Other Parts Discussed in Thread: HALCOGEN
I'm trying to create a user defined pwm, I've already done everything i need to in HET IDE and Halcogen. So im trying to write values in to the memory where these pulses are.
So I typed into Sys_main:
e_HETPROGRAM0_UN.Program0_ST.START_0.memory.data_word=0x80; // TELLS THE CODE WHERE TO LOAD THE HET PROGRAM
e_HETPROGRAM0_UN.Program0_ST.hetlabel_55_0.memory.data_word=0xA; // FIRST PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_57_0.memory.data_word=0xF; // SECOND PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_59_0.memory.data_word=0x14; // THRID PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_61_0.memory.data_word=0x1E; //FOURTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_63_0.memory.data_word=0x28; // FIFTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_65_0.memory.data_word=0x3C; // SIXTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_67_0.memory.data_word=0x5A; // SEVENTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_69_0.memory.data_word=0x78; // EIGHTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_71_0.memory.data_word=0x8C; // NINTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_73_0.memory.data_word=0xB4; // TENTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_75_0.memory.data_word=0xFA; // ELEVENTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_77_0.memory.data_word=0xA; // TWELVTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_79_0.memory.data_word=0xA; // THIRTEENTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.hetlabel_81_0.memory.data_word=0xA; // FOURTEENTH PULSE VALUE
e_HETPROGRAM0_UN.Program0_ST.PULSFIN_0.memory.data_word=0x5; // FIFTEENTH PULSE VALUE
But I get a load error now, so then I went into sys_comm_link and added:
_HETPROGRAM0_UN = 0xff460000;
e_HETPROGRAM0_UN = 0xff4601C0;
e_HETPROGRAM0_UN = 0xff4601E0;
e_HETPROGRAM0_UN = 0xff460200;
e_HETPROGRAM0_UN = 0xff460220;
e_HETPROGRAM0_UN = 0xff460240;
e_HETPROGRAM0_UN = 0xff460260;
e_HETPROGRAM0_UN = 0xff460280;
e_HETPROGRAM0_UN = 0xff4602A0;
e_HETPROGRAM0_UN = 0xff4602C0;
e_HETPROGRAM0_UN = 0xff4602E0;
e_HETPROGRAM0_UN = 0xff460300;
e_HETPROGRAM0_UN = 0xff460320;
e_HETPROGRAM0_UN = 0xff460340;
e_HETPROGRAM0_UN = 0xff460360;
e_HETPROGRAM0_UN = 0xff460370;
to refernce where all those pulse values should be, but I get a warning saying I'm redifining e_HETPROGRAM0_UN. And then I get a load error saying verification failed :
Values at address 0xF0407FF0 do not match Please verify target memory and memory map.
