CCS: Using CCS 7.1.0 and RTOS for TM4C Series
I have worked on a small test project with an TI RTOS running on a TIVA C Series Device under CCS 6.??.. I have now chaged to CCS 7.1.0 and i am faceing some trouble installing
I would like to ask, if TI-RTOS is currently supported with CCS 7?
  • Rico,
    TI-RTOS for TM4C / Tiva is available in Resource Explorer in CCSv7.  If you open Resource Explorer it is located under software.  You can then select to download and install it.
    If you already have TI-RTOS installed you can go to Window -> Preferences.  Select Code Composer Studio -> Products in the tree.  If you specify the path where it is install then CCS will be able to discover it.
    John
