28xx_CPU1: GEL Output:
Memory Map Initialization Complete
</message>
</record>
<record>
<date>2016-06-24T12:22:31</date>
<millis>1466785351267</millis>
<sequence>94</sequence>
<level>INFO</level>
<thread>13</thread>
<message>C28xx_CPU1: If erase/program (E/P) operation is being done on one core, the other core should not execute from shared-RAM (SR) as they are used for the E/P code. Also, CPU1 will be halted to determine SR ownership for the CPU which will run the Flash Plugin code, after which CPU1 will be set to run its application. User code execution from SR could commence after both flash banks are programmed.
</message>
</record>
<record>
<sequence>95</sequence>
<class>com.ti.debug.engine.scripting.AbstractListener</class>
<method>log</method>
<thread>12</thread>
<message>Target is now connected</message>
</record>
<record>
<sequence>96</sequence>
<thread>10</thread>
</record>
<record>
<millis>1466785351277</millis>
<sequence>97</sequence>
<thread>10</thread>
</record>
<record>
<sequence>98</sequence>
<thread>10</thread>
<message>Target is connected</message>
</record>
<record>
<sequence>99</sequence>
<thread>10</thread>
</record>
<record>
<sequence>100</sequence>
<thread>10</thread>
</record>
<record>
<sequence>101</sequence>
<level>INFO</level>
<thread>10</thread>
<message>> Connected.
</message>
</record>
<record>
<millis>1466785351287</millis>
<sequence>102</sequence>
<level>INFO</level>
<thread>10</thread>
<message>> Loading Program: C:\Main_GM1_75\Data\CFG235_D2.s37</message>
</record>
<record>
<sequence>103</sequence>
<logger>com.ti.debug.engine.scripting.Memory</logger>
<class>com.ti.debug.engine.scripting.Memory</class>
<method>loadProgram</method>
<thread>10</thread>
<message>ENTRY sFileName: C:\Main_GM1_75\Data\CFG235_D2.s37</message>
</record>
<record>
<sequence>104</sequence>
<method>load</method>
<thread>10</thread>
<message>Requesting program load</message>
</record>
<record>
<sequence>105</sequence>
<class>com.ti.debug.engine.scripting.APIContainer$OnCompleteWithErrorInfo</class>
<thread>10</thread>
</record>
<record>
<date>2016-06-24T12:22:33</date>
<millis>1466785353767</millis>
<sequence>106</sequence>
<level>INFO</level>
<thread>13</thread>
<message>C28xx_CPU1: Writing Flash @ Address 0x00080000 of Length 0x00002d1f (page 0)
</message>
</record>
<record>
<date>2016-06-24T12:22:34</date>
<millis>1466785354947</millis>
<sequence>107</sequence>
<level>SEVERE</level>
<class>com.ti.debug.engine.scripting.DebugSession$DebuggerErrorListener</class>
<thread>12</thread>
<message>C28xx_CPU1: Trouble Setting Breakpoint with the Action "Remain Halted" at 0xc15f: (Error -1066 @ 0xC15F) Unable to set/clear requested breakpoint. Verify that the breakpoint address is in valid memory. (Emulation package 5.1.641.0)
</message>
</record>
<record>
<sequence>108</sequence>
<level>WARNING</level>
<class>com.ti.debug.engine.scripting.DebugSession$DebuggerWarningListener</class>
<thread>12</thread>
<message>C28xx_CPU1: Breakpoint Manager: Retrying with a AET breakpoint
</message>
</record>
<record>
<date>2016-06-24T12:22:35</date>
<millis>1466785355577</millis>
<sequence>109</sequence>
<thread>13</thread>
<message>C28xx_CPU1: Error writing the PLL values. (Flash algoirthm returned error code). Operation cancelled.
</message>
</record>
<record>
<sequence>110</sequence>
<thread>12</thread>
<message>C28xx_CPU1: File Loader: Memory write failed: Unknown error
</message>
</record>
<record>
<sequence>111</sequence>
<thread>12</thread>
<message>C28xx_CPU1: GEL: File: C:\Main_GM1_75\Data\CFG235_D2.s37: Load failed.
