I'm having issues installing CCS on my computer and was hoping I could get some ideas on what to try. Description in desired format below...
1. New HP notebook running WIN10
2. Trying to install version 7.1.0.00014
3. Will be using RF430CL and MSP-EXP430FR5739, but haven't got that far yet
4. It starts the installation, then always fails at the same spot. ? I did disable the firewall & anti-virus on my system prior to trying the installation (that’s something that the installer recommends). I've tried multiple times
5. Attached below is the logs that I got after reading the "Failure with a new install" section in the Wiki.
ccs_setup_7.1.0.00014_install.log
?INFO: **************************************** INFO: 10/11/2016 10:15:57 INFO: Product Version 2.1.0.0. INFO: Version: 6.0.6000 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Running under Local System Account INFO: Interactive Windows Station INFO: Command Line: 'DPInst64.exe /SW /C /SA ' INFO: DPInst is not multi-lingual. INFO: **************************************** ERROR: Failed to set option to dump log info to console. INFO: Current working directory: 'C:\Program Files\Intel\WiFiDrivers\Drivers' INFO: Running on path 'C:\Program Files\Intel\WiFiDrivers\Drivers' INFO: No valid 'dpinst.xml' file provided. INFO: Install option set: Suppressing Wizard but no OS popups. INFO: Install option set: Suppress Add or Remove Programs entries. INFO: Found driver package: 'C:\Program Files\Intel\WiFiDrivers\Drivers\NETwbw02.INF'. INFO: Found driver package: 'C:\Program Files\Intel\WiFiDrivers\Drivers\NETwew01.INF'. INFO: Found driver package: 'C:\Program Files\Intel\WiFiDrivers\Drivers\NETwtw02.INF'. INFO: Found driver package: 'C:\Program Files\Intel\WiFiDrivers\Drivers\NETwtw04.INF'. INFO: Preinstalling 'c:\program files\intel\wifidrivers\drivers\netwbw02.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files\intel\wifidrivers\drivers\netwbw02.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: Preinstalling 'c:\program files\intel\wifidrivers\drivers\netwew01.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files\intel\wifidrivers\drivers\netwew01.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: Preinstalling 'c:\program files\intel\wifidrivers\drivers\netwtw02.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files\intel\wifidrivers\drivers\netwtw02.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: Preinstalling 'c:\program files\intel\wifidrivers\drivers\netwtw04.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files\intel\wifidrivers\drivers\netwtw04.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files\intel\wifidrivers\drivers\netwbw02.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64.6.3]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\netwbw02.inf_amd64_e3f6477195e2dc41\netwbw02.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\netwbw02.inf_amd64_e3f6477195e2dc41\netwbw02.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files\intel\wifidrivers\drivers\netwbw02.inf'. Driver will be installed when plugged in. INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files\intel\wifidrivers\drivers\netwew01.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64.6.2]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\netwew01.inf_amd64_8f61163a2a2bddf8\netwew01.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\netwew01.inf_amd64_8f61163a2a2bddf8\netwew01.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files\intel\wifidrivers\drivers\netwew01.inf'. Driver will be installed when plugged in. INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files\intel\wifidrivers\drivers\netwtw02.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64.10.0]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\netwtw02.inf_amd64_c6057094ae42faa9\netwtw02.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\netwtw02.inf_amd64_c6057094ae42faa9\netwtw02.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files\intel\wifidrivers\drivers\netwtw02.inf'. Driver will be installed when plugged in. INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files\intel\wifidrivers\drivers\netwtw04.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64.10.0]... INFO: Installing devices with Id "PCI\VEN_8086&DEV_24F3&SUBSYS_10108086&REV_3A" using INF "C:\Windows\System32\DriverStore\FileRepository\netwtw04.inf_amd64_81dfbff72428fc14\netwtw04.inf". INFO: ENTER UpdateDriverForPlugAndPlayDevices... SUCCESS:RETURN UpdateDriverForPlugAndPlayDevices. INFO: Installation was successful. SUCCESS:Install completed INFO: RETURN: DriverPackageInstallW (0x0) INFO: Successfull installation of 'c:\program files\intel\wifidrivers\drivers\netwtw04.inf'. INFO: Returning with code 0x301 INFO: 10/11/2016 10:16:08 INFO: **************************************** INFO: 12/09/2016 00:00:36 INFO: Product Version 2.1.0.0. INFO: Version: 6.2.9200 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Interactive Windows Station INFO: Command Line: '"C:\Program Files (x86)\Arduino\drivers\dpinst-amd64.exe"' INFO: DPInst is not multi-lingual. INFO: **************************************** INFO: Current working directory: 'C:\Program Files (x86)\Arduino\drivers' INFO: Running on path 'C:\Program Files (x86)\Arduino\drivers' INFO: No valid 'dpinst.xml' file provided. INFO: Found driver package: 'C:\Program Files (x86)\Arduino\drivers\arduino-org.inf'. INFO: Found driver package: 'C:\Program Files (x86)\Arduino\drivers\arduino.inf'. INFO: Found driver package: 'C:\Program Files (x86)\Arduino\drivers\linino.inf'. INFO: Found driver package: 'C:\Program Files (x86)\Arduino\drivers\slabvcp.inf'. INFO: Preinstalling 'c:\program files (x86)\arduino\drivers\arduino-org.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\arduino\drivers\arduino-org.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: Preinstalling 'c:\program files (x86)\arduino\drivers\arduino.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\arduino\drivers\arduino.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: Preinstalling 'c:\program files (x86)\arduino\drivers\linino.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\arduino\drivers\linino.