In an attempt to make a portable project that could be built from our linux build farm, I downloaded CCSv5 beta and installed it into an Ubuntu VM. I shared the folder where I had my CCSv4 project, and I tried to import it into CCSv5. It didn't quite work. I monkeyed with that for a while, but didn't get things quite right. Then I tried to go back and open CCSv4 in my Windows Vista host. It immediately crashes, telling me to look at .metadata/.log in my workspace. Looking at that file, there are a bunch of errors that look Java-eclipse-ish. I, however, can't interpret that. I'm wondering if CCSv5 touched my project files, and now, on CCSv4 bootup, CCSv4 is looking for components and eclipsey stuff that isn't there? Just a thought. Can anyone parse this? (TI employees to the rescue?) Thanks.
!SESSION 2010-08-24 10:20:59.684 -----------------------------------------------
eclipse.buildId=4.1.3.00038
java.version=1.5.0_14
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2010-08-24 10:21:00.613
!MESSAGE A workspace crash was detected. The previous session did not exit normally.
!ENTRY org.eclipse.osgi 4 0 2010-08-24 10:21:00.662
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (194).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.compatibility.PluginActivator.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1014)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:970)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:317)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:256)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.preFindLocalClass(EclipseLazyStarter.java:86)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:409)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:339)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:388)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:352)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at com.ti.ccstudio.ui.CCEWorkbench.createWorkbenchAdvisor(CCEWorkbench.java:31)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:98)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:996)
at org.eclipse.core.launcher.Main.main(Main.java:971)
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element /twilight2 not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:257)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:585)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:50)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:47)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:88)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:816)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:815)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:792)
at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:517)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:655)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1318)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:1883)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:1653)
at org.eclipse.core.resources.ResourcesPlugin.startup(ResourcesPlugin.java:367)
at org.eclipse.core.internal.compatibility.PluginActivator.start(PluginActivator.java:31)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:995)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:989)
... 28 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2010-08-24 10:21:00.669
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
!ENTRY org.eclipse.osgi 2 0 2010-08-24 10:21:00.723
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-24 10:21:00.723
!MESSAGE Bundle update@plugins/org.eclipse.equinox.common_3.2.0.vTI-201005061800.jar [204] was not resolved.
