CCS/CCSTUDIO-C2000: Is it possible to build the same image file between CCSV4 and CCSV7
Part Number: CCSTUDIO-C2000
I tried to updated my project from using CCSV4 to CCSV7. To begin in CCSV7, the expectation is to generate the same image file from the original CCSV4 to CCSV7. Is it possible?
What I use:
CCSV4: Version 4.1.2.00027---attached configuration file
CCSV7: Version 7.1.0.00014---attached configuration file
I used original .c and .h files to setup project in CCSV7, built and generated a image file. But I compared the image files between CCSV4 and CCSV7, they are very different. Attached both here
I also noticed that the object file related to .c and .asm is different too between two IDE version.
In CCSV7, I tried to used the same Code Generation tools chain as CCSV4, which is TI v5.2.3, but the image file still is different.
Is it possible to build the same image file between CCSV4 and  CCSV7? What do I need to pay attention to do it?
Gansheng
    The key thing is to make sure the code generation tools and build options are the same. While you are using the same code generation tools, are you making sure that the same exact build options are being used? The default build options used in v4 may differ in v7. Check your build output to see what options are passed to the compiler. Another thing to check is the linker command file. Your projects likely use the cmd file that comes with CCS and v7 might come with a newer version than v4. Also if you have any other dependencies (like BIOS), make sure those are the same.
    Hope this helps
    ki
  • I can the image file extension from .img to txt
    nga_ccsv4.txt
  • Thank,
    Based on your comment, it looks it is possible to generate the same image file. Right?
  • Yes, the key thing is the same build tools version, same build options, and same source files (including *.cmd files and *.header files). Note that the object files may differ slightly. This is because the debug symbols themselves may be slightly different - the symbols might have some debug path information that can be different for example. But this would not impact that actual generated target code
    I am sure below items are the same between CCSV4 and CCSV7: code generation tools, and the same .c, .h and .cmd files. I also checked every build options to make them the same. The only build option I can not change is:
    gmake -k,----CCSV4
    gmake -k -j 2 ---- CCSV7
    Even I manually changed to "gmake -k" in CCSV7, when it ran, it changed back to "gmake -k -j 2". The build output image is still different.
    Would you think it affect the result?
    Gansheng
    To get rid of the -j option, disable parallel builds in your project properties:
    There is a chance it could have some impact. Try disabling it and rebuild.
    ki
  • Is there any difference of gmake.exe between CCS V4  and V7?
    In CCS V7, when it points to CCS V4 gmake.exe, it does not compile the first .asm file:DSP2833x_CodeStartBranch.asm, which initialize stateup pointer.
  • The versions are different
    CCSv4.2.5 comes with gmake version 3.8
    CCSv7.2.0 comes with gmake version 4.1
  • When I use CCS V4 with compile version TI v5.2.3, the different build generates the same .img file.
    But if use CCS V7 with compile version TI v5.2.3, the different build generates the .img file with a little bit difference as attached. What that happen, and how to make it the same .img file?
    nga_build1.txtnga.build2.txt
  • Can you provide all the build output messages from both the v4 and v7 builds?
  • Attached CCS V4 and V7 build log files. Both build on the same project base, and V7 set to use V4 tool chain TI 5.2.3. If you need other info, can you please let me know.
