CCS/TMS320C5515: How to halt watchdog timer during single step debug
Guru 15580 points
Part Number: TMS320C5515
I am running into a reset problem when single stepping through my code on my C5515 target. I have enabled the watchdog timer for normal operation, but would like to disable it during single stepping in debug. Is there a setting somewhere for this?
  • Mike,
    If you know what registers to write to you could try putting writes to those registers in a GEL OnHalt() function. If you click halt that function would run and disable the watchdog. You could create a second function to enable the watchdog and have it associated with a menu and you could run that when you want normal operation again.
    John
  • John,
    Thanks for the suggestion. I was hoping for a setting in CCS Project properties "Debug" settings that would automatically disable the WDT if checked. I guess this doesn't exist. It would certainly be a nice product enhancement...:)
