Compiler: Netctrl_min
Hello!
I have a simple NDk project. And i need to change the version of  netcontrol lib to netctrl_min.
How can I change the variant of netcontrol lib in  my project?
NDK2.24.01.18
Thanks.
Andriy
  • Are you using the .cfg to configuration the NDK or are you doing it all in runtime code?
    If you are using the .cfg, you cannot have any of the following in your configuration:
    - DhcpServer
    - Dns
    - Nat
    - Telnet
    - Http
    - Global.enableCodeGeneration = false
    If all the above are met, the netctrl_min library is used.
    If you are not using the .cfg file for configuration, simple change the library in your project settings.
    Todd
  • Thanks Todd
    As I understand you. There must be next in my configuration in .cfg : Global.enableCodeGeneration = true .
    Am I correct?
  • Yes, you are correct.
  • Hello
    As you adviced, I changed  Global.enableCodeGeneration =  true;
    Build finished without errors. But when I try  to debug project on  c6670 I see the following run-time errors on CCS console.
    Thanks.
    Andriy
  • CCS console:
    [C66xx_0] QMSS successfully initialized
    CPPI successfully initialized
    PA successfully initialized
    TCP/IP Stack 'Hello World!' Application
    PASS successfully initialized
    Ethernet subsystem successfully initialized
    Ethernet eventId : 48 and vectId (Interrupt) : 7
    Registration of the EMAC Successful, waiting for link up ..
    Error opening PA Tx queue
    Tx setup failed
    Error: Unable to register the EMAC
    00000.000 ExecStart: Already Open
    00000.000 mmFree: Double Free
    00000.000
    NC_NetStart: WARNING: Boot thread has not completed!
    00000.000 NodeTreeFree: Null endpoints
  • What device are you on?
  • Oops. Just saw the C6670 above. I'll ask the device team to take a look. They wrote the low level driver. The Error opening PA Tx queue is a little worrisome.
    In the meantime, can you attach you .cfg file. Knowing how you set up you memory management for the NDK might be useful.
    Todd
  • Hello Todd!
    Ok
    I send you  my .cfg file.
    helloWorld.cfg
    Also I sand you  my .c file . Maybe it can help
     * helloWorld_bios6.c
     * TCP/IP Stack 'Hello World!' Example ported to use BIOS6 OS.
     * Copyright (C) 2007, 2011 Texas Instruments Incorporated - http://www.ti.com/
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // IP Stack 'Hello World!' Example
    // This is a skeleton application, intended to provide application
    // programmers with a basic Stack setup, to which they can start
    // adding their code.
    // To test it as is, use with helloWorld.exe from \winapps directory
    #include <stdio.h>
    #include <ti/ndk/inc/netmain.h>
    /* BIOS6 include */
    #include <ti/sysbios/BIOS.h>
    /* Platform utilities include */
    #include "ti/platform/platform.h"
    #include "ti/platform/resource_mgr.h"
    #include <xdc/runtime/Error.h>
    #include <ti/sysbios/knl/Task.h>
    //// sss ////
    #include <HeapMem.h>
    #include <Memory.h>
    #include "DDR3_INI.h"
    //#include <C:\ti\bios_6_33_06_50\packages\ti\bios\include\sem.h>
    #include <ti/sysbios/knl/Semaphore.h>
    //#include "types.h"
    //#include "csl_types.h"
    //#include "platform.h"
    //#include <stdio.h>
    //#include <stdlib.h>
    //#include <string.h>
    #include "csl_chip.h"
    #include "csl_chipAux.h"
    #include "csl_semAux.h"
    #include "cslr_device.h"
    #include "cslr_psc.h"
    #include "csl_psc.h"
    //#include "csl_emif4f.h"
    //#include "csl_emif4fAux.h"
    //#include "evmc66x_fpga.h"
    //#include "evmc66x_i2c.h"
    //#include "cslr_i2c.h"
    #include "csl_cpsw.h"
    #include "csl_cpsgmii.h"
    #include "csl_cpsgmiiAux.h"
    #include "csl_mdio.h"
    #include "csl_mdioAux.h"
    //#include "evmc66x_uart.h"
    //#include "cslr_uart.h"
    //#include "evmc66x_gpio.h"
    //#include "csl_gpioAux.h"
    //#include "evmc66x_i2c_eeprom.h"
    //#include "evmc66x_nand.h"
    #include "csl_pscAux.h"
    #include "csl_bootcfg.h"
    #include "csl_bootcfgAux.h"
    //#include "evmc66x_nor.h"
    //#include "evmc66x_spi.h"