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: Preinstalling 'c:\program files (x86)\arduino\drivers\slabvcp.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\arduino\drivers\slabvcp.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\arduino\drivers\arduino-org.inf' (Plug and Play). INFO: Looking for Model Section [DeviceList.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\arduino-org.inf_amd64_bb8d72653e2c9162\arduino-org.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\arduino-org.inf_amd64_bb8d72653e2c9162\arduino-org.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\arduino\drivers\arduino-org.inf'. Driver will be installed when plugged in. INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\arduino\drivers\arduino.inf' (Plug and Play). INFO: Looking for Model Section [DeviceList.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\arduino\drivers\arduino.inf'. Driver will be installed when plugged in. INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\arduino\drivers\linino.inf' (Plug and Play). INFO: Looking for Model Section [DeviceList.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\linino.inf_amd64_eb8e174d035c60aa\linino.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\linino.inf_amd64_eb8e174d035c60aa\linino.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\arduino\drivers\linino.inf'. Driver will be installed when plugged in. INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\arduino\drivers\slabvcp.inf' (Plug and Play). INFO: Looking for Model Section [SiLabsModelsSection.NTamd64.6.1]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\slabvcp.inf_amd64_0bae2245fca55739\slabvcp.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\slabvcp.inf_amd64_0bae2245fca55739\slabvcp.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\arduino\drivers\slabvcp.inf'. Driver will be installed when plugged in. INFO: Created entry in Add or Remove Programs for 'C:\Windows\System32\DriverStore\FileRepository\arduino-org.inf_amd64_bb8d72653e2c9162\arduino-org.inf'. INFO: Created entry in Add or Remove Programs for 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf'. INFO: Created entry in Add or Remove Programs for 'C:\Windows\System32\DriverStore\FileRepository\linino.inf_amd64_eb8e174d035c60aa\linino.inf'. INFO: Created entry in Add or Remove Programs for 'C:\Windows\System32\DriverStore\FileRepository\slabvcp.inf_amd64_0bae2245fca55739\slabvcp.inf'. INFO: Returning with code 0x400 INFO: 12/09/2016 00:00:53 INFO: **************************************** INFO: 02/24/2017 10:53:31 INFO: Product Version 2.1.0.0. INFO: Version: 6.0.6000 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Running under Local System Account INFO: Interactive Windows Station INFO: Command Line: '"C:\Program Files (x86)\Intel\Bluetooth\utilities\dpinst.exe" /SA /A /SE /SW /PATH "C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\WP\Win10Release\x64\' INFO: DPInst is not multi-lingual. INFO: **************************************** INFO: Current working directory: 'C:\Program Files (x86)\Intel\Bluetooth\utilities' INFO: Running on path 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\WP\Win10Release\x64\' INFO: No valid 'dpinst.xml' file provided. INFO: Install option set: Suppressing Wizard but no OS popups. INFO: Install option set: Suppressing EULA. INFO: Install option set: Suppress Add or Remove Programs entries. INFO: Install option set: Install all driver packages or none. INFO: Found driver package: 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\WP\Win10Release\x64\\ibtusb.inf'. INFO: Preinstalling 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wp\win10release\x64\\ibtusb.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wp\win10release\x64\\ibtusb.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wp\win10release\x64\ibtusb.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_8b4f716a536371d8\ibtusb.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_8b4f716a536371d8\ibtusb.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wp\win10release\x64\\ibtusb.inf'. Driver will be installed when plugged in. INFO: Returning with code 0x100 INFO: 02/24/2017 10:53:32 INFO: **************************************** INFO: 02/24/2017 10:53:32 INFO: Product Version 2.1.0.0. INFO: Version: 6.0.6000 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Running under Local System Account INFO: Interactive Windows Station INFO: Command Line: '"C:\Program Files (x86)\Intel\Bluetooth\utilities\dpinst.exe" /SA /A /SE /SW /PATH "C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\STP\Win10Release\x64\' INFO: DPInst is not multi-lingual. INFO: **************************************** INFO: Current working directory: 'C:\Program Files (x86)\Intel\Bluetooth\utilities' INFO: Running on path 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\STP\Win10Release\x64\' INFO: No valid 'dpinst.xml' file provided. INFO: Install option set: Suppressing Wizard but no OS popups. INFO: Install option set: Suppressing EULA. INFO: Install option set: Suppress Add or Remove Programs entries. INFO: Install option set: Install all driver packages or none. INFO: Found driver package: 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\STP\Win10Release\x64\\ibtusb.inf'. INFO: Preinstalling 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\stp\win10release\x64\\ibtusb.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\intel\bluetooth\drivers\ibtusb\stp\win10release\x64\\ibtusb.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\stp\win10release\x64\ibtusb.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_fbd3eb1105cdf92b\ibtusb.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_fbd3eb1105cdf92b\ibtusb.