</message>
</record>
<record>
<millis>1466785355587</millis>
<sequence>112</sequence>
<thread>10</thread>
</record>
<record>
<sequence>113</sequence>
<logger>com.ti.ccstudio.scripting.environment.ScriptingException</logger>
<class>com.ti.ccstudio.scripting.environment.ScriptingException</class>
<method>logException</method>
<thread>10</thread>
<message>File: C:\Main_GM1_75\Data\CFG235_D2.s37: Load failed.</message>
<exception>
<message>com.ti.ccstudio.scripting.environment.ScriptingException: File: C:\Main_GM1_75\Data\CFG235_D2.s37: Load failed.</message>
<frame>
<line>963</line>
</frame>
<frame>
<line>922</line>
</frame>
<frame>
<class>sun.reflect.NativeMethodAccessorImpl</class>
<method>invoke0</method>
</frame>
<frame>
<method>invoke</method>
</frame>
<frame>
<class>sun.reflect.DelegatingMethodAccessorImpl</class>
</frame>
<frame>
<class>java.lang.reflect.Method</class>
</frame>
<frame>
<class>org.mozilla.javascript.MemberBox</class>
<line>142</line>
</frame>
<frame>
<class>org.mozilla.javascript.NativeJavaMethod</class>
<method>call</method>
<line>201</line>
</frame>
<frame>
<class>org.mozilla.javascript.optimizer.OptRuntime</class>
<method>call1</method>
<line>64</line>
</frame>
<frame>
<class>org.mozilla.javascript.gen.c6</class>
<method>_c1</method>
<line>130</line>
</frame>
<frame>
</frame>
<frame>
<method>callName0</method>
<line>106</line>
</frame>
<frame>
<class>org.mozilla.javascript.gen.c1</class>
<method>_c6</method>
<line>342</line>
</frame>
<frame>
</frame>
<frame>
<line>106</line>
</frame>
<frame>
<method>_c0</method>
<line>21</line>
</frame>
<frame>
</frame>
<frame>
<class>org.mozilla.javascript.ContextFactory</class>
<method>doTopCall</method>
<line>337</line>
</frame>
<frame>
<class>org.mozilla.javascript.ScriptRuntime</class>
<line>2755</line>
</frame>
<frame>
</frame>
<frame>
<method>exec</method>
</frame>
<frame>
<class>org.mozilla.javascript.tools.shell.Main</class>
<method>evaluateScript</method>
<line>500</line>
</frame>
<frame>
<method>processFileSecure</method>
<line>422</line>
</frame>
<frame>
<method>processFile</method>
<line>388</line>
</frame>
<frame>
<method>processSource</method>
<line>379</line>
</frame>
<frame>
<method>processFiles</method>
<line>176</line>
</frame>
<frame>
<class>org.mozilla.javascript.tools.shell.Main$IProxy</class>
<method>run</method>
<line>97</line>
</frame>
<frame>
<class>org.mozilla.javascript.Context</class>
<line>540</line>
</frame>
<frame>
<line>447</line>
</frame>
<frame>
<line>159</line>
</frame>
<frame>
<method>main</method>
<line>137</line>
</frame>
</exception>
</record>
<record>
<sequence>114</sequence>
<thread>10</thread>
<message>Error loading "C:\Main_GM1_75\Data\CFG235_D2.s37": File: C:\Main_GM1_75\Data\CFG235_D2.s37: Load failed.</message>
<exception>
<message>com.ti.ccstudio.scripting.environment.ScriptingException: Error loading "C:\Main_GM1_75\Data\CFG235_D2.s37": File: C:\Main_GM1_75\Data\CFG235_D2.s37: Load failed.</message>
<frame>
<line>932</line>
</frame>
<frame>
</frame>
<frame>
</frame>
<frame>
</frame>
<frame>
</frame>
<frame>
<line>142</line>
</frame>
<frame>
<line>201</line>
</frame>
<frame>
<line>64</line>
</frame>
<frame>
<line>130</line>
</frame>
<frame>
</frame>
<frame>
<line>106</line>
</frame>
<frame>
<line>342</line>
</frame>
<frame>
</frame>
<frame>
<line>106</line>
</frame>
<frame>
<line>21</line>
</frame>
<frame>
</frame>
<frame>
<line>337</line>
</frame>
<frame>
<line>2755</line>
</frame>
<frame>
</frame>
<frame>
</frame>
<frame>
<line>500</line>
</frame>
<frame>
<line>422</line>
</frame>
<frame>
<line>388</line>
</frame>
<frame>
<line>379</line>
</frame>
<frame>
<line>176</line>
</frame>
<frame>
<line>97</line>
</frame>
<frame>
<line>540</line>
</frame>
<frame>
<line>447</line>
</frame>
<frame>
<line>159</line>
</frame>
<frame>
<line>137</line>
</frame>
</exception>
</record>
<record>
<sequence>115</sequence>
<level>INFO</level>
<thread>10</thread>
<message>> Command suspended due to errors in loading the program.