    //#include "cslr_spi.h"
    //#include "csl_pllcAux.h"
    //#include "csl_xmcAux.h"
    //#include "evmc66x_pllc.h"
    /* Platform Information - we will read it form the Platform Library */
    platform_info  gPlatformInfo;
    void Init_SGMII_S (uint32_t macPortNum);
    // Title String
    char *VerStr = "\nTCP/IP Stack 'Hello World!' Application\n\n";
    // Our NETCTRL callback functions
    static void   NetworkOpen();
    static void   NetworkClose();
    static void   NetworkIPAddr( IPN IPAddr, uint IfIdx, uint fAdd );
    // Fun reporting function
    static void   ServiceReport( uint Item, uint Status, uint Report, HANDLE hCfgEntry );
    // External references
    extern int dtask_udp_hello();
    //// sss ///
    extern void DDR_CNTRL();
    extern void PLL_CNTRL(void);
    extern void SLEEP_CNTRL(void);
    extern Semaphore_Handle semaNDK;
    // System Task Code [ Server Daemon Servers ]
    static HANDLE hHello=0;
    // Configuration
    char *HostName    = "tidsp";
    char *LocalIPAddr = "192.168.30.78";
    char *LocalIPMask = "255.255.255.0";    // Not used when using DHCP
    char *GatewayIP   = "192.168.30.101";    // Not used when using DHCP
    char *DomainName  = "demo.net";         // Not used when using DHCP
    char *DNSServer   = "0.0.0.0";          // Used when set to anything but zero
    // Simulator EMAC Switch does not handle ALE_LEARN mode, so please configure the
    // MAC address of the PC where you want to launch the webpages and initiate PING to NDK */
    Uint8 clientMACAddress [6] = {0x5C, 0x26, 0x0A, 0x69, 0x44, 0x0B}; /* MAC address for my PC */
     *  @b EVM_init()
     *  @n
     *  Initializes the platform hardware. This routine is configured to start in
     *   the evm.cfg configuration file. It is the first routine that BIOS
     *   calls and is executed before Main is called. If you are debugging within
     *  CCS the default option in your target configuration file may be to execute
     *  all code up until Main as the image loads. To debug this you should disable
     *  that option.
     *  @param[in]  None
     *  @retval
     *      None
    extern void configSerdes();  /// sss ////
    extern void Init_SGMII (uint32_t macPortNum); /// sss ///
    extern int dtask_udp_hello( SOCKET s, UINT32 unused );
    //// sss ////
    Task_Params taskParams;
    Task_Handle ETH_Task_hndl;
    Error_Block eb;
    extern void ConCmdEcho( int ntok, char *tok1, char *tok2 );
    int SOCK_OK=0;
    void EVM_init()
     platform_init_flags   sFlags;
     platform_init_config  sConfig;
     /* Status of the call to initialize the platform */
     int32_t pform_status;
     /////// sss ////
     //return;
      * You can choose what to initialize on the platform by setting the following
      * flags. Things like the DDR, PLL, etc should have been set by the boot loader.
     memset( (void *) &sFlags,  0, sizeof(platform_init_flags));
     memset( (void *) &sConfig, 0, sizeof(platform_init_config));
        sFlags.pll  = 0; /* PLLs for clocking    */
        sFlags.ddr  = 0;     /* External memory    */
        sFlags.tcsl = 1; /* Time stamp counter   */
    #ifdef _SCBP6618X_
        sFlags.phy  = 0; /* Ethernet       */
    #else
        sFlags.phy  = 1; /* Ethernet       */
    #endif
        sFlags.ecc  = 0; /* Memory ECC       */
        sConfig.pllm = 0;  /* Use libraries default clock divisor */
     pform_status = platform_init(&sFlags, &sConfig);
     /// sss  C:\ti\pdk_C6670_1_1_2_6\packages\ti\platform\evmc6670l\platform_lib\src\platform.c ///
     /* If we initialized the platform okay */
     if (pform_status != Platform_EOK) {
       /* Initialization of the platform failed... die */
    	 //// sss ////
       while (1) {
         (void) platform_led(1, PLATFORM_LED_ON, PLATFORM_USER_LED_CLASS);
         (void) platform_delay(50000);
         (void) platform_led(1, PLATFORM_LED_OFF, PLATFORM_USER_LED_CLASS);
       //// sss ////
    int timer_n=0;
    void Timer0_Func(void)
    	static int ii=0;
    		ii++; timer_n++;
    		//if(ii>5)``
    			ii = 0;
    			//Semaphore_post(semaNDK);
    //		Semaphore_post(semaNDK);
    int task1_n=0;
