CCS: Installation Error
Other Parts Discussed in Thread: CCSTUDIO
Good Day Everyone,
I tried to install CCS v6 on my Window 8 laptop.  During installation, i encountered an Eclipse Error
Below is the .metadata/.log. details:
!SESSION 2017-03-02 14:18:56.626 -----------------------------------------------
eclipse.buildId=4.5.1.M20150904-0015
java.version=1.7.0_80
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_SG
Framework arguments: -application com.ti.common.core.initialize -ccs.profileTag Installed Code Composer Studio 6.1.3.00033.
Command-line arguments: -os win32 -ws win32 -arch x86 -application com.ti.common.core.initialize -data C:/Users/Lim/AppData/Local/Temp/ccs_bd469b8c-e472-460f-44a5-a8c9d8191e28/workspace -ccs.profileTag Installed Code Composer Studio 6.1.3.00033.
!ENTRY com.ti.common.core 4 0 2017-03-02 14:19:00.208
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 4 0 2017-03-02 14:19:00.209
!MESSAGE debugServerDir=C:/ti/ccsv6/ccs_base/DebugServer
!ENTRY org.eclipse.core.jobs 4 2 2017-03-02 14:19:01.614
!MESSAGE An internal error occurred during: "CrashTrackerJob".
!STACK 0
java.lang.UnsatisfiedLinkError: C:\ti\ccsv6\ccs_base\DebugServer\bin\LibraryLoader.dll: Can't find dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1965)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1890)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1851)
at java.lang.Runtime.load0(Runtime.java:795)
at java.lang.System.load(System.java:1062)
at com.ti.debug.engine.xpcom.Runtime.preXPCOMInit(Runtime.java:163)
at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:116)
at com.ti.debug.engine.xpcom.Runtime.createComponent(Runtime.java:170)
at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:26)
at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:9)
at com.ti.utility.filesystem.DirectoryService$SingletonHolder.<clinit>(DirectoryService.java:44)
at com.ti.utility.filesystem.DirectoryService.instance(DirectoryService.java:49)
at com.ti.ccstudio.debug.server.DebugServerPlugin$1.run(DebugServerPlugin.java:117)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY org.eclipse.osgi 4 0 2017-03-02 14:19:03.454
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: Could not initialize class com.ti.utility.filesystem.DirectoryService$SingletonHolder
at com.ti.common.core.utils.ds.CoreUtilsProvider.getUserHomeDir(CoreUtilsProvider.java:40)
at com.ti.common.core.CoreUtils.getUserHomeDir(CoreUtils.java:135)
at com.ti.common.core.internal.ExternalReferenceParser.getUserExtRefDir(ExternalReferenceParser.java:176)
at com.ti.common.core.internal.ExternalReferenceParser.getExtRefDirectories(ExternalReferenceParser.java:158)
at com.ti.common.core.internal.ExternalReferenceParser.getReferenceFiles(ExternalReferenceParser.java:61)
at com.ti.common.core.internal.ExternalReferenceParser.getReferenceFiles(ExternalReferenceParser.java:147)
at org.eclipse.rtsc.xdctools.managedbuild.core.products.RTSCProductDiscoveryManager.getExtensionSiteDiscoveryPath(RTSCProductDiscoveryManager.java:457)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.getUserSearchPath(ExtensionSiteDiscoveryManager.java:122)
at org.eclipse.rtsc.project.core.extdiscovery.ProductManifestRegistry.<init>(ProductManifestRegistry.java:84)
at org.eclipse.rtsc.project.core.extdiscovery.ProductManifestRegistry.<clinit>(ProductManifestRegistry.java:73)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.collectExtensionSiteDirsToAdd(ExtensionSiteDiscoveryManager.java:749)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.createExtensionSites(ExtensionSiteDiscoveryManager.java:214)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.createAndAddExtensionSites(ExtensionSiteDiscoveryManager.java:169)
at org.eclipse.rtsc.project.core.extdiscovery.RTSCIDEInitializationParticipant.run(RTSCIDEInitializationParticipant.java:89)
at com.ti.common.core.internal.headless.Initialize.run(Initialize.java:45)
at com.ti.common.core.internal.headless.Initialize.start(Initialize.java:32)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
I tried to find many solution to solve it but it doesn't work.
I need to solve this issue quickly as I have to submit my project soon.
Please help me.
Thanks alot.
    !STACK 0
    Please see this wiki section for details on what could trigger this error and how to resolve (the error could occur during installation or startup of CCS).
    You may need to re-install CCS after installing the MSVC libraries. If so, make sure to completely delete the current installation directory before reinstalling.
    Let us know if it helps resolve the error.
