I am trying to build a DWT (discrete wavelet transform ) application for TMDSEVM6472 using Code Composer 4
The code is attached below
i get this error "errors encountered during linking" and i have no clue how to solve it ..i googled the problem and as i read from simular situations it's related to the size of memory. is that so ? and if it 'is how can'i solved it ?
* dwt.c - code for discrete wavelet transform
* (symmetric interpolating biorthogonal wavelets using the lifting transform)
* Copyright (c) 2000-2003 by Tom Schouten
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
#include "m_pd.h"
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define MAXORDER 64
typedef enum{DWT,IDWT,DWT16,IDWT16} t_dwttype;
typedef struct dwtctl
t_float c_update[MAXORDER];
t_float c_predict[MAXORDER];
int c_nupdate;
int c_npredict;
int c_levels;
int c_fakein;
t_float c_fakeval;
int c_mask;
char c_name[16];
int *c_clutter;
int *c_unclutter;
int c_permute;
t_dwttype c_type;
} t_dwtctl;
typedef struct dwt
t_object x_obj;
t_float x_f;
t_dwtctl x_ctl;
} t_dwt;
static void dwt_even(t_dwt *x, t_floatarg f)
int k = (int)f;
int i, j;
float *p = x->x_ctl.c_predict;
float *u = x->x_ctl.c_update;
float l, xi, xj;
if ((k>0) && (k<MAXORDER/2))
for (i=0; i<k; i++){
l = 1;
xi = 1+2*i;
for (j=0; j<k; j++)
xj = 1+2*j;
if (i != j) l /= (1 - ((xi*xi) / (xj*xj)));
l *= .5;
p[k-i-1] = l;
p[k+i] = l;
u[k-i-1] = l/2;
u[k+i] = l/2;
x->x_ctl.c_npredict = 2*k;
x->x_ctl.c_nupdate = 2*k;
#if 0
static void dwt_wavelet(t_dwt *x, t_floatarg f)
int k = (int)f;
t_float *p = x->x_ctl.c_predict;
t_float *u = x->x_ctl.c_update;
int *np = &x->x_ctl.c_npredict;
int *nu = &x->x_ctl.c_nupdate;
switch(k)
default:
case 1: /* haar */
*np = *nu = 2; /* actual order is one */
p[0] = 1;
p[1] = 0;
u[0] = 0;
u[1] = .5;
break;
case 2: /* hat */
case 3:
*np = *nu = 2;
p[0] = .5;
p[1] = .5;
u[0] = .25;
u[1] = .25;
break;
case 4: /* N = 4, N~ = 4 */
case 5:
*np = *nu = 4;
p[0] = -0.0625;
p[1] = 0.5625;
p[2] = 0.5625;
p[3] = -0.0625;
u[0] = -0.03125;
u[1] = 0.28125;
u[2] = 0.28125;
u[3] = -0.03125;
break;
case 6:
case 7:
*np = *nu = 6;
p[0] = 0.01171875000000;
p[1] = -0.09765625000000;
p[2] = 0.58593750000000;
p[3] = 0.58593750000000;
p[4] = -0.09765625000000;
p[5] = 0.01171875000000;
u[0] = 0.00585937500000;
u[1] = -0.04882812500000;
u[2] = 0.29296875000000;
u[3] = 0.29296875000000;
u[4] = -0.04882812500000;
u[5] = 0.00585937500000;
break;
#endif
static inline void dwt_perform_permutation(t_float *S, int n, int *f)
int k,l;
t_float swap;
for(k=0; k<n; k++)
l = f[k];
while (l<k) l = f[l];
swap = S[k];
S[k] = S[l];
S[l] = swap;
static void dwt_permutation(t_dwt *x, int n){
t_dwtctl *ctl = &x->x_ctl;
int k, L=0, l, start, power;
int nsave = n;
while(nsave>>=1) L++;
if (ctl->c_clutter) free(ctl->c_clutter);
if (ctl->c_unclutter) free(ctl->c_unclutter);
