Part Number: CCSTUDIO
Installation freezes on macOS 10.12.4. I'm using an offline installer of CCS v7.1.0.00016. Please see logs in the attached archive.
7357.ccs.zip
7357.ccs.zip
Hi!
Offline installer was unzipped in my desktop folder before. I tried to use home folder and got the same result.
My steps before installing(installation dir is default - "/Applications/ti"):
- run /Applications/ti/ccsv7/uninstall_ccs.app
- remore /Applications/ti
- remove /tmp/bitrock_installer.log
- remove directory /tmp/ccs_***(some digits, looks like hash or UUID)
Sorry for a long delay. I tried to run it from terminal, result difference a little. As you can see I am running it directly from my home folder.
As for as I now I did not make any changes in application running process... But I am going to check it.
Also you can find logs in the attached file.
20413.install_logs.zip
It looks like I found the problem.
macOS Sierra introduces a new security feature called "Gatekeeper Path Randomization" (or "app translocation", as it's called on the API level).
