CCS/EK-TM4C123GXL: C/C++ Search bug
Part Number: EK-TM4C123GXL
Hello all,
I'm having a problem with the C/C++ Search function, if I search for any string the first time after installing Code Composer Studio, it searchs normally the active project. But after closing the search tab and using Ctrl+H again, it searches another project instead of the active one (I already tried to limit the scope using all the other options, when I do that it only finds references in the Tivaware path).
How can I correct this issue?
  • Helder,
    What version of CCS are you using? I would like to try to reproduce this.
    John
  • Hello John,
    I'm using CCS 7.1.0.
    P.S. I'm also using Tiva 1294 codes.
  • Helder,
    I couldn't reproduce this issue here in my CCSv7.1.0, but I am using a newly created workspace that was recently indexed. Despite this, no matter what scope limiters I apply I always get relevant results - i.e., they find elements in the same resource.
    At any rate, please check the procedure I am following below and perhaps you can point out something I may be doing differently than you.
    Rafael
  • I'm not sure why, but clicking the search button worked, while Ctrl+H didn't at first. Now even Ctrl+H works.
    That's very strange, but I can't complain now that is working.
    Thank you!