    void Task1Func(void)
    	static int ii=0;
    	while(1)
    		task1_n++;
    		do{   ii++;
    		while(ii<200);
    	//	if(ii>1000)
    			ii = 0;
    //		if (SOCK_OK==1)
    //			dtask_udp_hello(hHello, 0);
    		Semaphore_pend(semaNDK, BIOS_WAIT_FOREVER);
    // Main Entry Point
    int main()
    	//// sss ////
    	//EVM_init();
    	PLL_CNTRL();
    	SLEEP_CNTRL();
    	//////// sss!!! /////////////
    	///////////////// CSL_BootCfgUnlockKicker();
    		//DDR_CNTRL();
    		//// sss /// EVM_init();
    	//// RESET ETHER////
    	//GPIO_DIR    GPIO_BASE_ADDR = 0x02320000u
    	*(unsigned int*)(0x02320000u + 0x00000010u) = 0x00001030;
    	///GPIO_CLR_DATA
    	*(unsigned int*)(0x02320000u + 0x0000001cu) = 0x1;
            configSerdes();
            /// sss C:\ti\pdk_C6670_1_1_2_6\packages\ti\platform\evmc6670l\platform_lib\src\evmc6670_phy.c
    #define ETH_CHANEL 1    /// 1 - EVM  0 - BCOSU
            ///        Init_SGMII_S(0); ////BCOSU
            ///sss!!!
            	Init_SGMII_S(ETH_CHANEL);///EVM
    		///// CACHE ///
    		KICK0 = KICK0_UNLOCK;////// CACHE ON /////
    		KICK1 = KICK1_UNLOCK;
    			 *(volatile unsigned int*)(0x01840000u) &=~7;          		/// L2CFG CACHE_OFF
    			 *(volatile unsigned int*)(0x01840000u) |=1;          		/// L2CFG CACHE_ON
    						*(volatile unsigned int*)(0x01840020u) &=~7;      /// 			    L1PCFG CACHE_OFF
    						*(volatile unsigned int*)(0x01840020u) |=4 ;      	///  			L1PCFG CACHE_ON
    			  *(volatile unsigned int*)(0x01840040u) &=~7;  				///   L1DCFG CACHE_OFF
    			  *(volatile unsigned int*)(0x01840040u) |=7;   			///   L1DCFG CACHE_ON
    						 *(volatile unsigned int*)(0x01848200u) &= ~9;//|=9;      /// MAR128
    			  	  	  	 *(volatile unsigned int*)(0x01848204u) &= ~9;///    MAR129 16M  - 2block DDR
    		KICK0 = KICK0_LOCK; //lock kicker registers
    		KICK1 = KICK1_LOCK;
    //	//// sss //////////////
    //		Error_init(&eb);
    //		/* Create a Task with priority xx */
    //		Task_Params_init(&taskParams);
    //		taskParams.stackSize = 1024;
    //		taskParams.priority = 3;
    //		ETH_Task_hndl = Task_create((Task_FuncPtr)Task1Func , &taskParams, &eb);
    //		//ConCmdEcho
    //			if (ETH_Task_hndl == NULL) {
    //			//System_abort
    //			printf("Task create failed");
    //		HeapMem_Params prms;
    //		static char *buf[1024];
    //		HeapMem_Handle heap;
    //		HeapMem_Params_init(&prms);
    //		prms.size = 0x30000;//1024;
    //		prms.buf = (Ptr)buf;
    //		heap = HeapMem_create(&prms, NULL);
    //		char* buf1;
    //		/* Alloc and free using systemHeap */
    //		buf1 = Memory_alloc(NULL, 128, 0, NULL);
    //		Memory_free(NULL, buf1, 128);
     /* Start the BIOS 6 Scheduler */
     BIOS_start ();
    // Main Thread
    int StackTest()
        int             rc;
        int        i;
        HANDLE          hCfg;
        QMSS_CFG_T      qmss_cfg;
        CPPI_CFG_T      cppi_cfg;
    //	Error_init(&eb);					//////////// sss /////////////
    //	/* Create a Task with priority 5 */
    //	taskParams.stackSize = 4096;
    //	taskParams.priority = 7;
    //	ETH_Task_hndl = Task_create((Task_FuncPtr)ConCmdEcho, &taskParams, &eb);
    //		//System_abort
       /// while(1);
     /* Get information about the platform so we can use it in various places */
     memset( (void *) &gPlatformInfo, 0, sizeof(platform_info));
     (void) platform_get_info(&gPlatformInfo);
     /*  */ //// sss //////     FOR PRINTING MASSAGES
     (void) platform_uart_init();
     (void) platform_uart_set_baudrate(115200);
     (void) platform_write_configure(PLATFORM_WRITE_ALL);
    /* //// sss ////// */
     /* Clear the state of the User LEDs to OFF */
    // for (i=0; i < gPlatformInfo.led[PLATFORM_USER_LED_CLASS].count; i++) {
    //   (void) platform_led(i, PLATFORM_LED_OFF, PLATFORM_USER_LED_CLASS);
     /**/ //// sss //////
        /* Initialize the components required to run this application:
         *  (1) QMSS
         *  (2) CPPI
         *  (3) Packet Accelerator
        /* Initialize QMSS */
    //    if (platform_get_coreid() == 0)   //// sss //////
            qmss_cfg.master_core        = 1;   ///// sss This Way!