ctl->c_clutter = (int *)malloc(n*sizeof(int));
ctl->c_unclutter = (int *)malloc(n*sizeof(int));
for(l = L, start = n/2, power=1; l>0; l--, start /=2, power *=2)
for(k=0; k<start; k++)
ctl->c_unclutter[start+k] = (1 + 2*k) * power;
ctl->c_unclutter[0] = 0;
for(k=0; k<n; k++)
ctl->c_clutter[ctl->c_unclutter[k]] = k;
return;
/* debug */
for(k=0; k<n; k++)
printf("clutter[%d] = %d\n", (int)k, (int)ctl->c_clutter[k]);
for(k=0; k<n; k++)
printf("unclutter[%d] = %d\n", (int)k, (int)ctl->c_unclutter[k]);
exit(1);
static void idwt_coef(t_dwt *x, t_floatarg index, t_floatarg value)
x->x_ctl.c_fakein = (int)index;
x->x_ctl.c_fakeval = value;
static void dwt_print(t_dwt *x)
int i;
printf("%s: predict: [ ", x->x_ctl.c_name);
for (i=0; i<x->x_ctl.c_npredict; i++) printf("%f ", x->x_ctl.c_predict[i]);
printf("], ");
printf("update: [ ");
for (i=0; i<x->x_ctl.c_nupdate; i++) printf("%f ", x->x_ctl.c_update[i]);
printf("]\n");
static void dwt_filter(t_dwt *x, t_symbol *s, int argc, t_atom *argv)
int invalid_argument = 0;
int i;
char *name = x->x_ctl.c_name;
float *pfilter = x->x_ctl.c_predict;
float *ufilter = x->x_ctl.c_update;
float *mask = NULL;
int *length = NULL;
float sum = 0;
if (s == gensym("predict"))
mask = pfilter;
length = &(x->x_ctl.c_npredict);
else if (s == gensym("update"))
mask = ufilter;
length = &(x->x_ctl.c_nupdate);
else if (s == gensym("mask"))
mask = NULL;
else
return;
if (argc >= MAXORDER) post("%s: error, maximum order exceeded.",name);
else if ((x->x_ctl.c_type == DWT16 || x->x_ctl.c_type == IDWT16 ) && (argc != 16))
post("%s: error, need to have 16 coefficients.",name);
else if (argc == 0) post("%s: no arguments given.",name);
else if (argc & 1) post("%s: error, only an even number of coefficients is allowed.", name);
else
for (i=0; i<argc; i++){
if (argv[i].a_type != A_FLOAT )
invalid_argument = 1;
break;
if (invalid_argument) post("%s: invalid argument, must be a number.", name);
else
if (mask) /* one of update / predict */
for (i=0; i<argc; i++) mask[i] = argv[i].a_w.w_float;
*length = argc;
else /* both + normalization */
for (i=0; i<argc; i++) sum += argv[i].a_w.w_float;
pfilter[i] = argv[i].a_w.w_float / sum;
ufilter[i] = argv[i].a_w.w_float / (sum*2);
x->x_ctl.c_npredict = argc;
x->x_ctl.c_nupdate = argc;
static inline void dwtloop(float *vector,
int source,
int dest,
int increment,
int backup,
int numcoef,
int mask,
float *filter,
int filtlength,
float sign)
int k,m;
float acc;
for (k = 0; k < numcoef; k++)
acc = 0;
for (m = 0; m < filtlength; m++)
acc += filter[m] * vector[source];
source += increment;
source &= mask;
vector[dest] += sign * acc;
dest += increment;
source -= backup;
source &= mask;
static inline void dwtloop16(float *vector,
int source,
int dest,
int increment,
int backup,
int numcoef,
int mask,
float *filter,
int filtlength __attribute__((__unused__)), /* ignored, set to 16 */
