Part Number: CC3220SF-LAUNCHXL
Other Parts Discussed in Thread: CC3220SF, SYSBIOS
I deleted my previous CCSv7.1 version and installed the latest CCSv7.1.0.00016. I build the CC3220SF SDK example programs and now I am getting these build errors below. How do I solve these build errors?
>> Compilation failure
subdir_rules.mk:26: recipe for target 'build-532594849-inproc' failed
"package/cfg/hello_pem4.c", line 863: warning #145-D: a value of type "xdc_Ptr (*)(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" cannot be used to initialize an entity of type "xdc_Ptr (*)(xdc_Ptr, xdc_SizeT, xdc_Ptr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)"
"package/cfg/hello_pem4.c", line 884: warning #145-D: a value of type "xdc_Ptr (*)(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" cannot be used to initialize an entity of type "xdc_Ptr (*)(xdc_Ptr, xdc_SizeT, xdc_Ptr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)"
"package/cfg/hello_pem4.c", line 906: warning #145-D: a value of type "xdc_Ptr (*)(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" cannot be used to initialize an entity of type "xdc_Ptr (*)(xdc_Ptr, xdc_SizeT, xdc_Ptr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)"
"package/cfg/hello_pem4.c", line 2414: error #20: identifier "CT__ti_sysbios_BIOS_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 2414: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 2635: error #20: identifier "CT__ti_sysbios_family_arm_m3_Hwi_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 2635: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 2848: error #20: identifier "CT__ti_sysbios_family_arm_m3_IntrinsicsSupport_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 2848: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 2925: error #20: identifier "CT__ti_sysbios_family_arm_m3_TaskSupport_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 2925: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3078: error #20: identifier "CT__ti_sysbios_family_arm_m3_Timer_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3078: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3204: error #20: identifier "CT__ti_sysbios_gates_GateHwi_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3204: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3339: error #20: identifier "CT__ti_sysbios_gates_GateMutex_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3339: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3447: error #20: identifier "CT__ti_sysbios_hal_Hwi_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3447: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3588: error #20: identifier "CT__ti_sysbios_heaps_HeapMem_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3588: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3755: error #20: identifier "CT__ti_sysbios_knl_Clock_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3755: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3899: error #20: identifier "CT__ti_sysbios_knl_Idle_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3899: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 3984: error #20: identifier "CT__ti_sysbios_knl_Intrinsics_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 3984: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 4088: error #20: identifier "CT__ti_sysbios_knl_Queue_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 4088: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 4190: error #20: identifier "CT__ti_sysbios_knl_Semaphore_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 4190: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 4476: error #20: identifier "CT__ti_sysbios_knl_Swi_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 4476: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 4796: error #20: identifier "CT__ti_sysbios_knl_Task_Module__startupDoneFxn" is undefined
"package/cfg/hello_pem4.c", line 4796: error #18: expected a ")"
"package/cfg/hello_pem4.c", line 12850: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 12850: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 12850: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 12850: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 12923: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 12923: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 12923: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 12923: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 13089: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 13089: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 13089: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 13089: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 13162: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 13162: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 13162: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 13162: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 13402: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 13402: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 13402: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 13402: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 13475: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 13475: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 13475: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 13475: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 13554: warning #169-D: argument of type "xdc_SizeT" is incompatible with parameter of type "const xdc_UChar *"
"package/cfg/hello_pem4.c", line 13554: warning #169-D: argument of type "xdc_Ptr" is incompatible with parameter of type "xdc_SizeT"
"package/cfg/hello_pem4.c", line 13554: warning #169-D: argument of type "const xdc_UChar *" is incompatible with parameter of type "xdc_runtime_Error_Block *"
"package/cfg/hello_pem4.c", line 13554: error #141: too many arguments in function call
"package/cfg/hello_pem4.c", line 13950: error #148: declaration is incompatible with "xdc_CPtr ti_sysbios_BIOS_RtsGateProxy_Proxy__delegate__S(void)" (declared at line 317 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/package/BIOS_RtsGateProxy.h")
"package/cfg/hello_pem4.c", line 14062: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_family_arm_m3_Hwi_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 989 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi.h")
"package/cfg/hello_pem4.c", line 14285: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_family_arm_m3_Timer_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 476 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Timer.h")
"package/cfg/hello_pem4.c", line 14484: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_gates_GateHwi_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 316 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/gates/GateHwi.h")
"package/cfg/hello_pem4.c", line 14665: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_gates_GateMutex_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 334 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/gates/GateMutex.h")
"package/cfg/hello_pem4.c", line 14846: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_hal_Hwi_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 445 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/hal/Hwi.h")
"package/cfg/hello_pem4.c", line 14986: error #148: declaration is incompatible with "xdc_CPtr ti_sysbios_hal_Hwi_HwiProxy_Proxy__delegate__S(void)" (declared at line 410 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/hal/package/Hwi_HwiProxy.h")
"package/cfg/hello_pem4.c", line 15098: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_heaps_HeapMem_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 417 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/heaps/HeapMem.h")
"package/cfg/hello_pem4.c", line 15220: error #148: declaration is incompatible with "xdc_CPtr ti_sysbios_heaps_HeapMem_Module_GateProxy_Proxy__delegate__S(void)" (declared at line 317 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/heaps/package/HeapMem_Module_GateProxy.h")
"package/cfg/hello_pem4.c", line 15332: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_knl_Clock_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 460 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/Clock.h")
"package/cfg/hello_pem4.c", line 15455: error #148: declaration is incompatible with "xdc_CPtr ti_sysbios_knl_Clock_TimerProxy_Proxy__delegate__S(void)" (declared at line 362 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/package/Clock_TimerProxy.h")
"package/cfg/hello_pem4.c", line 15495: error #148: declaration is incompatible with "xdc_CPtr ti_sysbios_knl_Intrinsics_SupportProxy_Proxy__delegate__S(void)" (declared at line 279 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/package/Intrinsics_SupportProxy.h")
"package/cfg/hello_pem4.c", line 15606: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_knl_Queue_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 292 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/Queue.h")
"package/cfg/hello_pem4.c", line 15787: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_knl_Semaphore_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 446 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/Semaphore.h")
"package/cfg/hello_pem4.c", line 15969: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_knl_Swi_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 455 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/Swi.h")
"package/cfg/hello_pem4.c", line 16168: error #148: declaration is incompatible with "xdc_Ptr ti_sysbios_knl_Task_Object__create__S(xdc_CPtr, const xdc_UChar *, xdc_SizeT, xdc_runtime_Error_Block *)" (declared at line 854 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/Task.h")
"package/cfg/hello_pem4.c", line 16271: error #148: declaration is incompatible with "xdc_CPtr ti_sysbios_knl_Task_SupportProxy_Proxy__delegate__S(void)" (declared at line 314 of "C:/ti/simplelink_cc32xx_sdk_1_30_01_03/kernel/tirtos/packages/ti/sysbios/knl/package/Task_SupportProxy.h")
72 errors detected in the compilation of "package/cfg/hello_pem4.c".
gmake.exe: *** [package/cfg/hello_pem4.oem4] Error 1
js: "C:/ti/xdctools_3_32_01_22_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[1]: *** [build-532594849-inproc] Error 1
gmake: *** No rule to make target 'build-532594849', needed by 'configPkg/compiler.opt'.
gmake[1]: Leaving directory 'C:/ti/ccsv7workspace/CC3220SF_Launchpad/hello_CC3220SF_LAUNCHXL_tirtos_ccs/Debug'
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
- kel
Josh Wyatt - I want to inform you about this issue.
