Other Parts Discussed in Thread: CODECOMPOSER, CCSTUDIO
Hi
I try to compile a Codecomposer Project (Version: 6.1.0.201502111100) using command line with the following command:
C:\ti\ccsv6\eclipse\eclipsec.exe -noSplash -data "C:\Data\workspace_v6_1_Unity" -application com.ti.ccstudio.apps.projectBuild -ccs.projects ProjectTemplate_Whitebox_Test
This results SOMETIMES in:
**** Build Finished ****
CCS headless build complete!
Job found still running after platform shutdown. Jobs should be canceled by the
plugin that scheduled them during shutdown: org.eclipse.cdt.internal.core.pdom.
PDOMIndexerJob$ProgressUpdateJob
The Workspace .log shows:
!ENTRY com.ti.common.core 4 0 2016-11-23 15:55:46.984 !MESSAGE path=ccs_base/DebugServer !ENTRY com.ti.common.core 4 0 2016-11-23 15:55:46.988 !MESSAGE debugServerDir=C:/ti/ccsv6/ccs_base/DebugServer !ENTRY org.eclipse.cdt.core 4 0 2016-11-23 15:55:54.405 !MESSAGE Error !STACK 0 java.lang.NullPointerException at com.ti.common.project.core.util.CTIProjectCoreUtils.getToolChainPropertyProvider(CTIProjectCoreUtils.java:411) at com.ti.common.project.core.util.CTIProjectCoreUtils.getLinkerTool(CTIProjectCoreUtils.java:450) at com.ti.ccstudio.project.core.internal.options.OutputFileOptionValueHandler.handleValue(OutputFileOptionValueHandler.java:49) at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.performValueHandlerEvent(ManagedBuildManager.java:3275) at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.performValueHandlerEvent(ManagedBuildManager.java:3227) at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.load(ConfigurationDataProvider.java:392) at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.loadConfiguration(ConfigurationDataProvider.java:557) at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.loadData(CConfigurationDescriptionCache.java:136) at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.loadDatas(CProjectDescription.java:196) at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.loadProjectDescription(XmlProjectDescriptionStorage.java:500) at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:237) at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:437) at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:419) at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:413) at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:406) at org.eclipse.cdt.internal.core.model.CProject.computeSourceRoots(CProject.java:585) at org.eclipse.cdt.internal.core.model.CProject.computeChildren(CProject.java:606) at org.eclipse.cdt.internal.core.model.CProject.buildStructure(CProject.java:570) at org.eclipse.cdt.internal.core.model.Openable.generateInfos(Openable.java:273) at org.eclipse.cdt.internal.core.model.CElement.openWhenClosed(CElement.java:427) at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:305) at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:295) at org.eclipse.cdt.internal.core.model.Parent.getChildren(Parent.java:55) at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:290) at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:267) at org.eclipse.cdt.internal.core.model.DeltaProcessor.createElement(DeltaProcessor.java:87) at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:453) at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:471) at org.eclipse.cdt.internal.core.model.DeltaProcessor.processResourceDelta(DeltaProcessor.java:433) at org.eclipse.cdt.internal.core.model.CModelManager.resourceChanged(CModelManager.java:900) at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285) at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149) at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:378) at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1498) at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:45) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.core.jobs 2 2 2016-11-23 15:55:54.727 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.cdt.internal.core.pdom.PDOMIndexerJob$ProgressUpdateJob
This leads to a return code of 0 interrupting the build server procedure. So I would appreciate any solution, even suppressing the error.
Regards Tobi