float sign)
int k;
float acc;
acc = 0;
acc += filter[0] * vector[source];
source &= mask;
acc += filter[1] * vector[source];
source &= mask;
acc += filter[2] * vector[source];
source &= mask;
acc += filter[3] * vector[source];
source &= mask;
acc += filter[4] * vector[source];
source &= mask;
acc += filter[5] * vector[source];
source &= mask;
acc += filter[6] * vector[source];
source &= mask;
acc += filter[7] * vector[source];
source &= mask;
acc += filter[8] * vector[source];
source &= mask;
acc += filter[9] * vector[source];
source &= mask;
acc += filter[10] * vector[source];
source &= mask;
acc += filter[11] * vector[source];
source &= mask;
acc += filter[12] * vector[source];
source &= mask;
acc += filter[13] * vector[source];
source &= mask;
acc += filter[14] * vector[source];
source &= mask;
acc += filter[15] * vector[source];
source &= mask;
dest += increment;
source -= backup;
source &= mask;
static t_int *dwt_perform(t_int *w)
t_float *in = (float *)(w[3]);
t_float *out = (float *)(w[4]);
t_dwtctl *ctl = (t_dwtctl *)(w[1]);
int n = (int)(w[2]);
int i;
int numcoef = n/2;
/* int source_u = ((1 - ctl->c_nupdate)/2 - 1);
* int source_p = ((1 - ctl->c_npredict)/2);
int source_u = ((2 - ctl->c_nupdate) - 1);
int source_p = ((2 - ctl->c_npredict));
int increment = 2;
int dest = 1;
int backup_u = (ctl->c_nupdate-1)*2;
int backup_p = (ctl->c_npredict-1)*2;
/* copy input to output */
if (in != out)
for (i=0; i<n; i++) out[i]=in[i];
/* fake input */
/* for (i=0; i<n; i++) out[i]=0; out[n/8]=1;*/
/* backward transform */
/* iterate over all levels */
for (i=0; i < ctl->c_levels; i++){
/* foreward predict */
dwtloop(out, (source_p & (n-1)), dest, increment, backup_p, numcoef, n-1, ctl->c_predict, ctl->c_npredict, -1);
/* foreward update */
dwtloop(out, (source_u & (n-1)), 0, increment, backup_u, numcoef, n-1, ctl->c_update, ctl->c_nupdate, +1);
/* update control parameters */
numcoef /= 2;
source_p *= 2;
source_u *= 2;
backup_p *= 2;
backup_u *= 2;
increment *= 2;
dest *= 2;
if (ctl->c_permute)
dwt_perform_permutation(out, n, ctl->c_unclutter);
return (w+5);
static t_int *idwt_perform(t_int *w)
int i;
int numcoef = 1;
int source_u = ((2 - ctl->c_nupdate) - 1) * (n/2);
int source_p = ((2 - ctl->c_npredict)) * (n/2);
int increment = n;
int dest = n/2;
int backup_u = (ctl->c_nupdate-1)*n;
int backup_p = (ctl->c_npredict-1)*n;
int fake_in = ctl->c_fakein;
float fake_val = ctl->c_fakeval;
if (in != out)
/* fake input */
if ((fake_in >= 0) && (fake_in<n)){
out[fake_in]=fake_val;
if (ctl->c_permute)
dwt_perform_permutation(out, n, ctl->c_clutter);
/* backward update */
dwtloop(out, (source_u & (n-1)), 0, increment, backup_u, numcoef, n-1, ctl->c_update, ctl->c_nupdate, -1);
/* backward predict */
dwtloop(out, (source_p & (n-1)), dest, increment, backup_p, numcoef, n-1, ctl->c_predict, ctl->c_npredict, +1);