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\stp\win10release\x64\\ibtusb.inf'. Driver will be installed when plugged in. INFO: Returning with code 0x100 INFO: 02/24/2017 10:53:32 INFO: **************************************** INFO: 02/24/2017 10:53:32 INFO: Product Version 2.1.0.0. INFO: Version: 6.0.6000 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Running under Local System Account INFO: Interactive Windows Station INFO: Command Line: '"C:\Program Files (x86)\Intel\Bluetooth\utilities\dpinst.exe" /SA /A /SE /SW /PATH "C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\LNP\Win10Release\x64\' INFO: DPInst is not multi-lingual. INFO: **************************************** INFO: Current working directory: 'C:\Program Files (x86)\Intel\Bluetooth\utilities' INFO: Running on path 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\LNP\Win10Release\x64\' INFO: No valid 'dpinst.xml' file provided. INFO: Install option set: Suppressing Wizard but no OS popups. INFO: Install option set: Suppressing EULA. INFO: Install option set: Suppress Add or Remove Programs entries. INFO: Install option set: Install all driver packages or none. INFO: Found driver package: 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\LNP\Win10Release\x64\\ibtusb.inf'. INFO: Preinstalling 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\lnp\win10release\x64\\ibtusb.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\intel\bluetooth\drivers\ibtusb\lnp\win10release\x64\\ibtusb.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\lnp\win10release\x64\ibtusb.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64]... INFO: Installing devices with Id "USB\VID_8087&PID_0A2B&REV_0001" using INF "C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_40559a7000b8b995\ibtusb.inf". INFO: ENTER UpdateDriverForPlugAndPlayDevices... SUCCESS:RETURN UpdateDriverForPlugAndPlayDevices. INFO: Installation was successful. SUCCESS:Install completed INFO: RETURN: DriverPackageInstallW (0x0) INFO: Successfull installation of 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\lnp\win10release\x64\\ibtusb.inf'. INFO: Returning with code 0x1 INFO: 02/24/2017 10:53:35 INFO: **************************************** INFO: 02/24/2017 10:53:35 INFO: Product Version 2.1.0.0. INFO: Version: 6.0.6000 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Running under Local System Account INFO: Interactive Windows Station INFO: Command Line: '"C:\Program Files (x86)\Intel\Bluetooth\utilities\dpinst.exe" /SA /A /SE /SW /PATH "C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\SDP\Win10Release\x64\' INFO: DPInst is not multi-lingual. INFO: **************************************** INFO: Current working directory: 'C:\Program Files (x86)\Intel\Bluetooth\utilities' INFO: Running on path 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\SDP\Win10Release\x64\' INFO: No valid 'dpinst.xml' file provided. INFO: Install option set: Suppressing Wizard but no OS popups. INFO: Install option set: Suppressing EULA. INFO: Install option set: Suppress Add or Remove Programs entries. INFO: Install option set: Install all driver packages or none. INFO: Found driver package: 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\SDP\Win10Release\x64\\ibtusb.inf'. INFO: Preinstalling 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\sdp\win10release\x64\\ibtusb.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\intel\bluetooth\drivers\ibtusb\sdp\win10release\x64\\ibtusb.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\sdp\win10release\x64\ibtusb.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_60916cce19c9a1a9\ibtusb.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_60916cce19c9a1a9\ibtusb.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\sdp\win10release\x64\\ibtusb.inf'. Driver will be installed when plugged in. INFO: Returning with code 0x100 INFO: 02/24/2017 10:53:35 INFO: **************************************** INFO: 02/24/2017 10:53:35 INFO: Product Version 2.1.0.0. INFO: Version: 6.0.6000 INFO: Platform ID: 2 (NT) INFO: Service Pack: 0.0 INFO: Suite: 0x0100, Product Type: 1 INFO: Architecture: AMD64. INFO: Running under Local System Account INFO: Interactive Windows Station INFO: Command Line: '"C:\Program Files (x86)\Intel\Bluetooth\utilities\dpinst.exe" /SA /A /SE /SW /PATH "C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\WSP\Win10Release\x64\' INFO: DPInst is not multi-lingual. INFO: **************************************** INFO: Current working directory: 'C:\Program Files (x86)\Intel\Bluetooth\utilities' INFO: Running on path 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\WSP\Win10Release\x64\' INFO: No valid 'dpinst.xml' file provided. INFO: Install option set: Suppressing Wizard but no OS popups. INFO: Install option set: Suppressing EULA. INFO: Install option set: Suppress Add or Remove Programs entries. INFO: Install option set: Install all driver packages or none. INFO: Found driver package: 'C:\Program Files (x86)\Intel\Bluetooth\drivers\ibtusb\WSP\Win10Release\x64\\ibtusb.inf'. INFO: Preinstalling 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wsp\win10release\x64\\ibtusb.inf' ... INFO: ENTER: DriverPackagePreinstallW SUCCESS:c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wsp\win10release\x64\\ibtusb.inf is preinstalled. INFO: RETURN: DriverPackagePreinstallW (0x0) INFO: ENTER: DriverPackageGetPathW INFO: RETURN: DriverPackageGetPathW (0x0) INFO: ENTER: DriverPackageInstallW INFO: Installing INF file 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wsp\win10release\x64\ibtusb.inf' (Plug and Play). INFO: Looking for Model Section [Device.NTamd64]... INFO: No matching devices found in INF "C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_bba8118da2fcf7e8\ibtusb.inf" on the Machine. INFO: No drivers installed. No devices found that match driver(s) contained in 'C:\Windows\System32\DriverStore\FileRepository\ibtusb.inf_amd64_bba8118da2fcf7e8\ibtusb.inf'. INFO: RETURN: DriverPackageInstallW (0xE000020B) INFO: No matching device was found for 'c:\program files (x86)\intel\bluetooth\drivers\ibtusb\wsp\win10release\x64\\ibtusb.inf'. Driver will be installed when plugged in. INFO: Returning with code 0x100 INFO: 02/24/2017 10:53:36
<Edition installerversion="1.0" name="Custom" version="7.1.0.00014" location="c:/ti/ccsv7/eclipse" totalsize="0" product="Code Composer Studio" percentcomplete="1">
<OS>windows</OS>
<CCSDIR>c:/ti/ccsv7</CCSDIR>
<zipbinary>C:/Users/davidhan/AppData/Local/Temp/ccs_7f4bbc59-9e29-413a-525f-4ce39a62268f/util/unzip.exe</zipbinary>
<osd>Windows10-64-bit</osd>
<OSName>Windows 10</OSName>
<ServicePack>0</ServicePack>
<allSelected>1</allSelected>
<proxy></proxy>