    //    else
    //        qmss_cfg.master_core        = 0;
    //    } //// sss //////
        qmss_cfg.max_num_desc       = MAX_NUM_DESC;
        qmss_cfg.desc_size          = MAX_DESC_SIZE;
        qmss_cfg.mem_region         = Qmss_MemRegion_MEMORY_REGION0;
        if (res_mgr_init_qmss (&qmss_cfg) != 0)
        	//// sss ////// platform_write
            printf("Failed to initialize the QMSS subsystem \n");
            goto main_exit;
        else
        	//// sss //////platform_write
         printf("QMSS successfully initialized \n");
        /* Initialize CPPI */
    //    if (platform_get_coreid() == 0)//// sss //////
            cppi_cfg.master_core        = 1;				///// sss This Way!
    //    else
    //        cppi_cfg.master_core        = 0;
        cppi_cfg.dma_num            = Cppi_CpDma_PASS_CPDMA;
        cppi_cfg.num_tx_queues      = NUM_PA_TX_QUEUES;
        cppi_cfg.num_rx_channels    = NUM_PA_RX_CHANNELS;
        if (res_mgr_init_cppi (&cppi_cfg) != 0)
            printf("Failed to initialize CPPI subsystem \n");
            goto main_exit;
        else
         ////// sss //////platform_write
         printf("CPPI successfully initialized \n");
        if (res_mgr_init_pass()!= 0) {
        	printf("Failed to initialize the Packet Accelerator \n");
            goto main_exit;
        else
        	printf("PA successfully initialized \n");
        // THIS MUST BE THE ABSOLUTE FIRST THING DONE IN AN APPLICATION before
        //  using the stack!!
        rc = NC_SystemOpen( NC_PRIORITY_LOW, NC_OPMODE_INTERRUPT );
        if( rc )
        	printf("NC_SystemOpen Failed (%d)\n",rc);
            for(;;);
        // Print out our banner
        printf(VerStr);
        // Create and build the system configuration from scratch.
        // Create a new configuration
        hCfg = CfgNew();
        if( !hCfg )
        	printf("Unable to create configuration\n");
            goto main_exit;
    //					// THIS MUST BE THE ABSOLUTE FIRST THING DONE IN AN APPLICATION!!
    //					rc = NC_SystemOpen( NC_PRIORITY_LOW, NC_OPMODE_INTERRUPT );
    //					if( rc )
    //						printf("NC_SystemOpen Failed (%d)\n",rc);
    //						for(;;);
    //					// Print out our banner
    //					printf(VerStr);
    //					// Create and build the system configuration from scratch.
