CCSV4 debug resets
Expert 2875 points
Other Parts Discussed in Thread: CCSTUDIO
If the check box Reset the target on a program load or restart is checked, code download to target fails and CCSV4 will terminate with Java xxxx fail.
How can we reset the target after code download?
Thank you.
Steve
    You can use the 'Target->Reset' menu item
    If you can provide some diagnostic logs, we can investigate the crash also.
    ki
  • What diagnostic logs do you need?  And how to get it?  Thanks.
  • It is documented here:
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS#CCS_Diagnostic_Logs
    Besides the install log, all the others will be helpful
  • CG toll install.log:
    :DIR {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/abs470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/acp470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/acpia470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/ar470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/asm470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/btiarm.dll}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/cg470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/cg470g3.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/cl470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/clist470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/dem470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/dis470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/embed470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/hex470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/ilk470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/libinfo470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/lnk470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/mk470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/nm470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/ofd470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/opt470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/sdp470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/strip470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/bin/xref470.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/compiler.reg}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/LICENSE.txt}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/RemoveRegistryKeys.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/SetupInCCSnRegistry.exe}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/DefectHistory.txt}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/LINKER_README.txt}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/ParserErrorList.txt}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/README.txt}
    :DIR {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/docs}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/docs/TMS470EABIMigration.pdf}
    :DIR {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/_fmt_specifier.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/_isfuncdcl.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/_isfuncdef.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/_lock.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/access.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/algorithm}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/assert.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/bitset}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cassert}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cctype}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cerrno}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cfloat}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/ciso646}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/climits}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/clocale}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cmath}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/Compiler.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/Compiler_Cfg.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cpp_inline_math.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cpy_tbl.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/csetjmp}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/csignal}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cstdarg}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cstddef}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cstdio}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cstdlib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cstring}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/ctime}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/ctype.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cwchar}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/cwctype}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/deque}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/elf_linkage.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/errno.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/etsi.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/exception}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/file.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/float.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/fstream}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/fstream.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/functional}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/hash_map}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/hash_set}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/inttypes.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iomanip}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iomanip.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/ios}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iosfwd}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iostream}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iostream.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iso646.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/istream}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/iterator}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/limits}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/limits.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/linkage.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/list}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/locale}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/locale.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/map}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/math.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/memory}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/new}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/new.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/numeric}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/ostream}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/Platform_Types.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/queue}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/rope}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/set}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/setjmp.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/signal.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/slist}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/sstream}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stack}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/Std_Types.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stdarg.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stddef.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stdexcept}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stdint.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stdio.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stdiostream.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stdlib.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/stl.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/streambuf}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/string}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/string.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/strstream}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/strstream.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/time.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/typeinfo}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/unaccess.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/utility}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/valarray}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/vector}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/wchar.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/wchar.hx}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/wctype.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xdebug}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xhash}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xiosbase}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xlocale}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xlocinfo}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xlocinfo.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xlocmes}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xlocmon}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xlocnum}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xloctime}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xmemory}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xstddef}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xstring}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xtree}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xutility}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/xwcc.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/ymath.h}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/include/yvals.h}
    :DIR {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/libc.a}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/lnk16.cmd}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/lnk32.cmd}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16arm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16arm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16e.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16e_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16earm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16earm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16etiabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16etiabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16tiabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts16tiabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32arm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32arm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32e.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32e_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32earm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32earm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32etiabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32etiabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32tiabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rts32tiabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtssrc.zip}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_be_eabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_be_tiarm7.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_be_tiarm7_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_be_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_le_eabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_le_tiarm7.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_le_tiarm7_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_le_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_A_le_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_be_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_be_tiarm7.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_be_tiarm7_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_be_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_le_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_le_tiarm7.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_le_tiarm7_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_le_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv4_T_le_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_A_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_A_be_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_A_le_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_A_le_eabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_A_le_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_A_le_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_T_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_T_be_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_T_le_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_T_le_eabi_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_T_le_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv5_T_le_tiarm9_eh.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7A8_A_le_n_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7M3_T_be_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7M3_T_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7M3_T_le_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7M3_T_le_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_A_be_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_A_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_A_be_v3D16_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_A_le_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_A_le_v3D16_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_T_be_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_T_be_tiarm9.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_T_be_v3D16_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_T_le_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/lib/rtsv7R4_T_le_v3D16_eabi.lib}
    :FILE {C:/Program Files/ccsv4/tools/compiler/TMS470 Code Generation Tools 4.6.4/install.log}
    error_recovery.log
    LogEntry.0=START_INSTALL_LOG
    LogEntry.1=FEATURE C:\Program Files\ccsv4\eclipse\features\com.sd.ccstudio.emulation_4.2.0.4\feature1280275579652.xml
    LogEntry.2=ALL_FEATURES_INSTALLED
    LogEntry.3=RENAME C:\Program Files\ccsv4\eclipse\features\com.sd.ccstudio.emulation_4.2.0.4\feature1280275579652.xml
    LogEntry.4=END_INSTALL_LOG
    eof=eof
  • Can you check to see if a crash dump file has been generated/
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS#Crash_Dump_File
    ki
  • There are a lot of dump files and all size zero.
    btw - i meant to say that everything BUT the install log would be useful...
  • Hi Ki,
    I was just importing CCS 3.3 project to V4 and got the following.  Actually, I got these message quite often on CCS V4.
  • Those messages are very generic and not very helpful for analyzing what happened. The dump files and JVM error logs are much more helpful - reproducible test case is best. Can you zip and attach that project you are importing?