<baserepourl>http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo</baserepourl>
<TempDir>C:/Users/davidhan/AppData/Local/Temp/ccs_7f4bbc59-9e29-413a-525f-4ce39a62268f</TempDir>
<InstallSrc>C:/Users/davidhan/Documents/TI/RF430CL330H/CCS</InstallSrc>
<InstallDir>c:/ti</InstallDir>
<LocalBaseRepository>C:/Users/davidhan/AppData/Local/Temp/ccs_7f4bbc59-9e29-413a-525f-4ce39a62268f/baserepo</LocalBaseRepository>
<featureurl>http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo</featureurl>
<eclipseexe>eclipsec.exe</eclipseexe>
<ComponentInstaller>false</ComponentInstaller>
<LocalRepository_Exists>0</LocalRepository_Exists>
<testurl>0</testurl>
<EclipseDir>c:/ti/ccsv7/eclipse</EclipseDir>
<Features>
<Feature tag="ARM_CGT_HELP" name="com.ti.cgt.arm.16.9.help" previousInstall="" version="16.9.0.20161128" state="initial" order="82" md5="" size="5542438" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/armhelprepo">
<Installer name="" arguments="--mode silent --prefix 'c:/ti/ccsv7/'" location=""/>
<Uninstaller name="" arguments="--mode silent" location="'c:/ti/ccsv7'"/>
</Feature>
<Feature tag="BBONE_FTDI_DRIVERS" name="com.ti.ftdi.drivers.win" previousInstall="" version="2.8.30.20140130" state="initial" order="123" md5="f1ec277ab9dfba1acdd818c39aae74d4" size="1935950" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="com.ti.ftdi.drivers.win_2.8.30.20140130.zip" arguments="'c:/ti/ccsv7'" location=""/>
<Uninstaller name="" arguments="" location=""/>
</Feature>
<Feature tag="C2000_CGT_HELP" name="com.ti.cgt.c2000.16.9.help" previousInstall="" version="16.9.0.20161128" state="initial" order="83" md5="" size="5326979" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/c2000helprepo">
</Feature>
<Feature tag="C6000_CGT_HELP" name="com.ti.cgt.c6000.7.4.help" previousInstall="" version="7.4.0.201303051055" state="initial" order="81" md5="" size="3278554" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/c6000helprepo">
</Feature>
<Feature tag="CCS_DOC" name="com.ti.ccstudio.doc.win32" previousInstall="" version="7.1.0.20170227" state="initial" order="139" md5="56ecdeb9337c9526b52e391ba6506037" size="307521" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ccs_doc_win32_7.1.0.20170227.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="CCS_LAUNCHER" name="com.ti.ccstudio.launcher.win32" previousInstall="" version="7.0.0.20161020" state="initial" order="136" md5="fcbb0db857cc0009357d7e47d9ed74e4" size="19339" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ccs_launcher_win32_7.0.0.20161020.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="CCS_UTILS" name="com.ti.ccstudio.utils.cli.win32" previousInstall="" version="1.0.0.20160210" state="initial" order="142" md5="31c0ed052c3d35a5ab3fe7015da85741" size="6936486" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ccs_utils_win32_1.0.0.20160210.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="CGT_DEFAULTLIBS_C2800" name="com.ti.cgt.c2000.16.win32" previousInstall="" version="16.9.1.LTS" state="initial" order="26" md5="4d3d8953256e2ba71b3ad5140d66443f" size="13680912" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_cgt_c2000_16.9.1.LTS_windows_installer.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
<Uninstaller name="" arguments="--mode unattended" location="'c:/ti/ccsv7'"/>
</Feature>
<Feature tag="CGT_DEFAULTLIBS_C6000_V8P" name="com.ti.cgt.c6000.8.1.win32" previousInstall="" version="8.1.3" state="initial" order="29" md5="bd53dc4f50d3bb941fe70dce063824da" size="26552097" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_cgt_c6000_8.1.3_windows_installer.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="CGT_DEFAULTLIBS_MSP430" name="com.ti.cgt.msp430.16.win32" previousInstall="" version="16.9.1.LTS" state="initial" order="31" md5="0e3edfa9bda7519995bee71713682bb5" size="13213616" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_cgt_msp430_16.9.1.LTS_windows_installer.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="CGT_DEFAULTLIBS_TMS470" name="com.ti.cgt.tms470.16.win32" previousInstall="" version="16.9.1.LTS" state="initial" order="34" md5="db7c86359870468e946fbc2e216c946f" size="18226130" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_cgt_tms470_16.9.1.LTS_windows_installer.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="CLOUDAGENT" name="com.ti.ccstudio.cloudagent.win32" previousInstall="" version="0.5.1181" state="initial" order="17" md5="7fd52bd8818bbe123e29c1366592d402" size="4134784" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="cloudagent_win_0.5.1181.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_AUTOMOTIVE" name="com.ti.ccstudio.automotive.devicesupport" previousInstall="" version="1.0.4" state="initial" order="108" md5="41f2cc4d32b39dd52fc6c9ffc43c1ff9" size="6847398" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="auto_rvp_rsp_device_support_1.0.4.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_C55XX" name="com.ti.ccstudio.c55xx.devicesupport.win32" previousInstall="" version="1.1.6" state="initial" order="89" md5="018831b4275bbbc2edd0f5b8e382d9e5" size="493040" pf_filter="C5500" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="c55xx_device_support_1.1.6.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_C6000" name="com.ti.ccstudio.c6000.devicesupport.win32" previousInstall="" version="1.1.3" state="initial" order="91" md5="b48cef12b8b2ce31eb107e5bd25bcde0" size="543732" pf_filter="C6000_SC" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="c6000_device_support_1.1.3.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_C6000MC" name="com.ti.ccstudio.c6000mc.devicesupport.win32" previousInstall="" version="1.0.5" state="initial" order="93" md5="40f265177cb65fbdaad35e428571d13e" size="165832" pf_filter="MULTICORE64" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="c6000multicore_device_support_1.0.5.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_CC2538" name="com.ti.ccstudio.cc2538.devicesupport.win32" previousInstall="" version="2.0.1.02" state="initial" order="101" md5="271c2b5c2ce217c3fbd30dcbe05f8e40" size="150563" pf_filter="CC2XXX" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="cc2538_device_support_2.00.01.02_win32.