    //					// Create a new configuration
    //					hCfg = CfgNew();
    //					if( !hCfg )
    //						printf("Unable to create configuration\n");
    //						goto main_exit;
        // We better validate the length of the supplied names
        if( strlen( DomainName ) >= CFG_DOMAIN_MAX ||
            strlen( HostName ) >= CFG_HOSTNAME_MAX )
            printf("Names too long\n");
            goto main_exit;
        // Add our global hostname to hCfg (to be claimed in all connected domains)
        CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_HOSTNAME, 0,
                     strlen(HostName), (UINT8 *)HostName, 0 );
        //// sss ////
    #define MINE_ MINE__
        // If the IP address is specified, manually configure IP and Gateway
    #if defined( MINE_) ||  defined( _SCBP6618X_) || defined(_EVMTCI6614_) || defined(DEVICE_K2H) || defined(DEVICE_K2K)
        /* SCBP6618x, EVMTCI6614, EVMK2H, EVMK2K always uses DHCP */
        if (1)  ////// sss ///// 0)
    #else
        if (!platform_get_switch_state(1))
    #endif
            CI_IPNET NA;
            CI_ROUTE RT;
            IPN      IPTmp;
            // Setup manual IP address
            bzero( &NA, sizeof(NA) );
            NA.IPAddr  = inet_addr(LocalIPAddr);
            NA.IPMask  = inet_addr(LocalIPMask);
            strcpy( NA.Domain, DomainName );
            NA.NetType = 0;
            // Add the address to interface 1
            CfgAddEntry( hCfg, CFGTAG_IPNET,
            					1,
            					0,
                               sizeof(CI_IPNET), (UINT8 *)&NA, 0 );
            // Add the default gateway. Since it is the default, the
            // destination address and mask are both zero (we go ahead
            // and show the assignment for clarity).
            bzero( &RT, sizeof(RT) );
            RT.IPDestAddr = 0;
            RT.IPDestMask = 0;
            RT.IPGateAddr = inet_addr(GatewayIP);
            // Add the route
            CfgAddEntry( hCfg, CFGTAG_ROUTE, 0, 0,
                               sizeof(CI_ROUTE), (UINT8 *)&RT, 0 );
    //        // Manually add the DNS server when specified                           /////  !!!!!!
    //        IPTmp = inet_addr(DNSServer);
    //        if( IPTmp )
    //            CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER,
    //                         0, sizeof(IPTmp), (UINT8 *)&IPTmp, 0 );
    //    // Else we specify DHCP
    //    else
    //        CI_SERVICE_DHCPC dhcpc;
    //        // Specify DHCP Service on IF-1
    //        bzero( &dhcpc, sizeof(dhcpc) );
    //        dhcpc.cisargs.Mode   = CIS_FLG_IFIDXVALID;
    //        dhcpc.cisargs.IfIdx  = 1;
    //        dhcpc.cisargs.pCbSrv = &ServiceReport;
    //        CfgAddEntry( hCfg, CFGTAG_SERVICE, CFGITEM_SERVICE_DHCPCLIENT, 0,
    //                     sizeof(dhcpc), (UINT8 *)&dhcpc, 0 );
        // Configure IPStack/OS Options
        // We don't want to see debug messages less than WARNINGS
        rc = DBG_ERROR;///DBG_INFO; //// sss ////     DBG_WARN;
        CfgAddEntry( hCfg, CFGTAG_OS, CFGITEM_OS_DBGPRINTLEVEL,
                     CFG_ADDMODE_UNIQUE, sizeof(uint), (UINT8 *)&rc, 0 );
        // This code sets up the TCP and UDP buffer sizes
        // (Note 8192 is actually the default. This code is here to
        // illustrate how the buffer and limit sizes are configured.)
        // UDP Receive limit       //////////////////////////////////!!!!!!!!!!!!!!!!!!!!!!
        rc =  8192;
        //4096;
        ////16384;
        CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_SOCKUDPRXLIMIT,
        // Boot the system using this configuration
        // We keep booting until the function returns 0. This allows
        // us to have a "reboot" command.
        do
        {	SOCK_OK =1;
            rc = NC_NetStart( hCfg, NetworkOpen, NetworkClose, NetworkIPAddr );
        } while( rc > 0 );
        // Delete Configuration
        CfgFree( hCfg );
        // Close the OS
    main_exit:
        NC_SystemClose();
        return(0);
    //// System Task Code [ Server Daemon Servers ]
    //static HANDLE hHello=0;
    // NetworkOpen
    // This function is called after the configuration has booted
    		Error_init(&eb);
    		taskParams.stackSize = 2048;
    		taskParams.priority = 9;
    		//ConCmdEcho
    			//System_abort
        // Create our local server
        hHello = DaemonNew( SOCK_DGRAM, 0,
    //    		7,
        		12288,
        		dtask_udp_hello,
                           OS_TASKPRINORM, OS_TASKSTKNORM, 0, 1 );
    // NetworkClose
    // This function is called when the network is shutting down,
    // or when it no longer has any IP addresses assigned to it.
        DaemonFree( hHello );
    // NetworkIPAddr
    // This function is called whenever an IP address binding is
    // added or removed from the system.