    **** Build of configuration Prod_Flash_Debug for project nga ****
    "C:\\ti\\ccsv7\\utils\\bin\\gmake" -k all
    'Building file: ../DSP2833x_CodeStartBranch.asm'
    'Invoking: C2000 Compiler'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="DSP2833x_CodeStartBranch.d"  "../DSP2833x_CodeStartBranch.asm"
    'Finished building: ../DSP2833x_CodeStartBranch.asm'
    'Building file: ../DSP2833x_GlobalVariableDefs.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="DSP2833x_GlobalVariableDefs.d"  "../DSP2833x_GlobalVariableDefs.c"
    'Finished building: ../DSP2833x_GlobalVariableDefs.c'
    'Building file: ../DSP2833x_usDelay.asm'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="DSP2833x_usDelay.d"  "../DSP2833x_usDelay.asm"
    'Finished building: ../DSP2833x_usDelay.asm'
    'Building file: ../_prtfi.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="_prtfi.d"  "../_prtfi.c"
    'Finished building: ../_prtfi.c'
    'Building file: ../ad7805.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="ad7805.d"  "../ad7805.c"
    'Finished building: ../ad7805.c'
    'Building file: ../adc.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="adc.d"  "../adc.c"
    'Finished building: ../adc.c'
    'Building file: ../capture.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="capture.d"  "../capture.c"
    'Finished building: ../capture.c'
    'Building file: ../capture_def.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="capture_def.d"  "../capture_def.c"
    'Finished building: ../capture_def.c'
    'Building file: ../commands.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="commands.d"  "../commands.c"
    'Finished building: ../commands.c'
    'Building file: ../control.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="control.d"  "../control.c"
    'Finished building: ../control.c'
    'Building file: ../control_def.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="control_def.d"  "../control_def.c"
    'Finished building: ../control_def.c'
    'Building file: ../dsplink.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="dsplink.d"  "../dsplink.c"
    'Finished building: ../dsplink.c'
    'Building file: ../dsplink_def.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="dsplink_def.d"  "../dsplink_def.c"
    'Finished building: ../dsplink_def.c'
    'Building file: ../fanspeed.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="fanspeed.d"  "../fanspeed.c"
    'Finished building: ../fanspeed.c'
    'Building file: ../fifo.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="fifo.d"  "../fifo.c"
    'Finished building: ../fifo.c'
    'Building file: ../i2c.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="i2c.d"  "../i2c.c"
    'Finished building: ../i2c.c'
    'Building file: ../lcd.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="lcd.d"  "../lcd.c"
    'Finished building: ../lcd.c'
    'Building file: ../log.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="log.d"  "../log.c"
    'Finished building: ../log.c'
    'Building file: ../log_def.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="log_def.d"  "../log_def.c"
    'Finished building: ../log_def.c'
    'Building file: ../memtest.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="memtest.d"  "../memtest.c"
    'Finished building: ../memtest.c'
    'Building file: ../nga.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nga.d"  "../nga.c"
    'Finished building: ../nga.c'
    'Building file: ../nga_init.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nga_init.d"  "../nga_init.c"
    'Finished building: ../nga_init.c'
    'Building file: ../nga_systemlog.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nga_systemlog.d"  "../nga_systemlog.c"
    'Finished building: ../nga_systemlog.c'
    'Building file: ../nvram.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nvram.d"  "../nvram.c"
    'Finished building: ../nvram.c'
    'Building file: ../prntf.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="prntf.d"  "../prntf.c"
    'Finished building: ../prntf.c'
    'Building file: ../root.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="root.d"  "../root.c"
    'Finished building: ../root.c'
    'Building file: ../rs485.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="rs485.d"  "../rs485.c"
    'Finished building: ../rs485.c'
    'Building file: ../rs485_tcnsl.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="rs485_tcnsl.d"  "../rs485_tcnsl.c"
    'Finished building: ../rs485_tcnsl.c'
    'Building file: ../snprntf.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="snprntf.d"  "../snprntf.c"
    'Finished building: ../snprntf.c'
    'Building file: ../spi.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="spi.d"  "../spi.c"
    'Finished building: ../spi.c'
    'Building file: ../spidataflash.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="spidataflash.d"  "../spidataflash.c"