numcoef *= 2;
source_p /= 2;
source_u /= 2;
backup_p /= 2;
backup_u /= 2;
increment /= 2;
dest /= 2;
return (w+5);
static t_int *dwt16_perform(t_int *w)
int i;
int numcoef = n/2;
int increment = 2;
int dest = 1;
if (in != out)
/* fake input */
dwtloop16(out, (source_p & (n-1)), dest, increment, backup_p, numcoef, n-1, ctl->c_predict, 16, -1);
dwtloop16(out, (source_u & (n-1)), 0, increment, backup_u, numcoef, n-1, ctl->c_update, 16, +1);
numcoef /= 2;
source_p *= 2;
source_u *= 2;
backup_p *= 2;
backup_u *= 2;
increment *= 2;
dest *= 2;
if (ctl->c_permute)
return (w+5);
static t_int *idwt16_perform(t_int *w)
int i;
int numcoef = 1;
int increment = n;
int dest = n/2;
if (in != out)
/* fake input */
if (ctl->c_permute)
dwtloop16(out, (source_u & (n-1)), 0, increment, backup_u, numcoef, n-1, ctl->c_update, 16, -1);
dwtloop16(out, (source_p & (n-1)), dest, increment, backup_p, numcoef, n-1, ctl->c_predict, 16, +1);
numcoef *= 2;
source_p /= 2;
source_u /= 2;
backup_p /= 2;
backup_u /= 2;
increment /= 2;
dest /= 2;
return (w+5);
static void dwt_dsp(t_dwt *x, t_signal **sp)
int n = sp[0]->s_n;
int ln = 0;
dwt_permutation(x, n);
x->x_ctl.c_mask = n-1;
while (n >>= 1) ln++;
x->x_ctl.c_levels = ln;
switch(x->x_ctl.c_type){
case DWT:
dsp_add(dwt_perform, 4, &x->x_ctl, sp[0]->s_n, sp[0]->s_vec, sp[1]->s_vec);
break;
case IDWT:
dsp_add(idwt_perform, 4, &x->x_ctl, sp[0]->s_n, sp[0]->s_vec, sp[1]->s_vec);
break;
case DWT16:
dsp_add(dwt16_perform, 4, &x->x_ctl, sp[0]->s_n, sp[0]->s_vec, sp[1]->s_vec);
break;
case IDWT16:
dsp_add(idwt16_perform, 4, &x->x_ctl, sp[0]->s_n, sp[0]->s_vec, sp[1]->s_vec);
break;
void dwt_free(t_dwt *x)
if (x->x_ctl.c_clutter) free(x->x_ctl.c_clutter);
if (x->x_ctl.c_unclutter) free(x->x_ctl.c_unclutter);
t_class *dwt_class, *idwt_class, *dwt16_class, *idwt16_class;
static void dwt_reset(t_dwt *x)
bzero(x->x_ctl.c_update, 16*sizeof(t_float));
bzero(x->x_ctl.c_predict, 16*sizeof(t_float));
x->x_ctl.c_update[7] = .25;
x->x_ctl.c_update[8] = .25;
x->x_ctl.c_nupdate = 16;
x->x_ctl.c_predict[7] = .5;
x->x_ctl.c_predict[8] = .5;
x->x_ctl.c_npredict = 16;
x->x_ctl.c_fakein = -1;
x->x_ctl.c_fakeval = 0;
static void *dwt_new_common(t_floatarg permute)
t_dwt *x = (t_dwt *)pd_new(dwt_class);
outlet_new(&x->x_obj, gensym("signal"));
/* init data */
dwt_reset(x);
x->x_ctl.c_clutter = NULL;
x->x_ctl.c_unclutter = NULL;
x->x_ctl.c_permute = (int) permute;
return (void *)x;
static void *dwt_new(t_floatarg permute)
t_dwt *x = dwt_new_common(permute);
sprintf(x->x_ctl.c_name,"dwt");
x->x_ctl.c_type = DWT;
return (void *)x;
static void *idwt_new(t_floatarg permute)
sprintf(x->x_ctl.c_name,"idwt");
x->x_ctl.c_type = IDWT;
return (void *)x;
static void *dwt16_new(t_floatarg permute)
sprintf(x->x_ctl.c_name,"dwt16");
x->x_ctl.c_type = DWT16;
return (void *)x;
