Part Number: LAUNCHXL-CC1310
I've created this target configuration, set the board's serials and attached projects to them in debug config. Whenever I go to debug it links both projects but then the "puck" doesn't respond to flashing. I've tried switching their serial numbers to be sure but it still doesn't flash. "Test Connection" seems to work. Any help would be greatly appreciated.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
<configuration XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_0">
<instance XML_version="1.2" desc="Texas Instruments XDS110 USB Debug Probe_0" href="connections/TIXDS110_Connection.xml" id="Texas Instruments XDS110 USB Debug Probe_0" xml="TIXDS110_Connection.xml" xmlpath="connections"/>
<connection XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_0">
<instance XML_version="1.2" href="drivers/tixds510icepick_c.xml" id="drivers" xml="tixds510icepick_c.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510cs_dap.xml" id="drivers" xml="tixds510cs_dap.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510cortexM.xml" id="drivers" xml="tixds510cortexM.xml" xmlpath="drivers"/>
<property Type="choicelist" Value="4" id="SWD Mode Settings">
<choice Name="cJTAG (1149.7) 2-pin advanced modes" value="enable">
<property Type="choicelist" Value="1" id="XDS110 Aux Port"/>
</choice>
</property>
<property Type="choicelist" Value="1" id="Debug Probe Selection">
<choice Name="Select by serial number" value="0">
<property Type="stringfield" Value="1" id="-- Enter the serial number"/>
</choice>
</property>
<platform XML_version="1.2" id="platform_0">
<instance XML_version="1.2" desc="Hub" href="devices/cc1310f128.xml" id="Hub" xml="cc1310f128.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="SimpleLink(TM) Sub-1 GHz CC1310 wireless MCU" id="Hub" partnum="CC1310F128">
<router HW_revision="1.0" XML_version="1.2" description="ICEPick_C Router" id="IcePick_C_0" isa="ICEPICK_C">
<subpath id="subpath_0">
<router HW_revision="1.0" XML_version="1.2" description="CS_DAP Router" id="CS_DAP_0" isa="CS_DAP">
<subpath id="subpath_1">
<cpu HW_revision="1.0" XML_version="1.2" desc="Cortex_M3_Hub" description="Cortex_M3 CPU" id="Cortex_M3_0" isa="Cortex_M3"/>
</subpath>
</router>
</subpath>
</router>
</device>
</platform>
</connection>
</configuration>
<configuration XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_1">
<instance XML_version="1.2" desc="Texas Instruments XDS110 USB Debug Probe_1" href="connections/TIXDS110_Connection.xml" id="Texas Instruments XDS110 USB Debug Probe_1" xml="TIXDS110_Connection.xml" xmlpath="connections"/>
<connection XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_1">
</choice>
</property>
<property Type="stringfield" Value="2" id="-- Enter the serial number"/>
</choice>
</property>
<instance XML_version="1.2" desc="Puck" href="devices/cc1310f128.xml" id="Puck" xml="cc1310f128.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="SimpleLink(TM) Sub-1 GHz CC1310 wireless MCU" id="Puck" partnum="CC1310F128">
<cpu HW_revision="1.0" XML_version="1.2" desc="Cortex_M3_Puck" description="Cortex_M3 CPU" id="Cortex_M3_0" isa="Cortex_M3"/>
</subpath>
</router>
</subpath>
</router>
</device>
</platform>
</connection>
</configuration>
</configurations>
Cortex_M3_Hub: GEL Output: Memory Map Initialization Complete. Cortex_M3_Puck: GEL Output: Memory Map Initialization Complete. Cortex_M3_Hub: GEL Output: Board Reset Complete. Cortex_M3_Puck: GEL Output: Board Reset Complete. Cortex_M3_Puck: Target timed out! (Block 0) Cortex_M3_Puck: Status 0x5DB9F52C: Target flashloader has not returned any status. Unknown error! Cortex_M3_Puck: File Loader: Memory write failed: Timed out waiting for target flashloader to execute command. Cortex_M3_Puck: GEL: File: C:\Users\[redacted]\puck_project\Debug\puck_project.out: Load failed.
