ccslinker.opt issue in release build
 I am using CCS Version: 4.1.2.00027  and have created a projected called Maint which uses DSP BIOS 5. The project has a configuration file called Maint.tcf.
The debug build is fine, but when I build release version it fails giving me a load of symbol redifinition errors for all the symbols defined in the Maint.tcf file.
When I compare the linker.opts file for the debug and release version i find that the maint.cmd has been linked twice. Any ideas why this happens?
Here are the linker.opts file
Debug
-mv64+
-g
--define="_DEBUG" --define="TMSC64"
--diag_warning=225
--diag_suppress=1 --diag_suppress=9
-z
-m"DABC_Maint.map"
--warn_sections
-i"C:/Program Files/Texas Instruments/ccsv4/tools/compiler/c6000/lib" -i"C:/Program Files/Texas Instruments/ccsv4/tools/compiler/c6000/include" -i"C:/Program Files/Texas Instruments/bios_5_40_02_22/packages/ti/rtdx/lib/c6000" -i"C:/Program Files/Texas Instruments/bios_5_40_02_22/packages/ti/bios/lib"
--reread_libs
--rom_model
-l"./Maintcfg.cmd" "./Maintcfg_c.obj" "./Maintcfg.obj" "./source/file1.obj" "./source/fle2.obj" "./source/file3.obj" "./source/main.obj"  -l"rts64plus.lib" -l"C:\work\dsp\software\build\DABC\CodeComposerStudio\l_C64\Debug\l_C64.lib"  -l"C:/ti/C6400/dsplib/lib/dsp64x.lib"
Release
-mv64+
-g
-O2
--define="TMSC64"
--diag_warning=225
-z
-m"DABC_Maint.map"
--warn_sections
--reread_libs
--rom_model
-l"./Maintcfg.cmd" -l"./Maintcfg.cmd" "./Maintcfg_c.obj" "./Maintcfg.obj"  "./source/file1.obj" "./source/fle2.obj" "./source/file3.obj" "./source/main.obj"  -l"rts64plus.lib" -l"C:\work\dsp\software\build\DABC\CodeComposerStudio\l_C64\Debug\l_C64.lib"  -l"C:/ti/C6400/dsplib/lib/dsp64x.lib"
Thanks and Regards,
Pavan
