Other Parts Discussed in Thread: IWR1642
**** Build of configuration Debug for project IWR1642_ARM ****
"D:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 4 all -O
'Building target: IWR1642_ARM.out'
'Invoking: ARM Linker'
"D:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.3.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi -z -m"IWR1642_ARM.map" --heap_size=0x800 --stack_size=0x800 -i"D:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.3.LTS/lib" -i"D:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.3.LTS/include" --reread_libs --diag_wrap=off --display_error_number --warn_sections --xml_link_info="IWR1642_ARM_linkInfo.xml" --rom_model --be32 -o "IWR1642_ARM.out" "./main.obj" "../xwr1642_r4f.cmd" -llibc.a
<Linking>
warning #10366-D: automatic library build: using library "D:\ti\ccsv7\tools\compiler\ti-cgt-arm_16.9.3.LTS\lib\rtsv7R4_A_be_v3D16_eabi.lib" for the first time, so it must be built. This may take a few minutes.
cannot create e:/temp/ti_mklibhhj3ia/obj/b_exp.P: permission denied
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/b_exp.obj' failed
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/b_log.obj' failed
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/b_exp.obj] Error 2
cannot create e:/temp/ti_mklibhhj3ia/obj/b_log.P: permission denied
cannot create e:/temp/ti_mklibhhj3ia/obj/e_acos.P: permission denied
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/b_log.obj] Error 2
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_acos.obj' failed
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/b_tgamma.obj' failed
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_acos.obj] Error 2
cannot create e:/temp/ti_mklibhhj3ia/obj/b_tgamma.P: permission denied
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/b_tgamma.obj] Error 2
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_acosh.obj' failed
cannot create e:/temp/ti_mklibhhj3ia/obj/e_acosh.P: permission denied
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_acosh.obj] Error 2
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_atan2.obj' failed
cannot create e:/temp/ti_mklibhhj3ia/obj/e_atan2.P: permission denied
cannot create e:/temp/ti_mklibhhj3ia/obj/e_asin.P: permission denied
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_atan2.obj] Error 2
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_asin.obj' failed
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_atanh.obj' failed
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_asin.obj] Error 2
cannot create e:/temp/ti_mklibhhj3ia/obj/e_atanh.P: permission denied
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_cosh.obj' failed
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_atanh.obj] Error 2
cannot create e:/temp/ti_mklibhhj3ia/obj/e_cosh.P: permission denied
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_cosh.obj] Error 2
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_exp.obj' failed
cannot create e:/temp/ti_mklibhhj3ia/obj/e_exp.P: permission denied
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_exp.obj] Error 2
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_fmod.obj' failed
cannot create e:/temp/ti_mklibhhj3ia/obj/e_fmod.P: permission denied
cannot create e:/temp/ti_mklibhhj3ia/obj/e_lgamma.P: permission denied
Makefile:1789: recipe for target 'e:/temp/ti_mklibhhj3ia/obj/e_lgamma.obj' failed
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_fmod.obj] Error 2
gmake.exe[2]: *** [e:/temp/ti_mklibhhj3ia/obj/e_lgamma.obj] Error 2
!CommandLauncher.error.commandCanceled!
Error: Program "D:/ti/ccsv7/utils/bin/gmake" is not found in PATH
PATH=[D:\ti\ccsv7\ccs_base\common\bin;D:\ti\ccsv7\ccs_base\common\uscif;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;d:\Program Files\MATLAB\R2016a\runtime\win64;d:\Program Files\MATLAB\R2016a\bin;d:\Program Files\MATLAB\R2016a\polyspace\bin;C:\Program Files (x86)\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft SQL Server\110\DTS\Binn\;C:\Strawberry\c\bin;C:\Strawberry\perl\site\bin;C:\Strawberry\perl\bin;D:\Cadence\Cadence_SPB_16.6-2015\tools\pspice;D:\Cadence\Cadence_SPB_16.6-2015\openaccess\bin\win32\opt;D:\Cadence\Cadence_SPB_16.6-2015\tools\capture;D:\Cadence\Cadence_SPB_16.6-2015\tools\pspice\library;D:\Cadence\Cadence_SPB_16.6-2015\tools\specctra\bin;D:\Cadence\Cadence_SPB_16.6-2015\tools\fet\bin;D:\Cadence\Cadence_SPB_16.6-2015\tools\libutil\bin;D:\Cadence\Cadence_SPB_16.6-2015\tools\bin;D:\Cadence\Cadence_SPB_16.6-2015\tools\pcb\bin;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps]
