CCS/TMS320C6748: TMS320C6748
Part Number: TMS320C6748
I installed Code Composer Studio 7.0.0  in a PC with Windows 7 Professional. When "building all" I am getting the following error:
  • Program "E:/ccsv7/utils/bin/gmake" is not found in PATH  also
  • .h file cannot be open
i have go  througth the previous posts .. i tried ..again getting the same error
please give some suggestion.
thanking you,
bhuvana
student
    A common cause of this error is system security software blocking access (antivirus). Did you try disabling it?
    Also make sure that gmake exe does reside the path specified and also check your PATH to make sure there is no conflict with other gmake exe onat may be on the PATH.
    ki
  • Hi sir,
    thank u for ur quick response...sir, i reinstalled the code composer studio by disabling the antivirus..it worked for the example "hello world "program and some other program..without any gmake error..since i m interested in converting a matlab simulink model to .c file and try to run on the ccs studio version 7...again its giving a same error!!!i.e gmake error and the another error stated ,"cannot open source file "filename.h"..!!..please suggest some solution sir..
    thanking u,
    regards,
    bhuvana
    student
  • Please provide a screenshot of the gmake error.
    As for the "cannot open source file "filename.h" error, please see:
    processors.wiki.ti.com/.../Build_Errors_in_CCS
    ki
  • Thanks a lot ki sir...
    I have resolved the problems regarding "gmake" error as well as  the "filename.h" error by following your  instructions..It helped me a lot sir...thanks once again:-)
    regards,
    bhuvana