static void *idwt16_new(t_floatarg permute)
sprintf(x->x_ctl.c_name,"idwt16");
x->x_ctl.c_type = IDWT16;
return (void *)x;
void dwt_tilde_setup(void)
//post("dwt~ v0.1");
dwt_class = class_new(gensym("dwt~"), (t_newmethod)dwt_new,
(t_method)dwt_free, sizeof(t_dwt), 0, A_DEFFLOAT, 0);
CLASS_MAINSIGNALIN(dwt_class, t_dwt, x_f);
class_addmethod(dwt_class, (t_method)dwt_print, gensym("print"), 0);
class_addmethod(dwt_class, (t_method)dwt_reset, gensym("reset"), 0);
class_addmethod(dwt_class, (t_method)dwt_dsp, gensym("dsp"), 0);
class_addmethod(dwt_class, (t_method)dwt_filter, gensym("predict"), A_GIMME, 0);
class_addmethod(dwt_class, (t_method)dwt_filter, gensym("update"), A_GIMME, 0);
class_addmethod(dwt_class, (t_method)dwt_filter, gensym("mask"), A_GIMME, 0);
class_addmethod(dwt_class, (t_method)dwt_even, gensym("even"), A_DEFFLOAT, 0);
class_addmethod(dwt_class, (t_method)idwt_coef, gensym("coef"), A_DEFFLOAT, A_DEFFLOAT, 0);
/*class_addmethod(dwt_class, (t_method)dwt_wavelet, gensym("wavelet"), A_DEFFLOAT, 0); */
idwt_class = class_new(gensym("idwt~"), (t_newmethod)idwt_new,
CLASS_MAINSIGNALIN(idwt_class, t_dwt, x_f);
class_addmethod(idwt_class, (t_method)dwt_print, gensym("print"), 0);
class_addmethod(idwt_class, (t_method)dwt_dsp, gensym("dsp"), 0);
class_addmethod(idwt_class, (t_method)dwt_filter, gensym("predict"), A_GIMME, 0);
class_addmethod(idwt_class, (t_method)dwt_filter, gensym("update"), A_GIMME, 0);
class_addmethod(idwt_class, (t_method)dwt_filter, gensym("mask"), A_GIMME, 0);
class_addmethod(idwt_class, (t_method)idwt_coef, gensym("coef"), A_DEFFLOAT, A_DEFFLOAT, 0);
class_addmethod(idwt_class, (t_method)dwt_even, gensym("even"), A_DEFFLOAT, 0);
dwt16_class = class_new(gensym("dwt16~"), (t_newmethod)dwt16_new,
CLASS_MAINSIGNALIN(dwt16_class, t_dwt, x_f);
class_addmethod(dwt16_class, (t_method)dwt_print, gensym("print"), 0);
class_addmethod(dwt16_class, (t_method)dwt_reset, gensym("reset"), 0);
class_addmethod(dwt16_class, (t_method)dwt_dsp, gensym("dsp"), 0);
class_addmethod(dwt16_class, (t_method)dwt_filter, gensym("predict"), A_GIMME, 0);
class_addmethod(dwt16_class, (t_method)dwt_filter, gensym("update"), A_GIMME, 0);
class_addmethod(dwt16_class, (t_method)dwt_filter, gensym("mask"), A_GIMME, 0);
idwt16_class = class_new(gensym("idwt16~"), (t_newmethod)idwt16_new,
CLASS_MAINSIGNALIN(idwt16_class, t_dwt, x_f);
class_addmethod(idwt16_class, (t_method)dwt_print, gensym("print"), 0);
class_addmethod(idwt16_class, (t_method)dwt_dsp, gensym("dsp"), 0);
class_addmethod(idwt16_class, (t_method)dwt_filter, gensym("predict"), A_GIMME, 0);
class_addmethod(idwt16_class, (t_method)dwt_filter, gensym("update"), A_GIMME, 0);
class_addmethod(idwt16_class, (t_method)dwt_filter, gensym("mask"), A_GIMME, 0);
class_addmethod(idwt16_class, (t_method)idwt_coef, gensym("coef"), A_DEFFLOAT, A_DEFFLOAT, 0);
