CCS/TMS320F28377D: 2/9/2017 CCS update failed
Part Number: TMS320F28377D
Hello.  You can see the results of the attempted update below.  I retried the install several times, after disabling windows defender entirely.  CCS reports no new updates after checking again.
As you can see, it instructed me to post the install log files.  See attached.
!SESSION 2016-12-05 16:50:49.874 -----------------------------------------------
eclipse.buildId=4.5.1.M20150904-0015
java.version=1.7.0_80
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments:  -application com.ti.ccstudio.p2app -repository http://software-dl.ti.com/ccs/esd/CCSv6/CCS6.2.0.00050_win32/baserepo/idebuildRepo,http://software-dl.ti.com/ccs/esd/CCSv6/CCS6.2.0.00050_win32/featurerepo,http://software-dl.ti.com/ccs/esd/CCSv6/CCS6.2.0.00050_win32/baserepo/dvtRepo -installiu com.ti.ccstudio.c6000.feature.group,com.ti.ccstudio.c7000.feature.group,com.ti.tirex.feature.group,com.ti.dvt2.via.ccs.feature.group,com.ti.dvt2.profileanalysismanager.feature.group,com.ti.dvt2.uia.feature.group,com.ti.dvt2.analysis.suite.feature.group,com.ti.dvt.msp430.power.feature.group
Command-line arguments:  -os win32 -ws win32 -arch x86 -application com.ti.ccstudio.p2app -repository http://software-dl.ti.com/ccs/esd/CCSv6/CCS6.2.0.00050_win32/baserepo/idebuildRepo,http://software-dl.ti.com/ccs/esd/CCSv6/CCS6.2.0.00050_win32/featurerepo,http://software-dl.ti.com/ccs/esd/CCSv6/CCS6.2.0.00050_win32/baserepo/dvtRepo -installiu com.ti.ccstudio.c6000.feature.group,com.ti.ccstudio.c7000.feature.group,com.ti.tirex.feature.group,com.ti.dvt2.via.ccs.feature.group,com.ti.dvt2.profileanalysismanager.feature.group,com.ti.dvt2.uia.feature.group,com.ti.dvt2.analysis.suite.feature.group,com.ti.dvt.msp430.power.feature.group
!ENTRY org.eclipse.equinox.p2.operations 2 10005 2016-12-05 16:51:05.578
!MESSAGE "Analysis Suite" will be ignored because it is already installed.
3007.ccs_setup_6.2.0.00050_install.logti_cgt_c6000_8.1.3_windows_installer_install.log
Log started 02/09/2017 at 13:41:08
Preferred installation mode : unattended
Trying to init installer in mode unattended
Mode unattended successfully initialized
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08]
[13:41:08] Beginning Installation of MSVC Redistributable Packages
Preparing to Install
Directory already exists: C:\ti\ccsv6\ccs_base\common\bin
Unpacking files
Unpacking C:\ti\ccsv6\ccs_base\common\bin\ti_targetdb_parser.dll
File is locked. Failed to overwrite C:/ti/ccsv6/ccs_base/common/bin/ti_targetdb_parser.dll
Error copying file from packed archive C:/ti/ccsv6/eclipse/downloads/ti_emupack_setup_6.0.504.4_win_32.exe to C:/ti/ccsv6/ccs_base/common/bin/ti_targetdb_parser.dll
There has been an error.
Unable to copy file
  • Hi Stephen,
    Sorry for the delayed response. Your logs indicate that one of the components was corrupted while downloading and was unable to install. I would recommend either using the offline installer or upgrading to CCS 7.1.0 which has more robust checking. Please delete the contents of c:\ti\ccsv6 before attempting the installation again.
    Danish
