Part Number: CC2650
Hi, I'm new to using the CCS development environment, and I'm trying to build and load the TI simple_eddystone demo app so I can load onto the CC2650STK dev kit.
I'm getting a compiler error as below, there must be some file or folder path problem, but I don't know what, as far as I can tell the paths are okay ?
Please help.
Chris
undefined first referenced
symbol in file
GAP_EndDiscoverable ./ICallBLE/ble_dispatch.obj
GAP_MakeDiscoverable ./ICallBLE/ble_dispatch.obj
GAP_PeriConnRegister ./PROFILES/gap.obj
GAP_PeriDevMgrInit ./PROFILES/gap.obj
GAP_RemoveAdvToken ./ICallBLE/ble_dispatch.obj
GAP_SendSlaveSecurityRequest ./ICallBLE/ble_dispatch.obj
GAP_SetAdvToken ./ICallBLE/ble_dispatch.obj
GAP_UpdateAdvTokens ./ICallBLE/ble_dispatch.obj
GAP_UpdateAdvertisingData ./ICallBLE/ble_dispatch.obj
LL_EncLtkNegReply ./Startup/rom_jt.obj
LL_EncLtkReply ./Startup/rom_jt.obj
LL_SetAdvControl ./Startup/rom_jt.obj
LL_SetAdvParam ./Startup/rom_jt.obj
SM_ResponderInit ./PROFILES/gap.obj
llAdv_TaskConnect ./Startup/rom_jt.obj
llAdv_TaskEnd ./Startup/rom_jt.obj
llDirAdv_TaskEnd ./Startup/rom_jt.obj
llProcessSlaveControlPacket ./Startup/rom_jt.obj
llProcessSlaveControlProcedures ./Startup/rom_jt.obj
llSetupNextSlaveEvent ./Startup/rom_jt.obj
llSetupStartEncReq ./Startup/rom_jt.obj
llSlave_TaskEnd ./Startup/rom_jt.obj
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "simple_eddystone_cc2650lp_stack.out" not built
>> Compilation failure
makefile:191: recipe for target 'simple_eddystone_cc2650lp_stack.out' failed
gmake[2]: *** [simple_eddystone_cc2650lp_stack.out] Error 1
gmake[1]: *** [main-build] Error 2
makefile:187: recipe for target 'main-build' failed
makefile:182: recipe for target 'all' failed
gmake: *** [all] Error 2
Description Resource Path Location Type
gmake[2]: *** [simple_eddystone_cc2650lp_stack.out] Error 1 simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_EndDiscoverable, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_MakeDiscoverable, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_PeriConnRegister, first referenced in ./PROFILES/gap.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_PeriDevMgrInit, first referenced in ./PROFILES/gap.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_RemoveAdvToken, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_SendSlaveSecurityRequest, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_SetAdvToken, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_UpdateAdvertisingData, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol GAP_UpdateAdvTokens, first referenced in ./ICallBLE/ble_dispatch.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol LL_EncLtkNegReply, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol LL_EncLtkReply, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol LL_SetAdvControl, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol LL_SetAdvParam, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llAdv_TaskConnect, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llAdv_TaskEnd, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llDirAdv_TaskEnd, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llProcessSlaveControlPacket, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llProcessSlaveControlProcedures, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llSetupNextSlaveEvent, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llSetupStartEncReq, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol llSlave_TaskEnd, first referenced in ./Startup/rom_jt.obj simple_eddystone_cc2650lp_stack C/C++ Problem
unresolved symbol SM_ResponderInit, first referenced in ./PROFILES/gap.obj simple_eddystone_cc2650lp_stack C/C++ Problem
