Part Number: MSP430G2553
I wanted to know hoe to store float value into flash, into 2 words or 4 bytes?
thank you all.
thank you all.
Hello Joe,
I am confused. In your initial post, you said you wanted to place the floating point number in flash. Adding const to the variable declaration will place the variable in flash.
Could you please post a small snippet of code that shows what you are currently doing.
Stephen
here's an example of writing char data into memory
void WriteToFlash(char* address, char val)
char* flash_ptr;
FCTL3 = FWKEY;
flash_ptr = address; // Initialize Flash pointer
while(FCTL3 & BUSY);
FCTL1 = FWKEY + WRT;
*flash_ptr = val;
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCK; // Set LOCK bit
her's another example to write long data:
WriteShortToFlash((short*)MEM_SLOPE_H,(short)(wt_slope & 0xFFFF));// Slope
WriteShortToFlash((short*)MEM_SLOPE_L,(short)((wt_slope >> 16) & 0xFFFF));// Slope
void WriteShortToFlash(short* address, short val)
short* flash_ptr;
FCTL3 = FWKEY;
*flash_ptr = val;
I want to know how to write a float to memory
Thank you for your help
Ok. I think the following should work.
Stephen
float var1 = 3.14159;
unsigned long int wt_slope;
int main(void)
wt_slope = *(unsigned long int*)&var1;
