got this error in CCS4.1. that is the entire message. I could use just a bit more information. any ideas?
sorry, still new to CCS4.1. the message was NOT fromt he console view. the message from the console view is:
_ECM_dispatchTab C:/Program Files/Texas Instruments/bios_5_41_04_18/packages/ti/bios/lib/bios.a674<ecm_dispatch.o674> > Try enabling the ECM module and see if the error goes away. "ECM module"? enable? I do not know what that means.
ECM stands for Event Combine Manager. This is a feature of BIOS which allows you to multiplex multiple interrupt sources through a single hardware interrupt. Open your BIOS configuration file, expand Scheduling, then expand the HWI Manager. At the bottom under HWI_INT15 you should see the ECM Manager. If you right click this you can enable this module again.Kurt Jensen said:"ECM module"? enable? I do not know what that means.
