CCS: Opening Curly Bracket
I have trouble with symbol "Opening Curly Bracket" in CCS7.
If I press in code editor keypad combination for "Opening Curly Bracket" (AltGr + B) the symbol doesn't show in editor.
"Closing Curly Bracket" works fine.
Is there any trick for that in latest CCS7?
Thanks for any suggestions or solutions.
    Unfortunately my keyboard layout is Brazilian Portuguese and therefore AltGr + B does not type an open curly bracket character. However, did you try the ASCII code? In my case, Alt + 123 and Alt + 125 (in the numeric keypad) yield the open and close curly bracket.
    Hope this helps,
    Rafael
  • It seem to be problem in my Slovenian keyboard layout that it won't write opening curly bracket.
    If I tried combination ALT+123 opening curly bracket works fine.
    When I change Layout to "English" opening curly bracket works fine.
    Problem solved, thank you for your help "desouza".
