Hi Ti professors,
I design a C6678 evm and reference the TI C6678 evm to design XDS100 emulator. But when I want to program eeprom, the error occur.I can read the data of eeprom by Mprog.exe,but when I download the prgram to eeprom,There is suggesting that the device not found.
MProg is an older version or programmer from FTDI - they usually recommend FTProg.
Also, the device chosen seems incorrect - the device on the XDS100v1 should be a FT2232H and not C. This may be causing the disconnect.
If you use FTProg, please check the attached template I downloaded from my C6678 board.
Hope this helps,
Rafael
