Please see C and associated disassembly and expression window below.
Why isn't abc.a3 being stored in the most upper nibble of the first first word? I expected the result to be 0x00004305 instead of 0x00040305.
Stephen
C-Code:
typedef unsigned int UWORD;
typedef union
long Message;
struct{
unsigned int a1:8;
unsigned int a2:4;
unsigned int a3:6;
unsigned int a4:1;
unsigned int a5:1;
unsigned int a6:1;
unsigned int a7:1;
unsigned int a8:5;
unsigned int a9:1;
unsigned int a10:1;
unsigned int a11;
}bits;
} ID;
ID abc;
int main(void)
abc.bits.a1=5;
abc.bits.a2=3;
abc.bits.a3=4;
return 0;
Disassembly:
29 abc.bits.a1=5;
main:
009078: 761F0300 MOVW DP, #0x300
00907a: CC00FF00 AND AL, @0x0, #0xff00
00907c: 5005 ORB AL, #0x5
00907d: 9600 MOV @0x0, AL
30 abc.bits.a2=3;
00907e: CC00F0FF AND AL, @0x0, #0xf0ff
009080: 1AA90300 OR @AL, #0x0300
009082: 9600 MOV @0x0, AL
31 abc.bits.a3=4;
009083: CC01FFC0 AND AL, @0x1, #0xffc0
009085: 5004 ORB AL, #0x4
009086: 9601 MOV @0x1, AL
33 return 0;
009087: 9A00 MOVB AL, #0x0
34 }
009088: 0006 LRETR
_register_unlock:
009089: 761F0300 MOVW DP, #0x300
00908b: A80A MOVL @0xa, XAR4
00908c: 0006 LRETR
_register_lock:
00908d: 761F0300 MOVW DP, #0x300
00908f: A808 MOVL @0x8, XAR4
009090: 0006 LRETR
_nop:
009091: 0006 LRETR
Expression Window:
abc union <anonymous_union> {...} (Hex) 0x0000C000@Data
Message long 0x00040305 (Hex) 0x0000C000@Data
bits struct <unnamed> {...} (Hex) 0x0000C000@Data
a1 unsigned int : 8 0x05 (Hex) 0x0000C000@Data bit 0-7
a2 unsigned int : 4 0x3 (Hex) 0x0000C000@Data bit 8-11
a3 unsigned int : 6 0x4 (Hex) 0x0000C001@Data bit 0-5
a4 unsigned int : 1 0x0 (Hex) 0x0000C001@Data bit 6
a5 unsigned int : 1 0x0 (Hex) 0x0000C001@Data bit 7
a6 unsigned int : 1 0x0 (Hex) 0x0000C001@Data bit 8
a7 unsigned int : 1 0x0 (Hex) 0x0000C001@Data bit 9
a8 unsigned int : 5 0x0 (Hex) 0x0000C001@Data bit 10-14
a9 unsigned int : 1 0x0 (Hex) 0x0000C001@Data bit 15
a10 unsigned int : 1 0x0 (Hex) 0x0000C002@Data bit 0
a11 unsigned int 0x0000 (Hex) 0x0000C003@Data