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_CC26XX" name="com.ti.ccstudio.cc26xx.devicesupport.win32" previousInstall="" version="2.10.3.00" state="initial" order="104" md5="5029d121eb7ca41c674e1ff9510604bb" size="608499" pf_filter="CC2XXX" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="cc26x0_device_support_2.10.03.00_win32.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_CC3220" name="com.ti.ccstudio.cc3220.devicesupport.win" previousInstall="" version="1.0.1" state="initial" order="131" md5="e895b43cabbbcb0a8a67cdec72097985" size="25277" pf_filter="CC3XXX" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="cc3220_device_support_win32_1.0.1.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_CC32XX" name="com.ti.ccstudio.cc3200.driversupport.win32" previousInstall="" version="1.0.8" state="initial" order="125" md5="ea102708953652abec3037e032fea796" size="1050" pf_filter="CC3XXX" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="cc3200_driver_support_win32_1.0.8.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_CC32XX_COMMON" name="com.ti.ccstudio.cc3200.devicesupport.win" previousInstall="" version="1.0.8" state="initial" order="128" md5="c1c9587b518b327c9978f536ace0af4a" size="7940" pf_filter="CC3XXX" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="cc3200_device_support_1.0.8.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_DAVINCI" name="com.ti.ccstudio.davinci.devicesupport.win32" previousInstall="" version="1.1.3" state="initial" order="95" md5="46250164e94d12e9600038b6438dacb3" size="220618" pf_filter="MEDIA" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="davinci_device_support_1.1.3.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_INTEGRA" name="com.ti.ccstudio.integra.devicesupport.win32" previousInstall="" version="1.0.9" state="initial" order="97" md5="54d448d5636dbcc6b361123d429568a2" size="64398" pf_filter="OMAP" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="integra_device_support_1.0.9.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_MMWAVE" name="com.ti.ccstudio.mmwaveradar.devicesupport.win32" previousInstall="" version="1.5.1" state="initial" order="107" md5="392a7a9b9d888cae6706cf6b26ddc584" size="130164" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="mmwave_radar_device_support_1.5.1.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_OMAP" name="com.ti.ccstudio.omap.devicesupport.win32" previousInstall="" version="1.0.9" state="initial" order="99" md5="ec16fe8934f948b820c66ad0c829ac4b" size="446478" pf_filter="OMAP" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="omap_device_support_1.0.9.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_PGA" name="com.ti.ccstudio.pga.devicesupport.win32" previousInstall="" version="1.0.1" state="initial" order="110" md5="2bb5850b74b5d50535f157edc0b67da6" size="35792" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="pga_device_support_1.0.1.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_SHARED" name="com.ti.ccstudio.shared.devicesupport.win32" previousInstall="" version="1.0.9" state="initial" order="85" md5="384dfb2a01da66067bb45f5f7e0ff339" size="5072696" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="shared_device_support_1.0.9.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_SITARA" name="com.ti.ccstudio.sitara.devicesupport.win32" previousInstall="" version="1.3.4" state="initial" order="87" md5="58d7c066a31238f83cadb72b47f2f8d5" size="3356904" pf_filter="SITARA" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="sitara_device_support_1.3.4.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="DEV_SUPPORT_UCD31XX" name="com.ti.ucd31xx.support.win32" previousInstall="" version="1.1.2" state="initial" order="134" md5="f5f45c3edeb36bfb5972aac4ca413967" size="221825" pf_filter="UCD31XX" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="digital_power_device_support_1.1.2.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DMED" name="com.ti.cgt.dmed.win32" previousInstall="" version="1.1.5" state="initial" order="79" md5="214b4936f8b96b663a61a6031a7cade2" size="4438928" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_cgt_dmed_1.1.5_windows_installer.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="DS" name="com.ti.ccstudio.debugserver.win32" previousInstall="" version="7.1.0.1971" state="initial" order="11" md5="97064171a77fc538aecf1e7196f19333" size="13061349" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_dspack_ibsetup_win32_7.1.0.1971.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="DS_FLASH" name="com.ti.dsflash.win32" previousInstall="" version="7.1.0.1971" state="initial" order="14" md5="504c0efd3a9d7438c38bd48635ecffca" size="816404" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="com.ti.dsflash.win32_7.1.0.1971.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="DVT_COMMON" name="com.ti.dvt2.graph.visualization.feature.group,com.ti.dvt2.rov.feature.group,com.ti.dvt2.resource.explorer.feature.group" previousInstall="" version="4.1.0.201702211632" state="initial" order="45" md5="" size="50219628" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/dvtRepo">
</Feature>
<Feature tag="DVT_ENERGYTRACE" name="com.ti.dvt.energytrace.feature.group" previousInstall="" version="4.1.0.201702211632" state="initial" order="49" md5="" size="50219628" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/dvtRepo">
</Feature>
<Feature tag="DVT_TRACE" name="com.ti.dvt2.trace.ccs.feature.group,com.ti.dvt2.trace.control.feature.group,com.ti.dvt2.analysis.suite.feature.group" previousInstall="" version="4.1.0.201702211632" state="initial" order="46" md5="" size="50219628" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/dvtRepo">
</Feature>
<Feature tag="DVT_UIA" name="com.ti.dvt2.uia.feature.group,com.ti.dvt2.analysis.suite.feature.group" previousInstall="" version="4.1.0.201702211632" state="initial" order="48" md5="" size="50219628" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/dvtRepo">
</Feature>
<Feature tag="DVT_VIA_CCS" name="com.ti.dvt2.via.ccs.feature.group,com.ti.dvt2.profileanalysismanager.feature.group" previousInstall="" version="4.1.0.201702211632" state="initial" order="47" md5="" size="50219628" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/dvtRepo">