</message>
</record>
<record>
<sequence>116</sequence>
<level>INFO</level>
<thread>10</thread>
<message>> Disconnecting from target.
</message>
</record>
<record>
<sequence>117</sequence>
<method>disconnect</method>
<thread>10</thread>
</record>
<record>
<millis>1466785355597</millis>
<sequence>118</sequence>
<thread>10</thread>
<message>Requesting target disconnect</message>
</record>
<record>
<sequence>119</sequence>
<class>com.ti.debug.engine.scripting.Target$OnDisconnectedListener</class>
<thread>10</thread>
</record>
<record>
<millis>1466785355617</millis>
<sequence>120</sequence>
<thread>13</thread>
<message>C28xx_CPU1: Error occurred during flash operation: Could not write 0x00000@Program: target is not connected
</message>
</record>
<record>
<sequence>121</sequence>
<thread>13</thread>
<message>C28xx_CPU1: Error occurred during flash operation: Cannot enable while the target is disconnected
</message>
</record>
<record>
<millis>1466785355647</millis>
<sequence>122</sequence>
<thread>13</thread>
<message>C28xx_CPU1: Error occurred during flash operation: Could not read 0x0005F444@Data: target is not connected
</message>
</record>
<record>
<millis>1466785355687</millis>
<sequence>123</sequence>
<thread>13</thread>
<message>C28xx_CPU1: Error occurred during flash operation: Could not read 0x0007026D@Data: target is not connected
</message>
</record>
<record>
<millis>1466785355837</millis>
<sequence>124</sequence>
<thread>12</thread>
<message>Target is now disconnected</message>
</record>
<record>
<sequence>125</sequence>
<thread>10</thread>
</record>
<record>
<sequence>126</sequence>
<thread>10</thread>
</record>
<record>
<sequence>127</sequence>
<method>terminate</method>
<thread>10</thread>
</record>
<record>
<sequence>128</sequence>
<thread>10</thread>
<message>Firing: onSessionTerminating()</message>
</record>
<record>
<sequence>129</sequence>
<thread>10</thread>
<message>Unregistering this session from the DebugServer</message>
</record>
<record>
<sequence>130</sequence>
<thread>10</thread>
<message>Firing: onSessionTerminated()</message>
</record>
<record>
<sequence>131</sequence>
<method>disposeAndUnload</method>
<thread>10</thread>
<message>Firing: onServerStopping()</message>
</record>
<record>
<sequence>132</sequence>
<thread>10</thread>
<message>Stopping DebugServer</message>
</record>
<record>
<sequence>133</sequence>
<thread>10</thread>
</record>
<record>
<sequence>134</sequence>
<thread>10</thread>
</record>
<record>
<sequence>135</sequence>
<thread>10</thread>
</record>
<record>
<sequence>136</sequence>
<thread>10</thread>
</record>
<record>
<sequence>137</sequence>
<thread>10</thread>
</record>
<record>
<sequence>138</sequence>
<thread>10</thread>
</record>
<record>
<sequence>139</sequence>
<thread>10</thread>
</record>
<record>
<sequence>140</sequence>
<thread>10</thread>
</record>
<record>
<sequence>141</sequence>
<thread>10</thread>
</record>
<record>
<sequence>142</sequence>
<thread>10</thread>
</record>
<record>
<sequence>143</sequence>
<thread>13</thread>
<message>C28xx_CPU1: Error occurred during flash operation: Could not write 0x0005F444@Data: target is not connected
</message>
</record>
<record>
<sequence>144</sequence>
<thread>10</thread>
</record>