    'Finished building: ../spidataflash.c'
    'Building file: ../tcnsl.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="tcnsl.d"  "../tcnsl.c"
    'Finished building: ../tcnsl.c'
    'Building file: ../test.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="test.d"  "../test.c"
    'Finished building: ../test.c'
    'Building file: ../test_def.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="test_def.d"  "../test_def.c"
    'Finished building: ../test_def.c'
    'Building file: ../trace_def.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="trace_def.d"  "../trace_def.c"
    'Finished building: ../trace_def.c'
    'Building file: ../tracec.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="tracec.d"  "../tracec.c"
    'Finished building: ../tracec.c'
    'Building file: ../uart.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="uart.d"  "../uart.c"
    'Finished building: ../uart.c'
    'Building file: ../unit.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="unit.d"  "../unit.c"
    'Finished building: ../unit.c'
    'Building file: ../units.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="units.d"  "../units.c"
    'Finished building: ../units.c'
    'Building file: ../util.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="util.d"  "../util.c"
    'Finished building: ../util.c'
    'Building file: ../var.c'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="var.d"  "../var.c"
    'Finished building: ../var.c'
    'Building target: C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out'
    'Invoking: C2000 Linker'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" -z -m"C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.map" --stack_size=0x7b0 --heap_size=0x800 --warn_sections -i"C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/lib" -i"C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS/include" -i"C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga" --reread_libs --xml_link_info="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga_linkInfo.xml" --rom_model -o "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" "./DSP2833x_CodeStartBranch.obj" "./DSP2833x_GlobalVariableDefs.obj" "./DSP2833x_usDelay.obj" "./_prtfi.obj" "./ad7805.obj" "./adc.obj" "./capture.obj" "./capture_def.obj" "./commands.obj" "./control.obj" "./control_def.obj" "./dsplink.obj" "./dsplink_def.obj" "./fanspeed.obj" "./fifo.obj" "./i2c.obj" "./lcd.obj" "./log.obj" "./log_def.obj" "./memtest.obj" "./nga.obj" "./nga_init.obj" "./nga_systemlog.obj" "./nvram.obj" "./prntf.obj" "./root.obj" "./rs485.obj" "./rs485_tcnsl.obj" "./snprntf.obj" "./spi.obj" "./spidataflash.obj" "./tcnsl.obj" "./test.obj" "./test_def.obj" "./trace_def.obj" "./tracec.obj" "./uart.obj" "./unit.obj" "./units.obj" "./util.obj" "./var.obj" "../DSP2833x_Headers_nonBIOS.cmd" "../nga_FLASH.cmd"  -lrts2800_fpu32.lib
    <Linking>
    "../nga_FLASH.cmd", line 146: warning #10068-D: no matching section
            -lrts2800_fpu32.lib <fd_div.obj
    'Finished building target: C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out'
    "C:/ti/ccsv7/tools/compiler/ti-cgt-c2000_16.9.1.LTS\bin\hex2000" "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"  ../../hexutil_scr/out2img.cmd -o "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.img"
    Translating to ASCII-Hex format...
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" ramfuncs ==> ramfuncs
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" .econst ==> .econst
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" .switch ==> .switch
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" .text ==> .text
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" .cinit ==> .cinit
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" $fill000 ==> $fill000
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" codestart ==> codestart
    **** Build Finished ****
    C:\Program Files (x86)\Texas Instruments\ccsv4\utils\gmake\gmake -k all
    'Invoking: Compiler'
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" -@ccsCompiler.opt
    'Building target: nga.out'
    'Invoking: Linker'
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" -@ccsLinker.opt -o "nga.out"
    <Linking>
    'Finished building target: nga.out'
    C:/Program Files (x86)/Texas Instruments/ccsv4/utils/gmake/gmake --no-print-directory post-build
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000\bin\hex2000" "nga.out"  ../../hexutil_scr/out2img.cmd -o "nga.img"
       "nga.out"   ==> ramfuncs
       "nga.out"   ==> .econst
       "nga.out"   ==> .switch
       "nga.out"   ==> .text
       "nga.out"   ==> .cinit
       "nga.out"   ==> $fill000
       "nga.out"   ==> codestart
    Build complete for project nga
  • I just found before I attached a wrong log file for V7.
    Attached the right one here.