</Feature>
<Feature tag="ECLIPSE" name="org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.feature.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.gef.feature.group,gnu.io.rxtx.feature.group,org.eclipse.gmf.runtime.thirdparty.feature.group" previousInstall="" version="4.6.0.SVG_UPT" state="initial" order="5" md5="" size="93854750" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/eclipserepo">
<Installer name="" arguments="--mode silent --prefix 'c:/ti/ccsv7/'" location="c:/ti/ccsv7/eclipse"/>
</Feature>
<Feature tag="ECLIPSECORE" name="" previousInstall="" version="4.5.1.custom-160121" state="initial" order="4" md5="442893c6da382175cc5e478f885d013b" size="6558624" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo">
<Installer name="eclipse_core_4.5.1.custom-160121.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="EMU_BH" name="com.bh.ccstudio.emulation.win32" previousInstall="" version="6.0.83.003" state="do not install" order="51" md5="91671ea7bd74631c597030076e9682de" size="26370529" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="bh_emupack_setup_6.0.83.003.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' --enable-components arm,c2800,c6000,davinci,omap,c5500" location=""/>
<Uninstaller name="uninstall_bh_emupack.exe" arguments="--mode unattended" location="'c:/ti/ccsv7/ccs_base/emulation'"/>
</Feature>
<Feature tag="EMU_C2000" name="com.ti.c2000.support.win32" previousInstall="" version="4.2.0.0" state="initial" order="64" md5="03dfd296dbc1a41cd32171c6865e295d" size="2611778" pf_filter="C2000" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_c2000support_setup_4.2.0.0.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="EMU_C2000_FLASH" name="com.ti.c2800.flash" previousInstall="" version="1.0.0.4" state="initial" order="67" md5="d17560d3768c1fb71c8092ca3cc8e011" size="373032" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_c2800_flash_1.0.0.4.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="EMU_HERCULES" name="com.ti.ccstudio.hercules.win32" previousInstall="" version="6.0.7" state="initial" order="59" md5="cac37cea967b8b4567930a9ee51f9976" size="1235674" pf_filter="SAFETY" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_hercules_setup_6.0.7.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="EMU_SD" name="com.sd.ccstudio.emulation.win32" previousInstall="" version="5.2.0.14" state="do not install" order="62" md5="b1407e253c047c3de01c6fcd0428cd8b" size="28232394" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="sd_emupack_setup_5.2.0.14.exe" arguments="--mode silent --prefix 'c:/ti/ccsv7/ccs_base' /noc2400 /noc5400" location=""/>
<Uninstaller name="uninstall_sd_emupack.exe" arguments="--mode silent" location="'c:/ti/ccsv7/ccs_base/emulation'"/>
</Feature>
<Feature tag="EMU_TI" name="com.ti.emulation.pack.win32" previousInstall="" version="6.0.576.0" state="initial" order="56" md5="9c34d252895c1feb1eab81283f4f1ba6" size="45492577" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_emupack_setup_6.0.576.0_win_32.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' --enable-components arm,c2800,c6000,davinci,omap,c5500,xds100,xds560" location=""/>
</Feature>
<Feature tag="GCC_ARM_COMPILER" name="com.ti.gcc.arm.win32" previousInstall="" version="4.9.3.2015q3_20150921" state="initial" order="114" md5="49fd5f1d46c4f962457afdacf6eb98c1" size="95509250" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="gcc-arm-none-eabi-4.9.3.2015q3_20150921-win32.zip" arguments="'c:/ti/ccsv7/tools/compiler'" location=""/>
</Feature>
<Feature tag="IDE_ARM" name="com.ti.ccstudio.tms470" previousInstall="" version="7.1.0.N201702161400" state="initial" order="40" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="IDE_C2000" name="com.ti.ccstudio.c2000" previousInstall="" version="7.1.0.N201702161400" state="initial" order="42" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="IDE_C5500" name="com.ti.ccstudio.c5500" previousInstall="" version="7.1.0.N201702161400" state="initial" order="43" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="IDE_C6000" name="com.ti.ccstudio.c6000.feature.group,com.ti.ccstudio.c7000.feature.group" previousInstall="" version="7.1.0.N201702161400" state="initial" order="44" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="IDE_CHROME" name="com.ti.chromium.browser.feature.group" previousInstall="" version="7.1.0.N201702161400" state="initial" order="41" md5="" size="39168410" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/browserRepo">
</Feature>
<Feature tag="IDE_GC" name="com.ti.gc.backplane.feature.group,com.ti.gc.pm.feature.group,com.ti.debug.server.feature.group" previousInstall="" version="7.1.0.N201702161400" state="initial" order="37" md5="" size="4530493" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/gcRepo">
</Feature>
<Feature tag="IDE_MAIN" name="com.ti.ccstudio.idemain" previousInstall="" version="7.1.0.N201702161400" state="initial" order="38" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="IDE_MSP430" name="com.ti.ccstudio.msp430" previousInstall="" version="7.1.0.N201702161400" state="initial" order="41" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="IDE_TOOLS_COMMON" name="com.ti.tools.common.feature.group" previousInstall="" version="7.1.0.N201702161400" state="initial" order="36" md5="" size="3644819" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/tools-commonRepo">
</Feature>
<Feature tag="IDE_WORKFLOW" name="com.ti.ccstudio.workflow" previousInstall="" version="7.1.0.N201702161400" state="initial" order="39" md5="" size="17002584" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/idebuildRepo">
</Feature>
<Feature tag="INSTALLER" name="com.ti.ccstudio.installer.win32" previousInstall="" version="7.1.0.00014" state="initial" order="160" md5="" size="353" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="7.1.0.00014.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="JRE" name="jre" previousInstall="" version="1.8.0.122" state="initial" order="1" md5="d00586812a0acf00b68aa32cc54411d6" size="60488057" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="jre-8u112-windows-i586.zip" arguments="'c:/ti/ccsv7'" location="c:/ti/ccsv7/eclipse/jre/bin"/>
