Compiler/TMS320F2810: Assembler Code generated
Part Number: TMS320F2810
I am migrating a F2810 project from CCS 3.3 to CCS 7.
In order to feel comfortable with the conversion, I plan to:
- generate assembler listings with both compilers
- plan to compare the assember listings
- review the differences (hopefully nothing except compilation date/time)
Am I on the right track? What are the holes in this approach?
thanks, srini
    Which means your compiler version changes too.  By many years.
    You will see many differences.  Any change in compiler version can cause such differences.  But a major change like this will see that many more.
    I suppose you could consider using the old CCS 3.3 compiler with CCS 7.  That combination has not been tested.  It might work OK.  But I suspect you will have some issues.  And that will force you to use the compiler that comes with CCS 7.
    Thanks and regards,
    -George