        IPN IPTmp;
        if( fAdd )
            printf("Network Added: ");
        else
            printf("Network Removed: ");
        // Print a message
        IPTmp = ntohl( IPAddr );
        printf("If-%d:%d.%d.%d.%d\n", IfIdx,
                (UINT8)(IPTmp>>24)&0xFF, (UINT8)(IPTmp>>16)&0xFF,
                (UINT8)(IPTmp>>8)&0xFF, (UINT8)IPTmp&0xFF );
    // Service Status Reports
    // Here's a quick example of using service status updates
    static char *TaskName[]  = { "Telnet","HTTP","NAT","DHCPS","DHCPC","DNS" };
    static char *ReportStr[] = { "","Running","Updated","Complete","Fault" };
    static char *StatusStr[] = { "Disabled","Waiting","IPTerm","Failed","Enabled" };
    static void ServiceReport( uint Item, uint Status, uint Report, HANDLE h )
        printf( "Service Status: %-9s: %-9s: %-9s: %03d\n",
                TaskName[Item-1], StatusStr[Status],
                ReportStr[Report/256], Report&0xFF );
        // Example of adding to the DHCP configuration space
        // When using the DHCP client, the client has full control over access
        // to the first 256 entries in the CFGTAG_SYSINFO space.
        // Note that the DHCP client will erase all CFGTAG_SYSINFO tags except
        // CFGITEM_DHCP_HOSTNAME. If the application needs to keep manual
        // entries in the DHCP tag range, then the code to maintain them should
        // be placed here.
        // Here, we want to manually add a DNS server to the configuration, but
        // we can only do it once DHCP has finished its programming.
    //						if( Item == CFGITEM_SERVICE_DHCPCLIENT &&       /////////////// !!!!!!!!!!!!!!!!!!!!!!!!!!!!
    //							Status == CIS_SRV_STATUS_ENABLED &&
    //							(Report == (NETTOOLS_STAT_RUNNING|DHCPCODE_IPADD) ||
    //							 Report == (NETTOOLS_STAT_RUNNING|DHCPCODE_IPRENEW)) )
    //							IPN IPTmp;
    //							if( IPTmp )
    //								CfgAddEntry( 0, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER,
        CSL_SGMII_ADVABILITY    sgmiiCfg;
        CSL_SGMII_STATUS        sgmiiStatus;
        //// sss!!! ///
        volatile unsigned int i32;
        /* Reset the port before configuring it */
        CSL_SGMII_doSoftReset (macPortNum);
        while (CSL_SGMII_getSoftResetStatus (macPortNum) != 0);
         if (macPortNum == 1) {
            /* Hold the port in soft reset and set up
             * the SGMII control register:
             *      (1) Enable Master Mode
             *      (2) Enable Auto-negotiation
            CSL_SGMII_startRxTxSoftReset (macPortNum);
            //CSL_SGMII_disableMasterMode (macPortNum);
            CSL_SGMII_enableMasterMode (macPortNum);  //// sss!!! get it out! //////
            CSL_SGMII_enableAutoNegotiation (macPortNum);
            CSL_SGMII_endRxTxSoftReset (macPortNum);
            /* Setup the Advertised Ability register for this port:
             *      (1) Enable Full duplex mode
             *      (2) Enable Auto Negotiation
             *      (3) Enable the Link
            sgmiiCfg.linkSpeed      =   CSL_SGMII_1000_MBPS;
            sgmiiCfg.duplexMode     =   CSL_SGMII_FULL_DUPLEX;
            sgmiiCfg.bLinkUp        =   1; //////sss!!! (get out this!)
            CSL_SGMII_setAdvAbility (macPortNum, &sgmiiCfg);
            i32 = *(unsigned int*)(0x02090118);
            do
                CSL_SGMII_getStatus(macPortNum, &sgmiiStatus);
            } while (sgmiiStatus.bIsLinkUp != 1);
            /* Wait for SGMII Autonegotiation to complete without error */
            do
                if (sgmiiStatus.bIsAutoNegError != 0)
                    printf("SGM ERROR\n");
                    return; /* This is an error condition */
            } while (sgmiiStatus.bIsAutoNegComplete != 1);
        if (macPortNum == 0) {
             *      (1) Disable Master Mode
           // CSL_SGMII_disableMasterMode (macPortNum);
            do
            /////////// sss!!! get it out! ///////////////
             do
        /* All done with configuration. Return Now. */
        return;
    Thanks.
    Andriy
  • Hello Todd
    Do you have a simple example NDK UDP project configured with .cfg ?
     If you dont have it , please let me know where I can find  this sample.
    Thanks Todd
    Andriy