</Feature>
<Feature tag="KEYSTONE1" name="com.ti.emulation.keystone1.win32" previousInstall="" version="1.0.12.0" state="initial" order="122" md5="9a55bef6efd6fa039aaeef133509d91d" size="291250" pf_filter="KEYSTONE1" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="keystone1_device_support_1.0.12.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="KEYSTONE2" name="com.ti.emulation.keystone2.win32" previousInstall="" version="1.1.8" state="initial" order="77" md5="4aa8ba4f1e85ca6142778a682b537b38" size="702634" pf_filter="KEYSTONE2" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="keystone2_device_support_1.1.8.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="MSP430_BUILD_DEBUG" name="com.ti.msp430.build_debug" previousInstall="" version="7.0.6" state="initial" order="70" md5="" size="35195006" pf_filter="MSP430" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/msp_win32_repo">
</Feature>
<Feature tag="MSP430_CGT_HELP" name="com.ti.cgt.msp430.16.9.help" previousInstall="" version="16.9.0.20161128" state="initial" order="80" md5="" size="4628808" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/msp430helprepo">
</Feature>
<Feature tag="MSP430_GCC_SUPPORT" name="com.ti.msp430.gcc_support" previousInstall="" version="7.0.6" state="initial" order="71" md5="" size="35195006" pf_filter="MSP430" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/msp_win32_repo">
</Feature>
<Feature tag="MSP432_BUILD_DEBUG" name="com.ti.msp432.build_debug" previousInstall="" version="7.0.6" state="initial" order="72" md5="" size="35195006" pf_filter="MSP432" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/msp_win32_repo">
</Feature>
<Feature tag="MSVC_REDIST_2005" name="com.ti.ccstudio.installer.msvc.2005.win32" previousInstall="" version="6.0.2900.2180" state="do not install" order="6" md5="ce2922f83fb4b170affce0ea448b107b" size="2667152" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="vcredist_x86_2005_6.0.2900.2180.exe" arguments=" " location=""/>
<Uninstaller name="" arguments="" location="'c:/ti/ccsv7'"/>
</Feature>
<Feature tag="MSVC_REDIST_2008" name="com.ti.ccstudio.installer.msvc.2008.win32" previousInstall="" version="9.0.30729.17" state="do not install" order="7" md5="5689d43c3b201dd3810fa3bba4a6476a" size="4195205" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="vcredist_x86_2008_9.0.30729.17.exe" arguments=" /q /l "c:/ti/ccsv7/install_logs/MSVC_REDIST_2008.log" /norestart " location=""/>
</Feature>
<Feature tag="MSVC_REDIST_2012" name="com.ti.ccstudio.installer.msvc.2012.win32" previousInstall="" version="11.0.61030" state="do not install" order="8" md5="7f52a19ecaf7db3c163dd164be3e592e" size="6356599" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="vcredist_x86_2012_11.0.61030.exe" arguments=" /q /l "c:/ti/ccsv7/install_logs/MSVC_REDIST_2012.log" /norestart " location=""/>
</Feature>
<Feature tag="MSVC_REDIST_2015" name="com.ti.ccstudio.installer.msvc.2015.win32" previousInstall="" version="14.0.24212" state="initial" order="9" md5="1b3d24a3e9c99e63391a53b9e5be5356" size="14245678" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="vc_redist.x86_14.0.24212.exe" arguments=" /q /l "c:/ti/ccsv7/install_logs/MSVC_REDIST_2015.log" /norestart " location=""/>
</Feature>
<Feature tag="NODEJS" name="com.ti.ccstudio.nodejs.win32" previousInstall="" version="6.9.1" state="initial" order="20" md5="5c89f62f73c82eb090d9c81c27266a15" size="5682050" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="node-6.9.1_win32.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="P2APP" name="com.ti.ccstudio.p2appf" previousInstall="" version="7.1.0.N201702161400" state="initial" order="49" md5="" size="39754" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/p2appfRepo">
</Feature>
<Feature tag="P2TOOLS" name="com.ti.ccstudio.p2tool" previousInstall="" version="7.0.0.201611291427" state="initial" order="43" md5="" size="33935" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/lwrepo">
</Feature>
<Feature tag="PINMUX" name="com.ti.ccstudio.pinmux.win32" previousInstall="" version="4.0.1470" state="initial" order="23" md5="7ca3d1ad538c0aeb885602814cc53089" size="2700259" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="pinmux_4.0.1470.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="SEGGER_J_LINK" name="com.segger.jlink.win32" previousInstall="" version="6.10.0.n" state="do not install" order="73" md5="5d792f1b84bce9db7380fb5d9bf9cdc2" size="5717587" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="com.segger.jlink.windows.V610n.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="SEGGER_J_LINK_DRIVERS" name="com.segger.jlink.drivers.win32" previousInstall="" version="1.0.0.6" state="do not install" order="75" md5="c857b17ed9695073f1ea6ae0063ed27e" size="4103087" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="JLinkDriver_setup_1.0.0.6.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="TARGETDB_DEF_PROPS" name="com.ti.ccstudio.targetdb.props.default.win32" previousInstall="" version="6.0.0.20131206" state="initial" order="145" md5="fb2010dfc02546d71f48b5f59d0cbe16" size="2301" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="targetdb_default_props_6.0.0.20131206.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="TARGET_CONTENT_CORE" name="com.ti.targetcontent.feature.group" previousInstall="" version="3.50.1.12" state="initial" order="112" md5="" size="29952111" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/targetcontent_core_repo">
<Installer name="" arguments="--mode silent --prefix 'c:/ti/ccsv7/..'" location=""/>
</Feature>
<Feature tag="TARGET_CONTENT_CORE_LEGACY" name="com.ti.xdctools_3_32.update.feature.group" previousInstall="" version="3.32.1.22" state="initial" order="44" md5="" size="25920463" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/baserepo/targetcontent_legacy_repo">
</Feature>
<Feature tag="TIREX" name="com.ti.tirex" previousInstall="" version="3.1.1.201702241447" state="initial" order="46" md5="77f636a1ee2db64da0c0b41bd2a4bf0b" size="24810723" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="tirex_3.1.1.201702241447_win32.exe" arguments="--mode unattended --ccs true --prefix 'c:/ti/ccsv7' --eclipseprefix 'c:/ti/ccsv7/eclipse' " location=""/>