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="DSP2833x_CodeStartBranch.d"  "../DSP2833x_CodeStartBranch.asm"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="DSP2833x_GlobalVariableDefs.d"  "../DSP2833x_GlobalVariableDefs.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="DSP2833x_usDelay.d"  "../DSP2833x_usDelay.asm"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="_prtfi.d"  "../_prtfi.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="ad7805.d"  "../ad7805.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="adc.d"  "../adc.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="capture.d"  "../capture.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="capture_def.d"  "../capture_def.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="commands.d"  "../commands.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="control.d"  "../control.c"
    'Invoking: C2000 Compiler'
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="control_def.d"  "../control_def.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="dsplink.d"  "../dsplink.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="dsplink_def.d"  "../dsplink_def.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="fanspeed.d"  "../fanspeed.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="fifo.d"  "../fifo.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="i2c.d"  "../i2c.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="lcd.d"  "../lcd.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="log.d"  "../log.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="log_def.d"  "../log_def.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="memtest.d"  "../memtest.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nga.d"  "../nga.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nga_init.d"  "../nga_init.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nga_systemlog.d"  "../nga_systemlog.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="nvram.d"  "../nvram.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="prntf.d"  "../prntf.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="root.d"  "../root.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="rs485.d"  "../rs485.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="rs485_tcnsl.d"  "../rs485_tcnsl.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="snprntf.d"  "../snprntf.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="spi.d"  "../spi.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="spidataflash.d"  "../spidataflash.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="tcnsl.d"  "../tcnsl.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="test.d"  "../test.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="test_def.d"  "../test_def.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="trace_def.d"  "../trace_def.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="tracec.d"  "../tracec.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="uart.d"  "../uart.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="unit.d"  "../unit.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="units.d"  "../units.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="util.d"  "../util.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/include" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --preproc_with_compile --preproc_dependency="var.d"  "../var.c"
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000" --silicon_version=28 -g --define="_DEBUG" --define="IOTEST" --define=USER=\"OuGa\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH" --verbose_diagnostics --diag_warning=225 --display_error_number --large_memory_model --unified_memory --float_support=fpu32 --c_src_interlist --asm_listing --asm_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --obj_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" --list_directory="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Prod_Flash_Debug" -z -m"C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.map" --stack_size=0x7b0 --heap_size=0x800 --warn_sections -i"C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/lib" -i"C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" -i"C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga" --reread_libs --xml_link_info="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga_linkInfo.xml" --rom_model -o "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out" "./DSP2833x_CodeStartBranch.obj" "./DSP2833x_GlobalVariableDefs.obj" "./DSP2833x_usDelay.obj" "./_prtfi.obj" "./ad7805.obj" "./adc.obj" "./capture.obj" "./capture_def.obj" "./commands.obj" "./control.obj" "./control_def.obj" "./dsplink.obj" "./dsplink_def.obj" "./fanspeed.obj" "./fifo.obj" "./i2c.obj" "./lcd.obj" "./log.obj" "./log_def.obj" "./memtest.obj" "./nga.obj" "./nga_init.obj" "./nga_systemlog.obj" "./nvram.obj" "./prntf.obj" "./root.obj" "./rs485.obj" "./rs485_tcnsl.obj" "./snprntf.obj" "./spi.obj" "./spidataflash.obj" "./tcnsl.obj" "./test.obj" "./test_def.obj" "./trace_def.obj" "./tracec.obj" "./uart.obj" "./unit.obj" "./units.obj" "./util.obj" "./var.obj" "../DSP2833x_Headers_nonBIOS.cmd" "../nga_FLASH.cmd"  -lrts2800_fpu32.lib
    <Linking>
    "C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000\bin\hex2000" "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"  ../../hexutil_scr/out2img.cmd -o "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.img"
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> ramfuncs
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> .econst
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> .switch
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> .text
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> .cinit
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> $fill000
       "C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/Flash_Debug/nga.out"   ==> codestart
  • Thanks,. Can you also provide the generated ccsCompiler.opt file for your v4 build?
  • Here it is. I changed the file extension to .txt for I cannot uploaded it here with .opt.
    -g
    --define="_DEBUG" --define=PROD_D_CONFIG --define=___TIME___=\""16:16:50"\" --define=___DATE___="\"Dec 21 2015\"" --define="PWM_DB150" --define="IOTEST" --define=USER=\"RashidA\" --define="LARGE_MODEL" --define="NGA_PROD_BOARD" --define="FLASH"
    --include_path="C:/Program Files (x86)/Texas Instruments/ccsv4/tools/compiler/c2000/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/../DSP2833x_headers" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/../DSP2833x_headers/include" --include_path="C:/Users/ouga/Perforce/OuGa_2_NGAstron/NGAstron/3.4D/nga/../include"
    --diag_warning=225
    --unified_memory
    --c_src_interlist
    --asm_listing
    --preproc_dependency="var.pp"
    "../var.c"
  • Thank you for your reminder. After I updated the predefined symbols, they build the same .img file
  • Thank you. I see some differences in the build options used to build in CCSv4 vs CCSv7.
    CCSv4:
    -g
    --diag_warning=225
    --unified_memory
    --c_src_interlist
    --asm_listing
    "../var.c"
    CCSv7
    -g
    --diag_warning=225
    --unified_memory
    --c_src_interlist
    --asm_listing
    Note the differences in the --defines between the two builds. The v4 one has additional defines like PROD_D_CONFIG, ___TIME___, ___DATE___, PWM_DB150. There are also other differences. Try using identical build options for both.
    ki