</Feature>
<Feature tag="TIVA_STELLARIS_DRIVERS" name="com.ti.tiva_stellaris.setup.win32" previousInstall="" version="2.1.3.15" state="initial" order="53" md5="4112e96c2d05a2810865431b1fe65c81" size="2004" pf_filter="" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ti_tiva_stellaris_windows_2_1_3_15.zip" arguments="'c:/ti/ccsv7'" location=""/>
</Feature>
<Feature tag="TIVA_TM4C" name="com.ti.tiva_tm4c.setup.win32" previousInstall="" version="2.1.1.15071" state="initial" order="117" md5="2c6fe6c22c19c37149517bb2a8c0676d" size="920588" pf_filter="TIVAC" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ccs_tiva_tm4c_devices_files_2_1_1_15071.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
<Feature tag="TIVA_TM4E" name="com.ti.tiva_tm4e.setup.win32" previousInstall="" version="2.1.1.15071" state="initial" order="120" md5="95588751f8e2ca7c713e195fdc936720" size="462451" pf_filter="TIVAE" location="http://software-dl.ti.com/ccs/esd/CCSv7/CCS7.1.0.00014_win32/featurerepo">
<Installer name="ccs_tiva_tm4e_devices_files_2_1_1_15071.zip" arguments="'c:/ti/ccsv7/ccs_base'" location=""/>
</Feature>
</Features>
<InstalledFeatures>
<FeatureSelected tag="EMU_TI"/>
<FeatureSelected tag="IDE_MSP430"/>
<FeatureSelected tag="MSP430_BUILD_DEBUG"/>
<FeatureSelected tag="MSP430_GCC_SUPPORT"/>
<FeatureSelected tag="EMU_MSP430"/>
<FeatureSelected tag="TIVA_STELLARIS_DRIVERS"/>
<FeatureSelected tag="JRE"/>
<FeatureSelected tag="P2APP"/>
<FeatureSelected tag="ECLIPSE"/>
<FeatureSelected tag="ECLIPSECORE"/>
<FeatureSelected tag="P2TOOLS"/>
<FeatureSelected tag="GMF"/>
<FeatureSelected tag="IDE_MAIN"/>
<FeatureSelected tag="IDE_WORKFLOW"/>
<FeatureSelected tag="DVT_COMMON"/>
<FeatureSelected tag="DVT_UIA"/>
<FeatureSelected tag="DVT_VIA_CCS"/>
<FeatureSelected tag="TIREX"/>
<FeatureSelected tag="XULRUNNER"/>
<FeatureSelected tag="INSTALLER"/>
<FeatureSelected tag="IDE_CHROME"/>
<FeatureSelected tag="IDE_TOOLS_COMMON"/>
<FeatureSelected tag="IDE_GC"/>
<FeatureSelected tag="TARGET_CONTENT_CORE"/>
<FeatureSelected tag="TARGET_CONTENT_CORE_LEGACY"/>
<FeatureSelected tag="NODEJS"/>
<FeatureSelected tag="PINMUX"/>
<FeatureSelected tag="DS"/>
<FeatureSelected tag="DS_FLASH"/>
<FeatureSelected tag="CLOUDAGENT"/>
<FeatureSelected tag="MSVC80"/>
<FeatureSelected tag="MSVC2012"/>
<FeatureSelected tag="MSVC2015"/>
<FeatureSelected tag="MSP430_CGT_HELP"/>
<FeatureSelected tag="CGT_DEFAULTLIBS_MSP430"/>
<FeatureSelected tag="DMED"/>
<FeatureSelected tag="DVT_ENERGYTRACE"/>
<FeatureSelected tag="MSP432_BUILD_DEBUG"/>
<FeatureSelected tag="EMU_MSP432"/>
<FeatureSelected tag="EMU_MSP432_FLASH"/>
<FeatureSelected tag="ARM_CGT_HELP"/>
<FeatureSelected tag="CGT_DEFAULTLIBS_TMS470"/>
<FeatureSelected tag="IDE_ARM"/>
<FeatureSelected tag="GCC_ARM_COMPILER"/>
<FeatureSelected tag="DVT_TRACE"/>
<FeatureSelected tag="DEV_SUPPORT_CC26XX"/>
<FeatureSelected tag="EMU_STELLARIS"/>
<FeatureSelected tag="DEV_SUPPORT_CC32XX"/>
<FeatureSelected tag="DEV_SUPPORT_CC3220"/>
<FeatureSelected tag="DEV_SUPPORT_CC32XX_COMMON"/>
<FeatureSelected tag="DEV_SUPPORT_CC2538"/>
<FeatureSelected tag="IDE_C2000"/>
<FeatureSelected tag="EMU_C2000_FLASH"/>
<FeatureSelected tag="EMU_C2000"/>
<FeatureSelected tag="GREE_C2000_SUPPORT"/>
<FeatureSelected tag="C2000_CGT_HELP"/>
<FeatureSelected tag="CGT_DEFAULTLIBS_C2800"/>
<FeatureSelected tag="TIVA_TM4C"/>
<FeatureSelected tag="TIVA_TM4E"/>
<FeatureSelected tag="EMU_HERCULES"/>
<FeatureSelected tag="DEV_SUPPORT_SITARA"/>
<FeatureSelected tag="DEV_SUPPORT_SHARED"/>
<FeatureSelected tag="C6000_CGT_HELP"/>
<FeatureSelected tag="CGT_DEFAULTLIBS_C6000_V8P"/>
<FeatureSelected tag="BBONE_FTDI_DRIVERS"/>
<FeatureSelected tag="IDE_C6000"/>
<FeatureSelected tag="DEV_SUPPORT_INTEGRA"/>
<FeatureSelected tag="CGT_DEFAULTLIBS_C6000"/>
<FeatureSelected tag="DEV_SUPPORT_DAVINCI"/>
<FeatureSelected tag="DEV_SUPPORT_OMAP"/>
<FeatureSelected tag="DEV_SUPPORT_AUTOMOTIVE"/>
<FeatureSelected tag="EVE_SIM_TI"/>
<FeatureSelected tag="CGT_DEFAULTLIBS_EVE"/>
<FeatureSelected tag="IDE_C5500"/>
<FeatureSelected tag="DEV_SUPPORT_C55XX"/>
<FeatureSelected tag="DEV_SUPPORT_C6000"/>
<FeatureSelected tag="KEYSTONE1"/>
<FeatureSelected tag="KEYSTONE2"/>
<FeatureSelected tag="DEV_SUPPORT_MMWAVE"/>
<FeatureSelected tag="DEV_SUPPORT_C6000MC"/>
<FeatureSelected tag="DEV_SUPPORT_UCD31XX"/>
<FeatureSelected tag="DEV_SUPPORT_PGA"/>
<FeatureSelected tag="CCS_DOC"/>
<FeatureSelected tag="CCS_LAUNCHER"/>
<FeatureSelected tag="CCS_UTILS"/>
<FeatureSelected tag="MSVC_REDIST_2005"/>
<FeatureSelected tag="MSVC_REDIST_2008"/>
<FeatureSelected tag="MSVC_REDIST_2012"/>
<FeatureSelected tag="MSVC_REDIST_2015"/>
<FeatureSelected tag="TARGETDB_DEF_PROPS"/>
</InstalledFeatures>
<ProductFamilies>
<FeatureSelected tag="PF_MSP430"/>
<FeatureSelected tag="PF_MSP432"/>
<FeatureSelected tag="PF_CC2X"/>
<FeatureSelected tag="PF_CC3X"/>
<FeatureSelected tag="PF_CC2538"/>
<FeatureSelected tag="PF_C28"/>
<FeatureSelected tag="PF_TM4C"/>
<FeatureSelected tag="PF_HERCULES"/>
<FeatureSelected tag="PF_SITARA"/>
<FeatureSelected tag="PF_OMAPL"/>
<FeatureSelected tag="PF_DAVINCI"/>
<FeatureSelected tag="PF_OMAP"/>
<FeatureSelected tag="PF_TDA_DRA"/>
<FeatureSelected tag="PF_C55"/>
<FeatureSelected tag="PF_C6000SC"/>
<FeatureSelected tag="PF_C66AK_KEYSTONE"/>
<FeatureSelected tag="PF_MMWAVE"/>
<FeatureSelected tag="PF_C64MC"/>
<FeatureSelected tag="PF_DIGITAL_POWER"/>
<FeatureSelected tag="PF_PGA"/>
</ProductFamilies>
<Devices>
<Device tag="MSP430"/>
<Device tag="MSP432"/>
<Device tag="ARM"/>
<Device tag="C2000"/>
<Device tag="C6000"/>
<Device tag="C5500"/>
<Device tag="UCD31xx"/>
<Device tag="PGA"/>
</Devices>
<PF_Filters>
<PF_Filter tag="C5500"/>
<PF_Filter tag="C6000_SC"/>
<PF_Filter tag="MULTICORE64"/>
<PF_Filter tag="CC2XXX"/>
<PF_Filter tag="CC3XXX"/>
<PF_Filter tag="MEDIA"/>
<PF_Filter tag="OMAP"/>
<PF_Filter tag="SITARA"/>
<PF_Filter tag="UCD31XX"/>
<PF_Filter tag="C2000"/>
<PF_Filter tag="SAFETY"/>
<PF_Filter tag="KEYSTONE1"/>
<PF_Filter tag="KEYSTONE2"/>
<PF_Filter tag="MSP430"/>
<PF_Filter tag="MSP432"/>
<PF_Filter tag="TIVAC"/>
<PF_Filter tag="TIVAE"/>
</PF_Filters>
</Edition>
Looking forward to getting some help with this.
Hayden
